Question about HP Computers & Internet
Why is my laptop getting hot right where I rest my left hand when I type?
It's a 15.6 inch screen HP Envy m6. On the right hand side it has that SimplePass fingerprint scanner built in. It's the left side where I rest my left hand when I type that is getting too hot to touch.
    New Friend:
  • 26 Answers
Go to a person, have an aircompressor, and blow the pc.in all slot ) opening from all side then all your problem are gone- tksvm fritz
Posted on Nov 08, 2014
    Scholar:
  • 78 Answers
Probably where your graphics card and/or CPU is located under the bezel. Make sure you are not blocking the vent holes on the laptop, and try to keep the laptop raised in back to allow heat to dissipate. If it's old enough, the fans might be blocked with dust and/or failing, in which case the laptop won't cool properly.
  • 1 more comment
  • Carolyn Anne
    Carolyn Anne Nov 08, 2014
    I have a laptop riser with built in cooling fan to sit the laptop on. When I keep the riser raised so the screen and back of the laptop is higher, it makes that spot hotter than having the laptop level. In fact, since a few days ago when it was up in the back and it got way too hot to touch, I keep it level. It still gets hot but not so hot I can't touch it.
  • Jon Evans Nov 08, 2014
    Unfortunately, this is a known issue with the Envy M6. There's simply too much processing power packed into a poorly designed cooling solution.
    That being said, there's an excellent thread on the HP site,http://h30434.www3.hp.com/t5/Other-Noteb... , read the fourth comment down by Xephya ... detailed description as to how you can lower the CPU power and decrease the heat significantly. Not my work, just posting the crosslink.
  • 4 Answers
SOURCE: How to use HP 6515b FingerPrint Scanner. Its Built
If you are using Windows XP Go to this page and look under the security section.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3355651&prodTypeId=321957&prodSeriesId=3368537&swLang=8&taskId=135&swEnvOID=1093#7887
and download the appropriate driver
Posted on Mar 19, 2009
starcomp
  • 117 Answers
SOURCE: I tried to get a fingerprint smudge off of my presario laptop screen and must have touched it too hard... colored horizontal line appeared. Then another and another and now there is another... beginn
this was happening due to damage or loose connection on u r laptop display panel cable. refix it. it may solve u r problem
Posted on May 25, 2009
Murphybanton
  • 2004 Answers
SOURCE: I have an HP Pavilion tx 1000 and until recently
Run system restore to an earlier date. This should fix it.
If it does not, then do restore back to factory default but backing up all your documents.
rate this please.
Posted on Jul 11, 2009
Mustgo
  • 2359 Answers
SOURCE: hp pavillon tx1000 12.1 inch touch screen cursor
Clean the screen with a clean soft cotton cloth is the step #1
Step 2:
SEE FULL instruction HERE
Calibrate the touch screen
The command buttons and fields are displayed on the screen image at specific pixel points. To initiate a response, the touch screen interface needs to recognize exactly where a fingertip or pen touches the screen relative to the pixel position of the display. Each user has a slightly different hand-eye coordination response. Calibrating the touch screen allows the interface to compensate between where the program is expecting a touch and where the touch actually occurs. To calibrate the touch screen, place the tablet notebook in the desired orientation and do the following actions.
  1. Click or tap Start > Control Panel > Tablet PC Settings to open the Table PC Settings window.
  2. On the General tab, select the option to display the menus in either the Right-handed or Left-handed position.
  3. On the General tab, select the desired screen orientation from the drop-down menu, and click or tap Calibrate . Follow the instruction to touch the screen at the specified points. Repeat this calibration action for all four of the screen orientations, then click or tap Apply .
  4. On the Handwriting Recognition tab, select the Use the handwriting personalization option.
  5. At a later time, you can return to review the Go to Pen and Input Devices and Go to Input Panel Settings options to make using the touch screen to control programs and input text easier and more accurate.
Compare your version of the firmware to the latest one at HP offical site HERE
Always get the latest firmware to avoid problem.
Always keep the screen clean!
Posted on Jul 11, 2010
jay120782
  • 111 Answers
SOURCE: when i press my right
RESTORE UR COMPUTER  to the last date things where running right  if u need me to explain how to guide u in this step send me an email at jay120782@gmail let me know who u are again and i will send u  step by step on how to do it.  i will be up 4 alittle while longer so send the email right now u need my help
Posted on May 16, 2011
Laptop restart by itself 20mins when i switch it on, it won't go off again till i turn it off and on again then it will restart by itself 20mins after. I have remove the dust from the sink.
what are you asking,?
who can fix it (any PC shop on earth)
or how can you diagnosis it and how to test PC?
what is the question?
yes, all do that , eventually. all do.
HP Envy M6
M6-nnnnn why not tell the helper, what nnnnnn is,, the full model matters. as does the unstated OS? Windows 7?
a laptop no less, my guess.
m6-1000 is 5 years old (i tossed 2 dice to get that, model.)
here is the list, and page links on tests.
  1. the battery is bad, the big one, as all do soon.
  2. remove the silly main battery and run on AC forever or?
  3. the coin cell is bad, as all do 5 to 10 years old. $2 fix.
  4. The HDD is bad. test it. ask. how. it's not hard.
  5. The power pack is dead. replace it but not before doing step1
  6. The OS will reboot you if the OS gets corrupted, or HDD bad.
  7. its overheating, does the fan work at full speed.?
  8. or worse, there is always worse, see the huge list here.
we know the PC processes and the screen works.
but resets, reboots, or even BSOD's
this rebooting usually progresses to dead black screens.
and the cause is same, leaving out bad screens.
see the stripping tests here, for the hard nut cases.
http://www.pcdied.com/black-screen.html#Laptop
the hdd tests are here.
a bad HDD self corrupts the OS, and then resets.
HP will even on newer machines put you on the F11 recover page any time the pc does that.
i do the linux tests. booted from CD.(or usb stick)
http://www.pcdied.com/brick-dead.html
Dec 15, 2017 | HP Computers & Internet
Problem with HP envy m6 laptop. Keyboard lags, or skips letters when im typing an email or web document.
HP Number: (888) 508-8524
Mar 12, 2016 | HP Computers & Internet
How off narrator on HP laptop
In the bottom left hand of the screen, next to the round windows icon, in the empty search box, (assuming that you have Windows 7) type in narrator. You should then see a menu or result for narrator where you will find the option to turn narrator off.
Sep 20, 2014 | HP ENVY dv7-7240us 17.3" Notebook PC
Any solution for hp envy m6 laptop that selects Screen
Can you clarify the question? I'm not sure what you are asking? "selects Screen"?
Apr 09, 2013 | Computers & Internet
Laptop black lines
Take it back - it's under warranty.
Mar 23, 2013 | HP ENVY m6-1105dx AMD Dual-Core A6-4400M...
Forgotten login password for hp envy m6
there are programs you can buy and some you can download basically u need a boot disk with the right utility email me
Mar 02, 2013 | HP Pavilion dv6000z Notebook
I have a hp envy m6 cant find the control pannel
press window key and r key together, this is run command , a dialog box will open then simply type control panel in the box and u r done . control panel will open automatically.
Nov 20, 2012 | Computers & Internet
HP Pavilion dv5 gets hot in left hand corner. I've had this laptop for 9 months with no problems. This morning I noticed it getting very hot on the left front corner where my left hand rests. About...
HP Tech Support & HP help phone number 1-8002044427 for troubleshoot HP problems.Our certified technicians are available 24/7 to deal with your HP ...
Jun 01, 2017 | Computers & Internet
Computers & Internet Logo
73 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
