Is it cost effective to replace draft inducer blower on 22 year old furnace?
Brant Serial Number: 0592A03516 Model: 394HAD024050 AAJA My 22 yr old furnace works great but makes an ungodly noise for a few seconds before kicking on (heat only - not A/C). Sounds like a tuba player! Should I spend money on repair or just replace the furnace?
  • 1,977 Answers
Depends on the cost to repair. Probably a 22 year old furnace is not very efficient also. Take every thing into consideration.
If it still works it may work for a while but you don't want a break down in the middle of winter.
Posted on Nov 08, 2014
  • Phyllis Purcell
    Phyllis Purcell Nov 08, 2014
    Estimated repair is $300-400. Estimated replacement is $1800-$2000. But you're right. I bet the furnace isn't energy efficient. Maybe I should bite the bullet. If I could repair it myself, it might be worth the 'band aid' but unfortunately, I'm not mechanically inclined.
  • Phyllis Purcell
    Also, I turned the heat off & the fan on. No noise. Is that the norm? And the noise is intermittent -- doesn't happen every single time the heat kicks on. But when it does, it sure is loud.
Need to find a replacement part
Here you go Angela
1149097 Draft Inducer Assembly - AllParts Heating
www.allpartsheating.com/1149097.html
  1. Cached
  2. Similar
Draft Inducer. 1149097 draft inducer for Heil, Tempstar, Arcoaire, Whirlpool & Comfortmaker brand model furnaces. This part replaces old part number 1008416.
Arcoaire Furnace Motor Parts: Fast Shipping RepairClinic.com
www.repairclinic.com/Shop-For-Parts/a36b389c53/Arcoaire-Furnace-Motor-Parts
  1. Cached
  2. Similar
Furnace draft inducer assembly. The draft inducer motor draws air into the burner and exhausts it out the flue. If the draft inducer motor is defective, the furnace ...
Arcoaire Furnace Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a36b389/Arcoaire-Furnace-Parts
  1. Cached
Direct Factory Replacement Inducer Blower Motor Used in 90 ...
www.americanhvacparts.com > ... > Oem Direct Replacement Models > Arco Aire
  1. Cached
  2. Similar
Direct Factory Replacement Inducer Blower Motor Used in 90% Furnaces. ... Comfortmaker, Intercity Products Snyder-General, Heil, Tempstar, Arcoaire Draft Inducer Blower Motor. ... Used in ICP Equipment Models: ... GUH125A016CIN
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor ...
https://www.amazon.com/1149097-Arcoaire-Furnace-Inducer.../dp/B00FFBQRGA
  1. Cached
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor - Fasco Replacement: Replacement Household Furnace Motors: Amazon.com: Industrial ... Draft inducer motor for arcoaire model guh125a016cin Google Search
Nov 27, 2016 | Heating & Cooling
I need to replace the draft inducer Fasco A190, P/N C341445P01. It's $400! Is there a less expensive alternative?
This is not a "tool" question, you should have posted to Air Conditioners.
eBay doesn't list any right now, last one went for $50.
Is it the control board or the fan or both that you need to replace? Might be able to find the control board separate if you have that number.
Best bet if you have the time, is eBay, Craigslist or a local heat and air repair guy who might have an old one he can sell you.
If you are lucky:
Ten-year internal functional parts limited warranty is effective on units installed after October 1, 2001 and manufactured January 1, 2000 or after. Earlier installations have two-year parts warranty
http://www.customengineering.info/products/esxv90.html
Sep 26, 2012 | Omega Trane Furnace Draft Inducer Blower...
I removed my Fasco 7021-11577S when the bearings went bad and ordered the A225 OEM replacement. I notice that when mounted this new draft inducer it whistles really loud .Is the hole in the back of the...
There should be a gasket between the mounting flange of the inducer motor and the furnace. If you do not have that you can use a small bead of blue or red silicone caulking to seal it. Hope this helps you. Thanks
Mar 29, 2011 | York Furnace Draft Inducer Blower Fasco #...
What is the model number for the Draft Inducer Motor Goodman GNP075-2REVB Furnace
I think you must mean GMP075-2rev8 check this link for parts listing:
http://site.famousparts.com/goodman/PDF/RP-169C.pdf
Johnstone supply which has many locations in many cities sells Goodman and stocks parts, and available mailorder http://www.johnstonesupply.com/corp/Default.aspx
Feb 18, 2010 | Goodman Furnace Draft Inducer Blower ...
Draft inducer runs continuously, unless i turn the furnace off at the fused switch on the furnace. Turning the Honeywell thermostat to the off position does nothing to stop it, nor does removing the front...
Sounds like some one needs a new induce draft fan relay, if relay is located on the main control board you have to replace control board,follow wires from inducer motor and you will find the relay. I could help you more if i knew model # and serial # of the furnace, Good luck.
Feb 06, 2010 | York Furnace Draft Inducer Blower Fasco #...
The fan motor went out and the furnace is not even 5 years old.
I have an Amana High Efficiency furnace that I purchased 5 years ago this past October (2009). My furnace started making a horrible noise last night and then stopped working. The repair person, told me my draft inducer motor needed replaced, and showed me where the plastic fan blade inside of the inducer was "chewed up." Of course my first question is, "How can a 5 year old furnace need such a costly repair already?" The only answer I received is that it will cost me close to $500.00 to have the situation remedied (service call, parts, labor). I started looking around on the internet today, and discovered that high efficiency furnace inducer motors are usually encased in plastic and the motor fan blades are made of plastic rather than metal like the lower efficiency models. Turns out that these plastic blades over time can't withstand the high heat generated and in time (they estimate 3-4 years) break. The damage to the blades causes an imbalance in the way they spin, which in turn, generates the resulting problem of a damaged draft inducer motor. Appears this is a design flaw. Yeah! I'll say. I spent $3100.00 for a brand new furnace and 5 years later I'm paying another $500.00 and apparently can look forward to doing the same in 3-5 more years! Maybe this answers in part your question?
Dec 07, 2009 | Goodman Furnace Draft Inducer Blower ...
Gas furnace is constantly blowing cold air
An indoor blower running when it is not supposed to usually indicates an overheat condition. I would guess that it has been cycling on and off for some time and finally caused the high limit to stick and not auto reset. if you tap it sometimes they reset. the real problem is that it has been overheating from lack of airflow, over sized unit, not enough return air, too many closed registers, dirty filter, dirty squirrel cage blower and or air conditioner a-coil. If you get it started again sit and watch the unit run the flames should come on and stay on for the entire heating cycle, not going on and off.
I wish I could help you more but it is difficult without seeing the problem myself. Good luck! this should get you started!
Nov 01, 2009 | Heating & Cooling
Heating & Cooling Logo
312 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
