Question about Music
Change battery - Music
  • 35 Answers
Change battery on what?
Posted on Nov 14, 2014
How to get and change the backup battery?
If you are not concerned about possibly voiding the warranty, figure out how to get access to the battery and find out whether a standard replacement will work.
Mar 22, 2015 | Hammond XM-2 Drawbar Sound Module
Changing the battery in the O1R/W module
Nothing to it. Remove the cover and you'll see the round battery about the size of a quarter in a grey holder. Remove, Replace the reboot the unit. If you look at YOutube, you'll see the procedure on the similar keyboard and the module works the same way.
Mar 01, 2015 | Music
Where is the battery on a digitech 21 pro and how do you change it?
The top panel has to come off. 2 phillip screws in the back, 3 on each side rail, and one 9/32 ( not sure on size) on the front, in the middle. Lift off carefully, the top bends. Facing front of unit, battery will be on the left side in a holder. Looks like an oversize AA battery. If this is the first time changing, you will need to clip off zip tie holding it down. Battery is getting harder to find. The one from Radio shack is too short. Do not bend the + and - tabs. You will snap off leads going to circuit board.
Jan 06, 2015 | Music
Why won't my digitech 21pro save my program changes. I know how to chage parameters and save those changes yet when after saving them and shutting down the unit, when I fire it back up it goes
Did you try changing the battery yet? It uses a lithium battery to keep the settings in memory and those eventually die. People forget that old electronics needed juice all the time.
Korg sp-250 randomly changes the voicing
When was the last time you changed the batteries? You may have gotten a pack of expired batteries the last time you replaced them. I suggest changing batteries.Jimmy
Apr 08, 2012 | Korg SP-250
Hi, my behringer us 600 works only for some minutes and then it turns off and on without pressing a button or doing something... i've already tried to change the batteries but nothing changed... i...
Check if the connection of the input cable MIGHT be intermittent. The sleeve of the connector enables the battery when the cable is inserted. If the cable is moved in the least and the sleeve makes intermitent contact that would cause your problem... a lesser probability is a loose battery contact.
Jun 17, 2011 | Behringer US600 Ultra Shifter/Harmonist...
Hi my name is Susanna and I own a Yamaha DTXtreme iis and whenever I turn the power on the screen shows this message: WARNING:DATA INITIALISING PLEASE PRESS ENTER. Then all my memory of the user programmes...
Probably the battery replacement was NOT done correctly or there is a problem with the battery voltage getting to the memory.
The original message was probably the result of the unit detecting the data was corrupted due to the backup battery not maintaining the memory.
The CORRECT Lithium cell for this unit is a CR2450
This is NOT a common available cell and LIKELY the person installed a readily available one which is not working.
Here is link to a supplier:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=N340-ND
This cell is thicker than the commonly available cells and if the readily available was installed, it would not make contact. Open the unit and check the cell in the holder at BT1 on the board.
Here is service manual which has disassembly instructions.
Mar 09, 2011 | Yamaha DTXPRESS IV Standard Electronic...
It wont turn on and starty working iv changed the batterys what else can i do ?
Check battery direction. Also if the unit can use a power adapter, sometimes the contact in the connector for the adapter that connects the battery when the adapter plug is out fails to contact and connect the battery.
Jan 30, 2011 | Disney Hannah Montana Karaoke System with...
Tuner for my acoustic guitar no longer works
Change the battery again and make sure you get a fresh name brand battery.
SOME batteries that are off brand or old or just plain defective will cause your symptoms.
ALSO check that it is securely contacting the battery contacts.
Things thaat come on for a second MAY just be residual charge on the filter capacitors that a breif contact was made to the battery.
Oct 26, 2009 | Alvarez Music
Music Logo
24 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
