Question about Sunbeam Heated Fleece Electric Throw
How do I get a control for a sunbeam electric throw? When my Mother passed I got her things. I cannot find the control so I am not even sure it works. The style HT-4 - listed 613A - E23623 - also o
YOU CAN CONTACT ME AT NANSID@CHARTER.NET
3 Suggested Answers
SOURCE: I need to find a replacement control unit for the
I have the same numbers on my blanket, mine has a PAC-215 controller, I found a couple of them on ebay. Don't know it all blankets have the controller so check the numbers on the back of your controller.
Posted on Mar 07, 2010
  • 5370 Answers
SOURCE: electric sunbeam fire place not
Is the blower fan working and its not heating or blower fan is working but still not heating.It can be faulty blower fan or faulty heating element. Also check the thermostat if both fan and heating element checked ok. It is really easy to change it, unscrew the four small screws at the top cover and replace the thermostat.If blower fan is running,if heating element is checked ok and its not burnt in between or got cracked and thermostat looks fine,then the thermal fuse in the fire place needs to be checked. if you take off the top of the fireplace you will find a little metal tube in front of the blower. This is the thermal fuse if it has gone out only your fan will blow and the heating element will not put out heat. You can pick one of the fuses up at radio shack for 3 dollars. the only problem is how to go about repacing it since it is crimped in and you can't use a soldering iron because it will trip it.So the procedure to replace the thermal fuse is ,---- To crimp in the thermal fuse on the fireplace, you can take and clip the lead of the old fuse and then crimp down the left over old clip and then bend upward and use a electrical wire splice uninsulated to crimp on to it and then crimp in the fuse. You then can use the 1/4" male tab where the wire is attached and remove and put a female to 2 male 1/4" connector on it and put a 1/4" female on the fuse and put it all together. This will require no heat and it will still be safe.------------- This are the possibilities,that are to be checked.This troubleshooting will help.Thanks.Helpmech.
Posted on Mar 07, 2011
I want to know if my throw is under warranty. I think I probably registered it as a gift, probably two years ago, a Christmas gift. Serial #D105VT07176010612B86112.
Hi Judith
your heated throw has a 5 year warranty! Warranty is covered on this page, specs are on the bottom link.
http://www.sunbeam.ca/en_CA/service-and-support/product-support/product-faqs/bedding/warranty/bedding-warranty-faq.html
Sunbeam Velvet Plush Heated Throw Mushroom Sunbeam Canada TSV8WS R772 26A50
Dec 02, 2015 | Sunbeam Fleece Throw Electric Heated...
Looking for the manual for the Sunbeam Bread Maker
www.sunbeam.com/...support/service-and-support.ht...
Jun 05, 2015 | Sunbeam Kitchen Appliances - Others
I wish to replace or buy a new control for my Automatic Heated Throw. The P.N. number is: 105190-000. Please advise. jaclapp@gmail.com
I'm sorry, but I'm confused! This question references grill SG7621sp but mentions the Heat Throw, the only reference I can find that involves most of your information is a Sunbeam "electric blanket" item. Can you help me narrow down the search parameters?
Jan 10, 2013 | Sunbeam SG7621SP Grill
Sunbeam heating pad no longer heats. The red
I had same issue w/ red blinking light on my Sunbeam controller SW114, pad CAT93. Was about to toss away but then got it to work perfectly by doing this:1. With unit UNplugged, press & hold the single grey controller button2. While pressing the controller button, plug the unit inUnit will power up in the 'warm' (green light) setting; pressing the controller button will cycle you thru the others modes.
Jan 12, 2010 | Kitchen Appliances - Others
Electric blanket does not warm
Call the manufacturer. They will often do repair for free.
Dec 03, 2008 | Heating & Cooling
My Sunbeam electric blanket controls blink when I plug the control cable into the blanket. I cannot turn the controls on or off.
Same problem, but now it is ok.  I emailed Sunbeam and was told that if my blanket was not plugged directly into a wall outlet it was not getting enough power and I needed to plug it into a wall outlet taking these steps:
1) Unplug from the surge protector/extension cord 2) Unplug from the blanket 3) Plug back into the blanket 4) Plug into a wall outlet
Jul 21, 2008 | Heating & Cooling
Sunbeam Heated Fleece Electric Throw Logo
81 people viewed this question
Top Sunbeam Home Experts
topcat7736
Level 1 Expert
Andrew Taylor
Andrew Taylor
rhodesworks
Are you a Sunbeam Home Expert? Answer questions, earn points and help others
