Hi, I have a fujitsu asu36clx1 air comditioner. When the unit is off it stills pulls 215 watts. Is this normal?
  • tainofinance Nov 09, 2014
    Monitor showing air conditioner off. Consuming 215 watts all the time when is off!
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
First of all how is it you determined it is still drawing wattage? Do you mean amps, Are you using an induction meter ?
Posted on Nov 09, 2014
Testimonial: "Hi. I add some pictures of how I get the amps and then the monitor that shows the drawing watts when the air conditioner (inverter) when is off."
Have broken blower wheel in a Fujitsu ASU36CLX1 Wall Mounted unit. How do I disassemble the unit far enough to replace the blower wheel?
That's no easy chore to achieve! My friend from another HVAC company changed 1, said he'd never do it again. He had to pull the unit from the wall. But if you try it, most of these units are snapped together by plastic tabs. I've tried to pull 1 to clean the blower wheel. I have 15yrs exp. in the field, 2 yr associates degree, been pulling wrenches since I was a kid, and I will not change that style of blower wheel. I usually ask the customer to change the unit. I know this won't help your situation but it's my opinion from experience.
Aug 26, 2017 | Fujitsu Heating & Cooling
ASTA12JEC Fujitsu Air Conditioning unit. Dear sir or madam. My air conditioning unit is no longer responding to remote control but stays on. It used to work fine then one day it stopped responding.
Start by replacing the batteries to your remote control and make sure there is nothing blocking the IR receiver on the unit itself. If that is blocked by something hanging on it or tape over it from something hanging on it previously.
Jan 31, 2015 | Fujitsu Heating & Cooling
What error is causing it to flash 2 x green and red then 5 x red?
This fault relates to a over current protection,
fault can be a number of things
connection failure (check power and connections)
outdoor fan failure (fan operating?)
outdoor coil dirty (is air passing through coil or is it clogged)
compressor failure (compressor operating?)
pcb and/or inverter PCB failure (is there power at boards or any visual damage)
Aug 14, 2012 | Fujitsu ASU36CLX1 HALCYON Mini Split Wall...
Hair window air comditioner is making funny noises
Hello, the noises you are hearing can be a few differant things. It could be the condensate being pcked up and splased on the condenser which makes a swishing sound, this is normal. It could be the fan blade hittting the shroud and that happens when the fan gets loose on the shaft. It also could be the compressor itself if liquid refrigerant is entering the compressor,
May 13, 2012 | Haier Mechanical Air Conditioner HWF05XC7
Can I use an 18 volt universal AC Power Adaptor on Fujitsu Lifebook P7120 which is a 16 volt laptop?
With voltage step down power supplies, output power is more important than data plate output V (volts). V times output A (data-plate amps) equals output Watts (or VA) under normal load. If the voltages are close and the output watts (VA) are very close (one or two watts) you are in luck as long as the connector is same size; AND THE POLARITY (+ & -) IS THE SAME for the old and replacement unit!
Jan 17, 2012 | Fujitsu LifeBook P7120 Laptop AC Power...
Hi I have a problem with my Fujitsu wall mounted air conditioner ,model AST24RGB-W the outdoor unit fan is running but there is no cold air coming out from the inside unit I put it on high cool to get cold...
I think, your compressor is not working. Check with amphs meter. If less amphs gas leak. Arrest the leak and re charge gas. If tripping with high amphs change capacitor. Still high amps, compressor is defective.
Dec 26, 2010 | Fujitsu Heating & Cooling
How do I remove front cover of Fujitsu indoor unit
THE INTAKE GRILLE REMOVAL
(1) Open the intake grille.
(2) Pull down the knob.
(3) Lift the intake grille upward, until the axle at the top of the intake
grille is removed.
THE FRONT PANEL REMOVAL
(1) Remove intake grille (Reference the intake grille removal.)
(2) Remove four screws.
(3) The thumb is hung on the lower part as shown in the figure,
and it pulls to the front, pushing [-] mark , and bottom hooks
(two position) is removed from wall hook bracket.
(4) The front panel bottom is pulled to the front, and bottom hooks
is removed indoor unit.
(5) The front panel is pulled to the front, raising the upper surface,
and a front panel is removed.
Feb 23, 2010 | Fujitsu 18R1 Air Conditioner
Have just installed a Fujitsu Asta 24lC air con heat pump problem
Hi Shannon,
I would pursue your fight with Fujitsu, normally their units are reliable:(
It could be a really simple problem or a really complex one ranging from many componenets. A air conditioner has many more components that people may think. Keep fighting to get the unit repaired will it is still under warranty, after that Fujitsu wont want to know you. It could also be a wiring and refrigerant fault. Call Fujitsu out again.
I take the time to answer your question, so please rate me.
Thankyou Mat
Aug 24, 2009 | Heating & Cooling
Ammonia smell when Dometic Air Comditioner is on
sounds like you have an old unit and it has a leak , the real old units where filled with ammonia as the gas
Feb 16, 2009 | Dometic Rooftop RV Air Conditioner
Aou18c1 not shutting off
Fujitsu, Mitsubishi, Sanyo mini-split indoor fan motors operate continuoulsy. The room-temperature sensor is inside the unit, so the fan motor needs to circulate air continuouly to sense room-air temperature. This is normal operation.
Sep 12, 2008 | Fujitsu 18C1 Air Conditioner
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
