Question about Acer Aspire Computers & Internet
Where can I get a installation media to repair the boot configuration?
Model #aspirexc603g rating 100-127/220-240 vac 6/3a 60/50hz fc can ices-3(b)/nmb 3(b) ul60950-1 E112725 when the system come up this blue screen comes up and says is missing some boot configuration
  • ramona gray
    ramona gray Nov 07, 2014
    where can i et a cd recovy dis
    Scholar:
  • 78 Answers
Go to this link:
http://us.acer.com/ac/en/US/content/drivers
Enter the model:
Aspire XC-603G
All drivers and documentation is available there.
That being said, I think your problem is worse. You will need to create a boot CD, in all likelihood, and install new drivers from there.
Posted on Nov 08, 2014
  • 112 Answers
SOURCE: dead comp
Sounds like your hard dive has gone.
Posted on Mar 27, 2008
cinek79
  • 320 Answers
SOURCE: cant recover system i do
try to boot from your recovery CD and reinstall system
Posted on Sep 17, 2008
rwalkero
  • 82 Answers
SOURCE: Dell Dimension C521 w/Vista will not boot OS.
There is no way around this you need to get your OS from Dell and reload.
Sorry.
Posted on Feb 19, 2009
SOURCE: blue screen stays on too long.
My opinion is that when sp3 was installed there probably is an upgrade to the or a patch to the sp3 for that machine chipset and is windows defaulting to a prevous driver if it cannot load the new one. Goto microsoft see if there are issues with this machine and goto hp and see if there are upgrades and a bios patch. If you do not know what I am talking about then a professional should be check the machine for you. Hardware problems are generally ver evident. machine won't start the monitor won't come on, No mouse pointer. very likely it is software related. If you donot know what I am talking about then you should consult a professional whom you trust.
Posted on Mar 17, 2009
  • 17 Answers
SOURCE: Error code 0F00:137B
GO TO BIOS SET UP VERIFY WHEATHER HARD DISK IS DETECTED OR NOT IF NOT CHANGE ID CABLE OR PLUG TO ANOTHER ID PORT ONCE GOT DETECTED TRY TO BOOT IF NOT BOOT IN SAFE MODE
Posted on Sep 07, 2009
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
The boot configuration data for my pc is missing or contains errors
Unless you took the time to create your own boot/recovery media (CDs) when you first got the computer, your only option would be to get on another computer and check for the availability of them on the vendor's website. (A real pain due to the many different models and configurations)
Have you tried a boot-up in *Safe Mode*? This will only be possible if offered as a failed, boot-up option screen, though. Sometime, if the boot files that are missing or have error are not too damaged they can be rebuilt when booting up in Safe Mode.
It might be possible to boot up into the BIOS - power it on and then repeatedly type the correct function key. (Check your manual for the right one.) Some BIOS configurations have an option to run Checkdisk - a DOS program which can sometimes rebuild boot files.
Apr 02, 2015 | Acer Aspire V3-571 15.6-Inch Laptop -...
Can power on
Check the fuses.Blown fuse conditions
FU1 - 6,3A Doors/covers open is displayed.
FU2 - 6,3A Doors/covers open for the finisher is displayed.
FU3 - 4A paper end condition.
FU4 - 6,3A SC 121 is displayed.
FU5 - 6,3A one of SC302 or SC403 or SC405 is displayed.
FU101 - 15A no response.
Fu 102 - 8A no response.
FU103 - 1A normal operation,optional heaters do not work.
If FU or 102 is the problem,verify the main motor and the fusing unit heater lamps and thermofuses.After change the problematic fuse removal the fusing unit and turn ON the copier.
Apr 18, 2013 | Ricoh Aficio 450 Copier
<windows root>\system32\hal.dll file is
Resolution
1. Restart the PC. The hal.dll error could be a fluke.
2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
5. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
6. Recover data from any bad sectors on your hard drive. If the physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
7. Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
8. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
9. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Important: If you can't gain access to your files to back them up, you should understand that you will lose them all if you continue with a clean installation of Windows XP.
10. Test the hard drive. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive but you'll want to test it to be sure.
If the drive fails any of your tests, replace the hard drive and then complete a "new" installation of Windows XP.
Mar 09, 2011 | Microsoft Computers & Internet
Windows media does not give audio on some avi files.vlc and nero players are fine . how /why is there a diffrence?Is it a codec problem if so can a different codec be copied into the windows media player...
This is due to the configuration of your AC3 filter or the absense of AC3 filter. VLC media player has these built in but for Windows Media player/Media centre you need to install & correctly configure the codec. Google KL codec pack & install the full version. Take all the default options, re-boot & all your audio will play through Windows Media player & media centre. KL codec pack also contains many other useful tools & codecs & nothing that will harm your PC. Don't forget to rate me.
Oct 22, 2009 | Computers & Internet
On boot up laptop states it can't find the operating system
this sounds like you need to repair the boot sector. this usually happens when a hard disks boot sector becomes corrupt or damaged. to fix this you must use the windows install disk to install recovery console. put the disk in the CDROM drive, reboot, (you may need to press F2 upon bootup to enter setup and choose to boot from the CDROM instead of HDD) once computer is configured to boot to the CD drive reboot and choose "repair" when prompted by the cd. once the repair prompt is up you must run the 'fixmbr' command which will copy boot files back to your computer. hope this helps. please rate me and thanks for choosing enterprise computing solutions.
Oct 06, 2009 | E-Machines eMachines Desktop PC
How do I get my Acer 5500 to boot from my uTorrent recovery disc?
Do you have your original recovery media for Vista? Sounds like you're going to have to repair the installation.
Dec 27, 2008 | Microsoft Windows Vista Home Premium with...
HP Media Center m1080n PC... Problem
If you have the original restore disk, you could try and fix it. But if you have an actual copy, you can go to install it but when it propts you click repair. It should go into a dos mode, and then type fixboot, (this is for if the computer comes to the boot logo and then crashes and shows boot logo again, or if it comes to the blue screen of death) and hit enter. also if prompted, you could try last known good configuration.
These are some methods of fixing your computer without erasing all data!
Cheers and Please Rate!!
Jul 17, 2008 | HP Media Center m1080n (PC099A#ABA) PC...
Computers & Internet Logo
76 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
