Question about Kitchen Appliances - Others
My fryer work good but iam concern when the unit is off there is a small lite around the burners nozzle i
    Top Expert:
  • Kitchen Appl... Master
  • 42,623 Answers
If this a gas fired unit the light will be a pilot light to ignite the gas when the thermostat setting is reached to shut if of after operation , close of the gas tap. If it is electric it may be a light to let you know the same thing
Posted on Nov 08, 2014
bigg t
  • 640 Answers
SOURCE: Imperial deep fryer model: IFS-40
Sounds like the pilot is dirty,if you have propane gas this is your issue,replace the pilot either way.
Posted on Sep 04, 2008
  • 234 Answers
SOURCE: deep fryer burners will not lite
Does this fryer plug up to power of not?If it don't ,then thehi limit is out,need to reset it and try lightning it back.You will need to hold if for a minute.At this time if it don't stay lite,then replace the pilot thremcouplen.
Posted on Mar 13, 2009
  • 2514 Answers
SOURCE: ef4 deep fryer
if it has a power phile was this replaced
Posted on Jan 21, 2010
kebah
  • 683 Answers
SOURCE: Hi, i am having a problem with a deep fryer. Pitco
Make sure that the gas pressure is standard (as rated on nameplate), thermopile must be clean (no dirt or soot) and the thermostat is good.
Posted on Jun 06, 2011
  • 99 Answers
SOURCE: fryer burner shuts off at
Sounds like thermostat is bad? For confirmation on this, call our service tech, Ray at 888-542-5959 at Restaurant Equipment Outlet, Cincinnati, Ohio. We normally ship parts in 1-2 days if you need something... Thanks, Susan REO
Posted on Sep 14, 2011
I have a picto fryer and when i turn of the t-stat knob the main burners turn off but there is a small flame at the orifice tip.
If that small flame does not go out, it sounds like there is gas passing around the valve core of the gas valve. Regressing the core will stop this from happening.
Mar 08, 2014 | Pitco Frialator SG18S Deep Fryer
I light the pilot everything is fine then when i go to turn thermostat on pilot light goes small and burners dont light and when i turn back to pilot the gas ignites and goes out
Sometimes certain models turn off if you touch the thermostat before it lites...
We've seen this happen many times, so you would need to light the fryer first, wait until it's stable before turning your thermostat to desired temperature.
Sep 02, 2011 | Pitco Frialator 35CS Deep Fryer
Pilot will lite,but burners will not lite when you turn the thermo. up
Make sure gas valve is in the ON position after lighting the pilot. Try jumping the thermostat terminals together to see if burner comes on. Three things could cause this problem 1. bad operator on gas valve 2.low millivolts 3. thermostat not functioning
Tom
Aug 03, 2010 | Frymaster Dean SR42G Deep Fryer
Hi, i am having a problem with a deep fryer. Pitco Frialator 35CS. The pilot is liting, but the burner will not lite. Solve this for me. thanks
Jan 19, 2010 | Pitco Frialator 35CS Deep Fryer
Keating fryer won't stay lit
You might want to see about getting your money back or swapping it for another. I'm guessing it is a natural gas model. If so check and make sure you have between 4 and 5 water columm gas pressure. If so I would start by checking the thermopile and make sure it's producing around 700 milivolts. If your not able to measure this or have the tools to do so, I would start by replacing the thermopile. (This is not a thermocouple.)If this does not fix the problem. You have a bad gas valve. Thermopile cost around $60.00. Gas valve runs around $30000You can go this web site for more info http://www.tmeinc.biz/xkeat.htm
Please rate solution
Sep 05, 2009 | Keating Instant Recovery 14CMG Deep Fryer
Deep fryer burners will not lite
Mar 13, 2009 | Vulcan EF4 Deep Fryer
Aug 22, 2008 | Imperial Kitchen Appliances - Others
Garland deep fryer
gas valve not fully turned on
cattering hose not fully pushed into connector
thermostat tube inside oven broken (new valve)
Nov 13, 2007 | Garland AF-5025 Deep Fryer
Gf 40 frymaster fryer
Hi, I am suposing that this fryer has worked good in this location before. If not, check to make sure it is set up right for your gas supply. (LP-Nat) There is something wrong with the gas - air flow in your unit. Look for obvious things first like exhaust being blocked, Flame dancing out side of fire area, Pilot too small, Build up of debris in fire box. The pilot should be able to be adjusted at the gas valve if it is too small. I believe you problem could be taken care of best with a good cleaning of the burner, fire box and pilot assemble. Make sure that all burner holes are clean especially around the pilot light. Check for oily debris inside the fire box to make sure its not leaking into the fire area. If you are unable to do this yourself, contact some one either in the restaurant equipment service business or heating and air conditioning business. Hope I have helped you. kstfas NOTE: If this answer does not rate at least 4 marks, (almost there) please do not rate. Thank You.
Sep 26, 2007 | Frymaster Dean GF40 Deep Fryer
Kitchen Appliances - Others Logo
43 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
