Question about LG Televison & Video
How do I connect a virgin v box to an old lg model?
Model is lg flatron l172wt The Virgin box has an hdmi cable,the tv does not. I bought a connector that allows me to plus the hdmi cable to it and then to the tv. It shows me the box options but the image is black and there's no sound.shall I get a scart rather than what am using?
  • LG Master
  • 5,499 Answers
The hdmi cable would not be compatible with your old style TV, if the Virgin box has a scart socket then that is your best option!
Posted on Nov 08, 2014
  • 13 Answers
SOURCE: No sound when plugging a Virgin Media V+ box through HDMI
have you tried a hd cable this could be the answer if not get back on to virgin as they supplied the box etc they should sort this for you
Posted on Sep 03, 2009
SOURCE: connect tv to cable box with hdmi lead
You will need an HDMI to DVI cable which are available in the shops, even ASDA has one but I don't know how good it is. Or you can buy an adapter that will plug into one of the ends of the HDMI cable and then plug into the DVI socket at the back of the TV. The DVI input is video only so you will need audio leads for sound. These will connect from the output of your source, say, blue ray or sky HD (Left and right audio sockets ) to the audio L/R at the back left of the TV (on the block next to the three component video connections and s-video connections)
Posted on Jan 28, 2010
SOURCE: Vizio 47'' LCD HDTV (Model SV470M). This TV is
I have been having the same problem!! Did you get a solution? Thanks for the help!
Posted on Feb 23, 2010
  • 144 Answers
SOURCE: Hi, I have a
I , would try using another ( alternative connection) from your humax , say the scart cable just to see if it , the humax is ok. then if tv has more than 1 hdmi skt try it too, if still not working retry upgrade firmware route
pete
Posted on Nov 11, 2010
  • 8457 Answers
SOURCE: Just purchased a Samsung LE46C650 LCD tv and it is
No,half a second that not consider a problems.There are hundred of hardwares and softwares design by dozen of compannies and corporations.Putting these diveces together 100% functionals are not gaureentee.99.99.....% out of 100% is not cosider a problems.
Posted on Nov 20, 2010
Ive got a panasonic model 32pf7520d/10 ive also vigin but i cant watch programs in high definition what cable do i need to connect the tv to the virgin box
If you don't have one already, you will need to get a hidef box from your cable provider( make sure it comes with an HDMI port) Once you have that, then you connect an HDMI cable from the HDMI port on the cable box to any HDMI input on the tv
Apr 03, 2011 | Panasonic Televison & Video
HDMI settings wouldn't work
What did you do to lose the HMDI output? How is everything exactly hooked up?
Apr 30, 2008 | Televison & Video
I have a JVC RM-C60 TV. I'm trying to tune it in to my Virgin Media HD box using a standard SCART lead but having no joy. It's completely failing to find the cable channel (or any other for that matter)....
Tuning of the TV not required when using scart lead, just select external input that the scartis connected to, ie AV1,AV2 (EXT1,EXT2) etc. The problem is possibly to do with the Virgin box, it may be set to HDMI out in which case it will not output anything via the scart lead, you would need to connect via an HDMI lead (small socket on the rear of the unit looks a little like a USB socket). Problem is if your TV is a CRT television its unlikely to have this socket. Your Virgin box can be reset to output via the scart but you would need to contact Virgin for this process.
Feb 17, 2011 | JVC Televison & Video
We have an LG 32LX2R-ZE. We have no sound, but the picture (Virgin Cable) connection is fine as is our Internet. I've checked all the leads and, no, neither the TV or the Virgin box are on mute!. Any...
I had the same problem and after buying loads of different cables came to the conclusion that the HDMI input on the TV was at fault. Bit of a sledgehammer to crack a nut but I upgraded my home cinema amp to one that had HDMI in/out and now I put the sound through that and use the TV as a panel with volume turned to zero.
Jan 13, 2011 | LG Televison & Video
Hi, I have a 32LG3000 HD tv with software version 3.47.1. I just bought a Humax FoxT2 HD free view box but when connected via hdmi to the LG tv a message briefly comes up on the tv saying invalid format...
pete
Nov 11, 2010 | LG 32LC7D Television
Cant tune to hd from virgin box
You should not have to tune into HD, you should be connected via a HDMI connector from the Virgin box to theTV, which means you only need to select the HDMI input source & then select your channels fron the Virgin box.
Oct 24, 2009 | Televison & Video
I want to connect a Virgin HD box to my Panasonic TH-42PV500B TV currently connected to a Panasoniv DVD recorder On Scart AV1. How do I switch between Virgin and existing equipment which I would like to...
what you need to do is obtain an HDMI cable for your Virgin HD box. Leave the rest on scart (you can probably even add a another box now that you've freed up one port). Basically just press the button on your TV remote, saying 'Source' and you can flick through all your scart soxkets and HDMI ports. Simples.
Oct 24, 2009 | Panasonic Televison & Video
Poor signal bush hd set top box
I have a saterllite reciver just bought a bush hd freesat top box i am running my virgin cable tv through my samsung hd television i put my satallite cable in to my bush top box connect the hdmi cable to get the freesat turn my virgin box off source the hdmi cable on tv get the freesat logo but nothing else what am i doing wrong
Aug 31, 2008 | Televison & Video
Red screens cause flickering
if normal tv is fine then ,likely the signal from the box is too hot.
if using composite switch to cable ch 3 or vice versa,
or use hdmi cable or change the box .
Apr 22, 2008 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
76 people viewed this question
Computer Repairing
Computer Repairing
