Question about 2-way Remote Transmitter - Dark Navy/gray
Manual transmission won't remote start even though Ive followed all the steps to leave it in reservation mode and car remains running until Ive exited and closed driver door. Error code is Sta
Manual transmission won't remote start even though Ive followed all the steps to leave it in reservation mode and car remains running until Ive exited and closed driver door. Error code is Start Error 7. Vehicle unlocks but doesn't start. There's nothing in the manual for this.
  • 162 Answers
If your getting 7 flashes from a Compustar brain there is something not working right with the manual reservation mode. Double check to make sure it is 7. If it is then go see an authorized Compustar dealer and have them go over the installation and programming of the unit.
Posted on Nov 08, 2014
Rumbling noise coming from engine compartment.
engine size, etc., I can only make educated guesses, but here goes: You stated "My car will drive, but very slow hardly moving". My first suspicion is that you don't have a transmission problem, but the car is in what Chrysler calls the 'limp-home mode'. This occurs when the computer 'sees' a problem with an engine function or sensor that is serious, but not so bad that the car won't run at all. Limp-home mode allows your car to only operate in second gear so that you won't damage it further by driving normally, but won't leave you stranded either. Is your 'check engine' or 'service engine' light on? If not, check to see that it actually works by turning the key 'on', but not starting the car. All the dash lights should be lit for about 3-5 seconds. No matter what, you need to check your transmission fluid level (on a Crysler, should be checked with the engine running and in gear, NOT park or nuetral). Safety first, make sure someone is holding the brake on - please don't ever trust a 'parking brake' for this. If the fluid level is OK and there's no 'check engine' light you need
to visit a competent transmission shop. Probabably a worn front pump, torque converter, or a hung spool valve in the valve body, none of which is generally fixable at home. If you do have a 'check engine' light on, see a regular mechanic first as there is a mechanical problem probably not related to the transmission. Good Luck!
Oct 13, 2012 | 2003 Chrysler Sebring
Low coolant in reserve every week
Absolutely have to stop using it, until the issue is resolved,
just common sense
There are no Fluids on any vehicle that are consumed
or need topping off,ever
You have a leak & it has to be found
If you see no coolant leaks & you need to really
spend time looking.
Have to crawl all over & under the vehicle & don't miss a thing,
check both hot & cold & after a trip
You could have a head gasket going & that is not good,
you won't see any leaks with that situation.
Sep 14, 2012 | 2000 Jeep Grand Cherokee
The 'theft system' light does not turn off with the key in the run position on my 1999 chevy cavalier. car won't start, it won't even crank over. the battery and the starter are brand
try locking your car with the key and unlocking it with the key, leave it for 30 second or so between the locking and unlocking , the car thinks some one has tampered with it
Mar 18, 2012 | 1998 Chevrolet Cavalier
Remote doesn't control on/off,volume or channels
Remote won't workThe most common reasons the remote won't work is that the batteries are dead or it hasn't been programmed properly. It's often easy to fix. Here are the steps to take to troubleshoot the problem.
Make sure you have a clear path between the remote and the infrared eye on your equipment. Clear any dust or debris that may be covering the eye.
Try unlocking the battery-saving mode. When a button is pressed for longer than three minutes, the remote goes into battery-saving mode. Press the SAT mode button at the top to unlock it. Your remote should work properly.
Check the batteries. When you press a mode button, does it light up? If not, you may be out of juice. Check to make sure they are in the right way, with the metal ends making good connections with the metal in the remote. If they're in correctly and you still don't get power, try replacing them. They may be dead.Learn about batteries
Check to make sure the remote is programmed properly, which basically means you reprogram it to work with your receiver, TV and any other components. Start with the receiver and work your way through programming each component that isn't working. We tell you how to program remotes in our guide to remotes.Learn about remotes
Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.Be prepared to tell us:What components you have.All of the steps you've been through to try and solve the problem yourself.Can't change channels on receiverThis is almost always caused by a programming problem with the remote. Here are the steps to take to troubleshoot the problem.
Make sure you are in SAT mode. The receiver will only change channels when the remote is in the correct mode.Look for a timer. If you have a timer set, the receiver won't let you change channels. This ensures you don't miss recording a program with an external device. If a timer is set and you want to watch another channel, simply turn off the receiver and turn it back on.Learn about timers
Make sure the problem is with the remote and not the receiver. Try the buttons on the front of the receiver. Try to change channels. If your model doesn't have channel buttons, try to turn the machine off. If you can't change channels or power off, the problem is with the receiver. Try unplugging it for two minutes and plugging it in again.
If you can change the channels or power off, the problem is with the remote. Press any mode button on the remote. It should light up. If not, you probably have low batteries. They should be replaced.
