SOURCE: Adding light to Hunter Fan w/o light
you can get the kit at home depot, it has a plug inside, under the cap. very simple
SOURCE: I needed to replace the
Hi. After you pull the first filter out, look with a flashlight because there is another right beside it unless it was never there to start with. So, there are two filters in there.
Dale
SOURCE: could I use wire size 14 for 1 1/2 ton air window
No sir,14 gauge,three conductor will carry only up to 15 amps,which is usually wired for lighting circuits.Look on the electrical requirement plate on the unit,usually located under the front panel cover.It will tell you how many amps are drawn when unit is operating.Using a three conductor cable;wire accordingly:#14--15amps----#12--20amps---#10--30amps----#8--50amps.These are the wire sizes and the current(amps)they will carry.Be safe! Gregg
SOURCE: Craftsman 1/2 inch impact air driver leaks air
put a bunch of hydraulic oil in it and this will lubricate the seals inside to form a more uniformed seal it will stop leaking air.
SOURCE: I need a replacement reuseable cartridge filter
Look at the Big Box store for your parts ...
Perch diameter is an extremely important factor in relation
to perch choice. It is crucial that you
choose a perch that is the right size for your bird. Here is a sizing chart I came across to help
educate you further on perch diameter.
Your bird's foot should wrap around approximately 2/3 of the perch;
their toes should never meet/overlap.
Bird size Perch
Diameter
Extra
small 1/2 an inch or less
Small 1/2 an inch to 5/8 of an inch
Medium 3/4 of an inch to 1 inch
Large
1 inch to 1 1/2 inches
Extra
Large
2 inches to 2 1/2 inches
