Question about Frigidaire Refrigerators
How do i fix my refrigerator with no power but the in side light is on >
Small refrigerator
    Problem Solver:
  • 9 Answers
On the back there is the core that actually does the cooling. On my mini fridge there was a little plastic screw-like thing that all I had to do was turn it a quarter turn. This reset the core and it worked for a little while longer. Mine ran for a couple days the first time and later the lifetime shortened to hours. Before I replaced the core I sold it. Hope this helps out until someone else writes on how to replace or rebuild the core.
Posted on Nov 08, 2014
Gd5rhaxnq00
The lights are controlled by door switches and a small circuit board near the compressor=> W10135090 Main Control Board
The control board is quite expensive and if you know someone that can replace circuit board parts it would really pay to have them replace a defective relay, Thanks Sea Breeze
Jan 30, 2013 | Whirlpool Gold White-on-White 21.9 cu. ft....
No power to Electrolux ESE6077SC side by side fridge freezer (a small white light flashes every 20 secs or so from the door water & ice dispenser though)
Hello - Sounds like the power outage possibly caused a communication problem with the control board to the refrigerator not responding. From what you explained in your comment, if the refrigerator seems dead I would strongly suggest contacting a professional to move forward accurately. If the unit is not cooling in either section of the appliance, unit can be experiencing some form of sealed system issue as well. This can include the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines not at the correct levels to properly cool. If the compressor is running, humming, or even a little warm then that is typically normal. However if the compressor is running hot, then it is over working and the issue could be before the compressor in the evap fan, coil or coolant lines. Unless the unit is displaying an error code, often alpha-numeric, then you would need to contact you're a professional to properly diagnose the refrigerator.
Oct 22, 2012 | Electrolux Refrigerators
Refridgerator light quit working on 2003 whirlpool gold conguest side by side
Unplug your refrigerator and gently pry out the light switch and test the light switch for continuity. Most likely the light switch=> C3680310 Light Switch is defective or the=> W10134764 Light Socket Best way to test the switch is found HERE. If you have questions on testing I will be here or through my websites, Thanks, Sea Breeze
Adobe Reader X 10.1.3 Free Download
GX5FHTXVQ00_Parts_Manual
Jun 25, 2012 | Whirlpool White Gold 25 cu. ft. ENERGY...
I have a Kenmore 795.5881 side by side refrigerator and I came home this afternoon and it has lost all power, no lights or anything. No breakers had tripped and the receptacle will power other items.
i had same problem, no compressor no lights nothing. power was good at outlet. took cover off top of unit. noticed a blown glass 15 amp fuse. cost less than 30 cents to fix
Sep 05, 2011 | Kenmore 59962 / 59964 / 59969 (25.5 cu....
Rudd furnace>>>> power surge.
Some circuit boards have a built in transformer and others have the transformer that sits right beside the board depending on the age of the furnace. First, look for a small 3 or 5 amp fuse on the circuit board. Check it, and if its good, and you have a small ohm/volt meter. Check your transformer. You can either ohm it out or just check for voltage. You have a "high" voltage side and a "low voltage" side of the transformer. The "high" voltage side will go to the power (120 volt) that comes into the furnace. This would probably be the side that would burn out during an elec. storm. To ohm the transformer: (This will be your best way to check)
1) shut off power to the furnace
2) pull the two wires loose that go to the "high voltage side"
3) put the leads from your ohm meter to each wire that goes to the transformer, and you should get some kind of reading. If not the "high voltage" side of the transformer is burnt out
You can follow those three steps to the "low voltage side as well, just remember where you take any wires off.
Be sure you have the power turned OFF. Good luck, hope this helps you.
Apr 18, 2011 | Heating & Cooling
My True bakery case light is off but the refrigeration is working. Please tell me how can I fix it?
>>> Please leave feedback so I can continue helping You & Others
Try replacing the globe.
Thanks,
Adam.
Feb 18, 2011 | True Refrigerators
Light does not work
1. remove power then look to see that the bulb socket bottom pin touches the bottom of the lamp; if it does not use a pen tip to bend it back up.
2. check or, replace the door lamp switch
Apr 07, 2010 | Frigidaire FRS26R4A Side by Side...
Ice maker is not operating
Take it out and let it thaw. -- They can freeze up. Also, there is a gear or small wheel on the front but under a plastic cover, remove the cover and (GENTLY) help the wheel turn (usually clockwise) and you may help to free up a locked wheel that turns the rod which dispenses the ice. Careful and goood luck!! >>>don't force it or you could damage it!!
Sep 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
My refrigerator is't cooling & my freezer is
Pull down plastic panel inside which covers the temp adjustment. In center there is small panel and under neath is computer chip board R&R board. This should fix your problem but be sure to turn ref off and defrost the chiller tubed on freezer side before starting back up
Denny
Jun 24, 2009 | Jenn-Air JCD2389G Side by Side...
Refrigerators not cooling
no reset but the frigs do have overload circuit that will shut compressor down,the frigs. compressors need a certain about of amps to start and to run ,what is the amp rating on your generator?let me know-mike
Sep 22, 2008 | Refrigerators
Refrigerators Logo
54 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