Try unlocking the battery-saving mode. When a button is pressed for longer than three minutes, the remote goes into battery-saving mode. Click on any of the mode buttons at the top to unlock it. Your remote should work properly.
Try re-programming the remote to talk to your receiver.Find the manual for your remote control
Check to see if your Shaw Direct Receiver is using the same remote control address as your remote control.If you are using the DSR 319, HDDSR 505, or HDPVR 530 receiver press the Options button on the front panel of your Shaw Direct receiver. An options menu should appear on your screen. Using the direction keys on the front of your receiver navigate to 6 - System Setup and then press the Enter button on the front panel of the receiver. Using the same directional and Enter buttons go to 4 - System Setup. Then 3 - Installation Settings. Followed by 2 - Remote control Address.If you are using a legacy receiver such as the DSR 315, DSR 405, or any other receiver with front panel buttons, press the Options button on the front panel of your Shaw Direct receiver. An options menu should appear on your screen. Using the direction keys on the front of your receiver navigate OPTIONS and then press the Enter button on the front panel of the receiver. Using the same directional and Enter buttons go to 6 - Change System Settings. Then 3 - Change Installation Settings. Followed by 2 - Set Remote Control Address.Follow the on-screen instruction to reset the remote control address on your receiver and remote control.Check the back of your remote, if you own the IRC/URC 550 or RT-U50 remote controls you will need to enter the remote control address differently from what is displayed on screen. To program these remotes, hold the ENTER and MUTE button on your remote at the same time until the mode buttons at the top start to illuminate then enter the last three digits of the number displayed in "Current Address" column on the screen, then press the MUTE button to lock in the code. For example: If the remote address on the screen displays 0002, you would hold ENTER + MUTE until the mode button illuminated and then enter 0 0 2, followed by ENTER on your remote control.If you own the IRC 551 or URC 551 remote control you can follow the instruction depicted on the screen, but you must substitute the follows numbers in place those specified: 00869 for 0000, 01870 for 0001, 01871 for 0002, 01872 for 0003, 01873 for 0004, 01874 for 0005, 01875 for 0006, 01876 for 0008. For example: If the remote address on the screen displays 0003, you would hold the SAT button until it flashes, press 01872, then ENTER, to lock in the new code.Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.What components you have.All of the steps you've been through to try and solve the problem yourself.Can't control TV volumeThis is almost always caused by a programming problem with the remote. Here are the steps to take to troubleshoot the problem.
Press the volume button on the remote. The TV mode should light up. If not, you probably have low batteries. They should be replaced.
If the SAT button lights up, you are in the wrong mode. Press TV and try again.
Try re-programming the remote to talk to your TV.Find the manual for your remote control
Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.What components you have.All of the steps you've been through to try and solve the problem yourself.Thank you for using Fixya, Hope this will help your problem.Don't forget to rate me.thanks,Reymond
Oct 18, 2011 | JVC AV-27850 27" TV
I changed tv's and everything works except the volume buttton on Dish remote. It won't turn down or up or Mute.
I came across your post, autumlite; that's interesting! I have a few steps for you to follow to get that taken care of so you can start enjoying the convenience:
Address To Other Equipment Using Power Scan
  • Remote: All Remotes (except Basic)
    1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
    2. Press and release the Power button. AUX Mode: Before pressing and releasing the Power button
      • Press 0 for a TV
      • Press 1 for a VCR/DVD
      • Press 2 for any other device
      Then Press STAR (*)
    3. Press the Up button once a second while pointing the remote at the desired equipment. Note: If the code for the equipment comes up, the equipment will power off.
    4. Press the POUND (#) button. Note: If the code entered is valid for the remote, the mode light flashes three times.
Hope that helps and let me know if you need any further assistance!
Aug 27, 2011 | DISH Network IR Remote Control
2001 Saturn L300 transmission shifter does not shift when car is started, foot on brake. It remains in park. Can't shift transmission into grear. a clicking noise is heard
Almost all newer cars have a safety that won't allow you to shift without a foot on the brake. These are either cable or electric solenoid activated. They fail, so check your owners manual, as it will have the procedure to get it to shift, untill you can get it fixed correctly.
Jul 05, 2011 | 2006 Saturn L300
Replaced ignition switch in 1999 chevy cavaliar rs, anti-theft light comes on and stays on and won't allow car to start and remain on or run
You have to do a relearn procedure on the anti-theft system:
Attempt to start the vehicle. Leave the ignition on until the THEFT SYSTEM indicator turns off (about 10 minutes). Turn the ignition switch off. Leave the ignition switch off with key in for about 10 minutes. Attempt to start vehicle.
