Question about HP Electronics - Others
Hi, I have a fujitsu asu36clx1 inverter. When the unit is off it stills pulls 215 watts. This is normal?
Have broken blower wheel in a Fujitsu ASU36CLX1 Wall Mounted unit. How do I disassemble the unit far enough to replace the blower wheel?
That's no easy chore to achieve! My friend from another HVAC company changed 1, said he'd never do it again. He had to pull the unit from the wall. But if you try it, most of these units are snapped together by plastic tabs. I've tried to pull 1 to clean the blower wheel. I have 15yrs exp. in the field, 2 yr associates degree, been pulling wrenches since I was a kid, and I will not change that style of blower wheel. I usually ask the customer to change the unit. I know this won't help your situation but it's my opinion from experience.
Aug 26, 2017 | Fujitsu Heating & Cooling
What does opp stand for on a motor master 3000 watt inverter
Unit is shutdown with display showing "OPP"
Inverter is short circuit and has shut down.
Reset to normal operation by using manual switch
Nov 26, 2016 | Inverter Electronics - Others
Hi, I have a fujitsu asu36clx1 air comditioner. When the unit is off it stills pulls 215 watts. Is this normal?
First of all how is it you determined it is still drawing wattage? Do you mean amps, Are you using an induction meter ?
Nov 07, 2014 | Heating & Cooling
What error is causing it to flash 2 x green and red then 5 x red?
This fault relates to a over current protection,
fault can be a number of things
connection failure (check power and connections)
outdoor fan failure (fan operating?)
outdoor coil dirty (is air passing through coil or is it clogged)
compressor failure (compressor operating?)
pcb and/or inverter PCB failure (is there power at boards or any visual damage)
Aug 14, 2012 | Fujitsu ASU36CLX1 HALCYON Mini Split Wall...
Power inverter fan don't work
fan should come on when the unit has a load on it and it starts to get hot.
Jun 05, 2010 | Watts 75w Power Inverter 12v Dc To 220v Ac...
I bought two Victor 750 watt inverters ,and was led too belive i could stack them and get 230 volts. This did not work ! why.
In order to get 230 volts out of any 115 volt inverters you would need to be able to hook the outputs up in series with each other. If your inverters have outlets there is no way to do this other than completely dismantling both units and then I wouldn't advise it. As a licensed electrcian and electronics tech I've sometime done things like that but only as experiments or in emergencies.
If your units came with a power(+) and ground(-) you could then hook them up in series by fastening the (+) from one unit to the (-) of the other, then tape them to insulate them. You should then show 230 volts from the two leads still available. On the battery side you will still hook both postives(+) to the positive(+) and both ground(-) to the negative(-).
Notes:
* Depending on the internal wiring of your units the above description may not work and could damage or even ruin your inverters.
* Although you may get 230 volts this way you will not have more power(watts,Amps) than listed for one unit and you may even have less.
* You need to also beware this could VOID any warantees and shorten the life of these units.
May 31, 2010 | Victor Power On Board 1500 Watt Power...
Low voltage output from inverter
I am thinking this a high impediance device problem and this is normal operation - the user manual of my inverter warns about use with high impediance devices - if not I am interested also...
Jan 23, 2009 | Electronics - Others
How many batteries do I need to run a coleman 1500 watt power inverter
It would depend on the load being driven by the inverter (which would determine the current drawn by the inverter), the capacity of the batteries and the shutdown voltage of the inverter.
Oct 01, 2008 | Statpower PW-1750 Triple Outlet 1750 Watt...
Electronics - Others Logo
Top HP Electronics - Others Experts
Tape-Techie
Raj Patel
Are you a HP Electronics - Other Expert? Answer questions, earn points and help others
