Question about Vacuums
Kenmore 23155301c replacement filter
Can I still buy a replacement filter for this vacuum? If so, which filter do I buy. This one looks similar but without a product number attached to it I can't tell if it's right. http://www.sears.ca/product/kenmorei-md-hepa-filter-foam/620-000205658-472026?recs=igodigital
  • 1,923 Answers
Take the new one out of the package without destroying the package and put the old one up against it and see if it will fit. If you take it home see if the new one will fit. The new one may not look exactly like the old one but if it fits it should work. If it does not fit put it back in it's new package and take it back to the store. I have done this and had no problems.
Posted on Nov 08, 2014
reddevil6
  • 1673 Answers
SOURCE: HEPA FILTER REPLACEMENT
Looks like there are is an 2 indentations on the back, these are tabs, push them in and push the cover up, it should come off.
Posted on Jan 29, 2008
reddevil6
  • 1673 Answers
SOURCE: miele big blue
Could be a problem with the cord. There also is a circuit board by the motor that could be the problem. Did you drop something in the hose to see if it comes out the other end? Because you could have a clog. Or just unhook the hose and see if it runs that way.
Posted on Apr 28, 2008
debbily
  • 101 Answers
SOURCE: WindTunnel HEPA Filter won't spin
I just fixed my HEPA filter not rotating!!
It involves taking apart the vacuum HEPA area. All screws are the same size. There are a LOT of 'em. Really straightforward putting it back together too.
ok, once you take the HEPA canister area off the vacuum, careful with the wires! Unplug them from the controller board. You open up the HEPA chamber by removing more screws until you see where the motor that turns the filter is mounted on the side. Remove motor from the green chamber. Note where the washer goes. Once the motor is off, you'll see that the center hub that drives the HEPA filter is rounded out. What I did was jam little bits of aluminum from a pop can into the space between the circle and the square to force the walls back to square. I started by folding a little piece of aluminum over and over so it was about three layers thick. Jammed that in. That wasn't quite enough thickness so I shoved another piece with it. If you can find something that is about 4 times the thickness of a pop can aluminum, that'd probably work too. Slight wedge shape on the tip would help. Any sort of tiny shim.
To test your work, just put a couple of holder screws into the HEPA cannister housing, plug in the cover/switch, plug in the HEPA moter. Turn it on for a few seconds to make sure the filter turns. Then you can add more thickness to the hub or put things back together.
Posted on Oct 12, 2008
CMV9
  • 594 Answers
SOURCE: want to replace HEPA post filter
http://www.dyson.com/customercare/manuals/us/dc07_manual_us2007.pdf
here is the link to your owners manual. scroll down to page 6 it shows you the filter to clean and how to take it aprt.
Posted on Jan 08, 2009
  • 10 Answers
SOURCE: Need Manual for Kenmore Progressive with Direct Drive vacuum clea
You can check for the manual at:
www.managemyhome.com
I would suggest checking the hoses for clogs. Especially the hose right after the carpet brushes. Don't forget to clean off your brush. Hope this helps.
Posted on Jan 14, 2009
I was in the middle of vacuuming and all of a sudden the vacuum just stopped working. I looked, thought the bag was full so I changed it out and nothing it will not turn back on again.
If the bag was really full it could have restricted the airflow and caused it to get too hot and shut off. If it does not have a mechanical reset button it will come back on after it cools down. The filters may need replaced too.
Feb 20, 2017 | Kenmore Vacuums
Euro-pro EP57 vacuum bags
Call
EURO-PRO Customer Service at: 800-798-7398
514-842-8691
or Fax to: 514-842-6985
Monday to Friday 8:30 AM - 5:00 PM Eastern Standard Time
Replacement set of 2 Cloth Bags and 2 sets of Filters: $10.95 + $3.95 Shipping & Handling
Replacement set of 10 Paper Bags and 2 sets of Filters: $ 9.95 + $3.95 Shipping & Handling
Jan 30, 2013 | Euro-Pro EP055 Bagged Canister Vacuum
Unbeknownst to me, someone took the bag out of my Kenmore Progressive vacuum and failed to replace it. I have been vacuuming without a bag for months, and today the vacuum stopped sucking. When I opened...
Sounds like you need to buy a new motor. All that grit and dust will ruin a motor and I'm surprised it lasted as long as it did.
This is where a vacuum that won't run without a bag would have been nice. (Aerus for one)
Nov 16, 2010 | Kenmore 31913 Progressive Direct Drive...
As soon as I turn on my Kenmore upright bagless (twin chamber) vacuum cleaner, it makes a funny noise, then the red light goes on. As far as I can tell, there is no big clog
Have you replaced both filters? remove the canister and turn the unit on. feel at the inlet hole or under where the canister sits. If you have suction there and you installed new filters check in the hose for a clog, shine a flashlight at one end if you cant see the light use a broom handle or something similar (nothing sharp that will puncture the hose). If the hose is clear check where the hose plugs in to the brush head. sometimes cloggs can occur here. While you are at it you should throw a new belt on it if you havent changed it in the last 6 months. If you need any filters, belts, or supplies email me at chuck@acevacuums.com or check out my website www.acevacuums.com.
Mar 04, 2010 | Kenmore 25512/ 25513 Progressive Canister...
Hi, I have a canister Kenmore vacuum with power head. Everytime I use it, it smells sour. Its strong and like FEET with bad odor. My old Kenmore did the same thing but I used it anyway...because the power...
Never heard of this odor but if you have had it in both vacs it might have something to do with a disintegrating rubber backing on a carpet.
Arm and Hammer makes a baking soda based vac powder that will help eliminate some odors.
Do several things , get the powder and pour a tablespoon of it or baking soda into a fresh bag. Keep your filters fresh. If you use washable filters be certain they are thoroughly dry before reinstalling. And use a Mutli ply filter bag.. and NEVER pick up anything wet or vacuum a damp carpet
Sep 10, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
I have a kenmore whispertone 5.1 and need to find out if it has a hepa filter. I don't think so..... Thank you!
Hi If its the same as the one shown here:
http://cgi.ebay.com/KENMORE-WHISPERTONE-12AMP-HEPA-VACUUM-WARRANTY-AVE_W0QQitemZ310151428708QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item4836773a64&_trksid=p3286.c0.m14&_trkparms=65%3A12%7C66%3A2%7C39%3A1%7C72%3A1205%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
That model has a HEPA filter.
Otherwise the older models don't have them and rely purely on Allergy bags that you can buy for your vacuum.
Jun 27, 2009 | Kenmore Whispertone 23312 Bagged Canister...
Smoke coming out of my Kenmore Canister Vacuum Model 22550300C
Sounds like a motor err. Could be repaired by a professional but it never be as good as a new one. Also they you might not find anyone to repair it because the replacement motor might cost more than a new vacuum /considering it's age the motor will be hard to find and that makes it more expensive to repair./
I suggest you to buy a new vacuum.
Feb 16, 2009 | Kenmore Vacuums
Kenmore progressive vaccuum
Did you replace the hepa filter with a new one? Those filters may not look bad, but after a period of time and use, air is restricted thru them. They should be changed at least once per year.
Sep 03, 2007 | Kenmore 31913 Progressive Direct Drive...
My vacuum is not sucking at all.....
I took out the air flow filter at the back of the vacuum and turned it on, somehow the clog cleared. Then I put the filter back in and it works perfectly! Barb
Mar 01, 2007 | Kenmore 35912 / 35913 Progressive Upright...
Vacuums Logo
82 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