May 24, 2011 | 1996 Chevrolet Cavalier
I just brought universal remote control it an 8 way diital slx rc050 i can get it to pair with my accousic solutions sp 101 amp have you got any codes that would work for this please
try this if you need the manual let me know. (PLEASE rate if it was helpful)
If you are programming the remote for a brand/model that is
not listed in the Popular Brand List or the Direct Code Entry
(e.g. Wharfedale, Acoustic Solutions etc), it is recommended
that you use the Learning Mode (go to section 4).
Follow the steps below to program your remote using the
learning function.
1. Press and hold the device key you wish to learn for 3 secs.
The LED turns ON when the key is pressed but turns OFF
after 3 secs indicating that the key can be released.
2. Release the Device key, LED turns back ON.
3. Press and release the RECORD key, the LED turns off
when the key is pressed and turns on after release, the
remote is now in the learning mode.
4. Press and release the key on the RC050 that you want to
learn to, the LED will blink once and then remain ON with a
lower brightness to indicate it is ready to learn.
5. Face the head of RC050 to the head of your original
remote control, leaving a gap of 5cm (2”).
6. Now press and hold the original remote key (the teaching
key), do not release this key until the LED on the RC050
this indicates an error. Repeat steps 4-6 to correct the
error.
7. LED remains on, repeat steps 4-6 for other key functions to
be learned.
8. Press and release EXIT key to exit learning mode at any
time, the LED turns off.
9. If no keys are pressed for more than 15 secs while in
this mode, the remote exits the mode and the LED turns
OFF
good luck
4. Learning Mode
Dec 18, 2009 | Televison & Video
How do u program Bush DFTA13HD STB TV buttons
The following is an extract from the Bush DFTA13HD/ DFTA13HDSIL user manual, page 9;
1. Press STUDY key until Red LED remains lit (for about 3 seconds)
2. Point Converter (Bush) remote control to TV remote control directly, keep the distance about 1~3cm
3. Press the "Power" key at TV/s remote control to send signal to Converter remote control. The LED light will flash till steady. Then press "Power" key at Converter remote control. It will record the signal.
4. Now the Power key can turn on/off TV/s power
5. Repeat settings of learning for the other keys
You can repeat Step 3-4 for setting of learning for the other keys at TV remote control, such as VOL /-, CH /-, and F1, F2 are reserved for any other keys you want to set up.
Note:
1. When you have finished setting the learning keys, press the STUDY key to leave the learning status, and the LED light will turn off.
2. The learning function of this remote control may not support all types of TV sets, if you still can not control your TV after you have attempted the above steps, then this remote control may not support your TV or its remote control.
Jul 19, 2009 | Televison & Video
REMOTE STARTER NOT WORKING COMPLETELY
Here is page 2 of the owners manual, Hope it helps.
This will not start the vehicle if any one of the following situations exists;
The vehicle's hood lid is opened.
The gear shift selector is not in Park.
The brake pedal is depressed.
The safety control switch is in the Off position.
1. To start the vehicle, press and release the transmitter button two times within 2
seconds. The vehicle will start and remain running for the pre-programmed 5,10,15,20 minute run cycle. As a visual indication, the parking lights will flash or remain on depending on the setting by your installation center.
2. When you arrive at the vehicle, turn the ignition key to the ON position (not the spring loaded start position), then step on the brake pedal to disengage the remote starter. The
vehicle will continue to run, but now on it's own power.
NOTE: The engine will stop running before the pre-programmed run cycle has expired if you perform any one of the following functions;
-Press and the button on the keychain transmitter two times within 2 seconds.
-Depress the brake pedal.
-Open the vehicle's hood
-Place the unit in the safety control disabled mode.
PRLED SAFETY CONTROL SWITCH
The Push-Button LED control switch allows you to temporarily disable the remote starting function of the system. This recommended whenever the vehicle is being serviced. To place the system in the service mode:
1) With the system disarmed/unlocked, and the ignition switch off Press and Hold the PRLED on.
2) Turn the ignition switch on, off, on, off, on, off.
3) The LED begins to flash two short flashes followed by one long flashes and continues this pattern until returned to normal mode of operation. This puts the unit into the R/S Override mode indicating that the remote start is in the service mode and will not start from RF or any other input Posse or otherwise.
To Exit R/S Override Mode
1) With the system disarmed, Press and Hold the PRLED on.
3) The LED turns off indicating that the R/S unit is fully functional one again
Dec 18, 2008 | Car APS921 Remote Starter - Keyless Entry
2-way Remote Transmitter - Dark Navy/gray Logo
124 people viewed this question
Top Compustar Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Compustar Vehicle Part and Accessory Expert? Answer questions, earn points and help others
