My 22 yr old furnace works great but makes an ungodly noise for a second or two before kicking on. Sounds like a tuba player! It only happens when the heat goes on, not the A/C. Assuming it's the d
Serial Number: 0592A03516 Model: 394HAD024050 AAJA
  • 66 Answers
Sounds like a Bryant inducer assembly. When was the last time you had this cleaned and checked?
Posted on Nov 13, 2014
Testimonial: "I had it cleaned last year when they replaced the thermocouple. I have decided to replace the furnace. I have quotes on Trane, Lennox, Comfort Maker, Goodman, Rheem & Payne. Trane is much higher than the others, but I don't want to buy skimp & be sorry later. I have to go with the 80% because I can't drill holes in the wall of my building. Any advice??"
  • Robotinner Nov 18, 2014
    I am a Lennox dealer so I am a bit biased. What you need to do is find a tech or company you are comfortable with. I prefer working on the big three units versus the others. Lennox,Trane and Carrier are good units. I would go with one that has a variable speed motor or dc at least they seem to work longer and are more efficient on electric. A two stage heating cycle is great for comfort and usually has a better warranty. I would also recomend a media filter to protect your investment. the money you spend on it now will be worth it in the long run. A merv 10 is fine enough don't get anything new fangled there. hope this helps:-)
2 Suggested Answers
FurnaceGuy
  • 74 Answers
SOURCE: I have a new home 1 yr and when the furnace kicks
Check by turning the unit off and turn the fan to on. Do you hear the noise now? The noise your hearing could be coming from your combustion fan assembly instead. Newer furnaces have a in-shot burner and are nosier than the old style of heater.
Posted on Jan 04, 2010
When furnace ignites making weird noise and i checked outside piping odore when running not the same as usuall once the blower kicks in furnce sounds ok but doent seam as warm as normal
needs a tune up. flame is probably yellow which means it is burning too much fuel and therefore not getting as hot and it would smell different also.
Mar 10, 2015 | Miscellaneous
Is it cost effective to replace draft inducer blower on 22 year old furnace?
Depends on the cost to repair. Probably a 22 year old furnace is not very efficient also. Take every thing into consideration.
If it still works it may work for a while but you don't want a break down in the middle of winter.
Nov 07, 2014 | Heating & Cooling
Goodman Heat Pump laing heat and loud noise
Taking a little bit of time for heat is normal but the "pressure" thing you are referring to leads me to believe that the reversing valve is getting stuck. You will here that "pressure release" noise with a reversing valve but it should not be happening 5 minutes after start up.
May 06, 2017 | Goodman Heating & Cooling
I have an older Miller Furnace in a mobile home that I own. The unit was made around 1977-78. Think the model number is MGC-80-1. It does two things that seem odd. 1st is it will kick on like it should,...
sounds like the fan control is playing up try cleaning the back of it could have dust in it cleaning my help fan could be a loose spindal which the fan spins on see if this helps
Nov 06, 2010 | Heating & Cooling
I have a new home 1 yr and when the furnace kicks in, I am assuming the fan it makes a noise but as soon as the heat starts the noise is gone, could this be the furnace blower
Jan 04, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
AiWa stuck on mute - no sound from subs.
have you tried powering down unit and seeing what happens?
Dec 02, 2009 | Aiwa CDC-X227 CD Player
Goodman GSK9 (2yrs. old) gas furnace won't run
I don't have the same system, but on mine when I replace anything, I have to reset the system by killing power to it for a few minutes.
I hope yours is the same,
RSMITH972278
Oct 15, 2009 | Heating & Cooling
Goodman furnace
sounds like the fan switch in the furnace is coming on and off. This is common for Goodman. or could be the heat anticipator on the t-stat. While there are several reasons this happens these are the most common.
Guy
Oct 29, 2008 | Heating & Cooling
Sub zero making a horrible noise
if it is coming from under your unit is it most likely the water inlet valve for the icemaker check that and let me know you will have to remve the 2 screw on the kick plate to get to it,it should be on the left side
Apr 07, 2008 | Refrigerators
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
