Question about Air Tools & Compressors
Manual for binks spray booth model number 83-2448
4 Suggested Answers
  • 760 Answers
SOURCE: No suction
This model comes in either suction feed or pressure feed. For example a 6211-4307-9 is a suction model. There are different air caps and needles depending on feed style. I assume your'e using either a 82-545 or a 82-555 suction cup attached to the gun. Make sure the tubing is tight, and that the vent hole in top of the cup isn't clogged. See Binks.com for detailed tip combinations.
Posted on Jun 30, 2010
SOURCE: i am trying to find a manual for a binks 2001
I looked up same gun. I think I googled "binks model 2001 spray gun" and I got a pdf with all info and diagrams. On the available websites, I looked for the one that looked like official Binks site.
The PDF # I got is 77-2316R-14.pdf. It shows that #7 o ring
Posted on Dec 08, 2010
  • 14 Answers
SOURCE: I need a users manual for a binks model 15 spray
Here you can find a manual: http://www.tpub.com/content/automotiveaccessories/TM-9-4940-507-14-P/TM-9-4940-507-14-P0006.htm
Michael
info@bsc-teknik.com ' www.bsc-teknik.com
Posted on Jun 21, 2011
My binks model 18 spray gun sprays inconsintaly on off on off ect.
this can be contributed to the seals around the needle part of the trigger operation
they get hard and don't seal properly
check gland seal nut for adjustment to place tension on the gland to make it seal
make sure that air bleed hole in the lid is clear and not blocking off
Dec 02, 2016 | Binks Air Tools & Compressors
My binks 2001 will not pick up paint under 60 psi, and at that must be very thin!
I think I would 1st check to make sure the fluid nozzle is not leaking (sucking) any air. There may be a small piece of debris between the nozzle and body causing it not to be completely sealed.
Another place to check would be the pick up tube to the main body.
If you don't have one, here's a link to the manual for your spray gun.
http://www.binks.com/Portals/0/repository/77-2626.pdf
Hope this helps.
Jun 14, 2014 | Binks Air Tools & Compressors
I bought a spray gun and wanted to know the difference between the two air caps one is numbered 36SD and the other is 67PD I have a binks spray gun.
67PD PE Used for Zinc rich and other abrasive coatings, the 36sd is a general nozzle that is used for most applications, if you need assistance,, heres their number Technical Support Tel. 888-992-4657 Fax. 888-246-5732 or you can check their PDF located here . http://www.southernfluidsystems.com/BICONV.pdf
Apr 22, 2011 | Binks Model 7 Conventional Suction Feed...
I am trying to find a manual for a binks 2001 spray gun i am having trouble figuring out where the o ring number 7 goes
Nov 05, 2010 | Binks Paint Spray Gun Repair/rebuild Kit...
No suction
Jun 30, 2010 | Binks Model 7 Conventional Suction Feed...
I need a users manual for a binks model 15 spray gun
Michael
Jun 14, 2010 | Binks SPRAY GUNS & OUTFITS
Spares for binks 630 spray gun
You can find spares for Binks 630 here: http://sprayfinishingstore.com/products/spray_gun/classics-gun/binks-630-gravity-spray-gun/
Michael
www.sprayfinishingstore.com ' info@sprayfinishingstore.com
Sep 29, 2009 | Binks Air Tools & Compressors
Binks bbr converting from pressure to siphon
Worked in paint repair shop for 18+ years. Every time we had that issue it was the wrong air cap. The particular model we always had trouble with was a Devilbiss JGA going from a pressurized system to a 1 quart cup. But the Devilbiss and Binks are quite similar.
The air cap from the pressurized system would actually cause a reverse pressure in the cup.
Both air caps were for this gun. Also the Devilbiss
rep said they should be interchangeable.
They weren't. Try a different air cap.
I'm kind of curious so please let me know if this works for your Binks.
Jul 31, 2009 | Binks MACH 1 HVLP Pressure Feed Spray...
Air Tools & Compressors Logo
166 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
