Question about Euro-Kitchen Kitchen Ranges
Fix the 12v lights on my euro ventro sv218 island mount. blower is ok bulbs are new
4 Suggested Answers
  • 579 Answers
SOURCE: Light on fan.
Most likely, the dimmer control has failed and needs replacing. Would be good to check its output voltage first.
Posted on Dec 31, 2007
dr_greg
  • 192 Answers
SOURCE: Both 2005 Honda Odyssey brake lights don't work.
make sure u have put the right bulbs in. rear brake lamps are dual filament....
Posted on Apr 15, 2009
SOURCE: Can I put a 35 watt bulb into a Rangehood?
Yes it will possibly just be a little brighter... but should do no harm. The original 2 would equal 25 Watts the replacement 35 Watts.. the 5 Watts in neither here nor there.
Posted on Jan 31, 2010
Testimonial: "Thank you very helpful, and prompt"
Replace halogen bulb
Please see my answer at http://www.fixya.com/support/t9977585-sv168n_36_spagna. I suspect your problem is with a failed transformer, rather than the actual halogen fixtures.
Oct 29, 2013 | Euro-Kitchen SPAGNA VETRO 198D-36...
Dead Fan blower 2006 Kia Sportage has 12v power, should I replace it?
Could be your blower motor resistor,it's mounted next to the blower motor,Autozone will take part back for refund if it don't fix problem.Here's what it looks like,Here's where the blower motor is.Easy to remove,disconnect electrical connector,remove 2 screws,can't look at it to tell if bad.Here's the relay.
Dec 23, 2012 | 2006 Kia Sportage
Low beam right light not working and fuse is ok
sounds simple but check there is live at the bulb with a multimeter or 12v test light. should show round 12v. if not then it will be a wiring fault/broken circuit or bad earth. if there is then check the bulb connections and change try changing bulb even if you feel it may look ok. looks can be decieving
Apr 29, 2012 | 2003 Nissan Altima
No running lights checked fues head light switch all ok
If fuse and switch are all ok then try check the out put from the light plugs ( with a volt meter or another 12V light bulb), you might need new light bulbs.
Feb 12, 2010 | 2004 Ford F350
Jan 31, 2010 | Kitchen Ranges
All brake lights not working (already change light bulbs).
Did you check the fuse,#23 in JB center,this is hard wired to brake swicth, PK/BL should have 12v,if ok procede, wh/br will have 12v when brake is pushed on.if not replace the switch, jump the 2 wires and light sould come on, same feed goes to high mount lamps, does the info console warn of no lights, if you need more info, just ask. GOOD LUCK, RDJRP
Dec 25, 2009 | 2000 Jeep Grand Cherokee
Odometer Light
I have a 2005 Equinox and recently had the problem with the odometer bulb going out. Only the bulb needs to be replaced--NOT THE ENTIRE CLUSTER!! The process to remove and replace the bulb is a simple one. First tilt the steering wheel out of place, pull bezel straight out carefully, and with 7mm screw head remove the four mounting screws and pull cluster out. Disconnect cluster and remove burnt out bulb by giving it a counter clockwise quarter turn. Insert new bulb and turn it clockwise quarter turn. Plug in cluster again, insert the mounting screws, replace bezel. Very simple. The bulb replacement that I used was different than the original but has the same voltage and watts--the old one had a white base with frosted cover, while the new one had a beige base and clear--which made the new light brighter but very workable. I used 39118 Bulb 20210B24 DE66K2 12V 1.5w or this one should work: http://www.rmeuropean.com/Part-Number/Bulb-12V---15W-with-Beige-Socket-Base-for-Dashboard-Instruments-__62111391260_OSR_2439488A.aspx . I hope this helps..
Sep 01, 2009 | 2005 Chevrolet Equinox
Blower for ac/heat only work on lower 3 levels.
Check the blower motor resitor. Use a 12v test light at the switch and notice the bulb brightness change as you switch settings.. Probably have a bad blower resiter.
Jul 07, 2009 | Chevrolet Blazer Cars & Trucks
Vicking VIDV500 Kitchen Hood
steve...first, is the light working? If not, you may not have power. If so, turn off all power to the unit at the breaker. Remove the filter and see if the blower turns easily by hand. Yes...switch could be bad...no...motor bad.
Open up unit and using test light from the hardware store and motor plug disconnected...turn on fan and probe the motor feed wire for power. It may be the switch that's bad. This should tell you.
Dec 01, 2007 | Viking VEDV900 Kitchen Hood
Kitchen Ranges Logo
118 people viewed this question
Top Euro-Kitchen Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you an Euro-Kitchen Kitchen Range Expert? Answer questions, earn points and help others
