Can i replace logs? - Computers & Internet
  • 2,355 Answers
Yes
Posted on Nov 08, 2014
How do I replace bulbs on model DS5603 Mod G electric fireplace
Do you need to replace the upper or lower light bulbs?
For both, first open the door of the fireplace. For the upper light, locate the upper bulb bracket (above the door). Bend the bracket down. Unscrew the old bulb and replace it with 7 W clear chandelier or candelabra bulb with an E12 base. Bend the bracket back up to its original position. Close the door, if only the upper bulb is out.
You will need a Phillips blade screwdriver to replace lower bulbs. Open the door (if it wasn't already open). Locate the screw that holds the log set in the center of the ember bed. Remove that screw and the log set. Locate the bulbs that are behind the log set and determine if one or both bulbs need to be replaced. Unscrew the bulb(s) to be replaced. Screw in the replacement 60 W clear chandelier or candelabra bulb with the E12 base. Replace the log set and press firmly against the glass. Replace the screw that holds the log set. Close the fireplace door.
The procedure to replace the bulbs is on page 4 of the service manual. It is also on pages 10-11 of the Owner's Manual. The documentation is available from Dimplex: http://www.dimplex.com/en/customer_support/technical_and_troubleshooting . The direct link to the service manual is http://www.dimplex.com/cms/publications/7400650000R04.pdf . The Owner's manual is here: http://www.dimplex.com/cms/publications/7206570100R09.pdf .
I hope this helps.
Jan 12, 2017 | Heating & Cooling
I have a gas fireplace with logs that need replacing badly. I want to replace the logs with new ones. Company may have gone out of business.
Chances are you will not need to replace the logs with exact duplicates - the real concern when replacing gas logs is two-fold:
1. The electrical connection - most units use a standard 110v power source - usually connected to a single pole switch. The connection to the burner unit usually comes in the form of a small metal box with the power line from the switch connected inside, usually with 3 wires - black (hot), white (neutral), and bare or green (ground) - make sure any replacement unit is designed for 110v.
2. The gas connection - while this is something than can be done by the end consumer, the better bet is to have a HVAC professional disconnect the older unit and make the connection to the new one. The good news is that almost all gas units are designed to work with universal connectors, the bad news is that this connection needs to be completely free of defect or leaks, hence the recommendation for a HVAC pro.
Nov 20, 2014 | Home
I have mislaid the instructions for my Genesis Miami gas fire, and need to relay the ceramic logs. can anyone please help?
This will depend on whether the fireplace is vented or is vent-free. Vent-free gas fireplaces are sold as a kit with the valve, burner, media (logs, glass, shapes, etc) all designed for a particular placement to work together to reduce dangerous chemicals. A vent-free burner and valve cannot have the logs removed and replaced with some other type of ceramic gas log because the exact placement of the logs is designed around the ports in the burner where the flames rise to minimize carbon created from the flames touching the logs.
If your fireplace is vented then the pull of the flue will remove dangerous fumes created by the same placement so there are no rules about re-arranging or replacing "media". If the fireplace is vented then you could use other log-placement-guides to identify the type of log and where it belongs with little worry because vented logs are designed to be able to have some adjustment anyway.
If vent-free and without a manual, an educated technician should do this for you because the BTU setting on the valve must be compared to the types of burners, port placement, size of ports, amount of ports and flame height. After this examination, someone familiar with the various hidden "tongue-and-groove" etchings in different types of gas logs can figure-out where to place the logs. They may have to test the fireplace burning once or twice to get it exactly correct but once you understand the idea of how a vent-free gas log diminishes the carbon-output of the amount of gas flowing through the burners then it is only a matter of watching the flames to see where the logs could be and comparing the size and layout of the logs to find the best fit.
Feb 02, 2014 | Grilling
Adding hydrolic oil to yardworks 4-ton wood spliter
Replace the Hydraulic oil in the log splitter after
every 150 hours of use. Take following steps to
replace it.
  1. Make sure all moving parts stops and the log splitter is unplugged.
  2. Unscrew Oil Drain Bolt with Dipstick to remove it.
  3. Turn the log splitter on the Support Leg side over an 4 liters capacity container to drain the hydraulic oil off.
  4. Turn the log splitter on the the motor side.
  5. Refill fresh hydraulic oil at the volume as per the hydraulic oil capacity of a particular model indicated in above specifications table.
  6. Clean the surface of Dipstick on the Oil Drain Bolt and put it back into the oil tank while keep the log splitter vertically.
  7. Make sure the level of the refilled oil is just between 2 grooves around the Dipstick.
  8. Clean the Oil Drain Bolt before thread them back. Make sure they are tightened to avoid leakage before place the log splitter horizontally.
Periodically check oil level to ensure it is between
2 grooves around the Dipstick. Upon Lower oil
level, oil refilling is required.
Source:
http://www.qci.net/files/5_Ton_Log_Splitter_-_USE_THIS_MANUAL.pdf
Sep 22, 2013 | Hardware & Accessories
Blank screen
Check the cables are all connected properly. Replace the Ram.
Jun 09, 2013 | Intel Celeron M 420 1.6GHz 533MHz 1MB...
How do i change the bulb on my dimplex electric fire 930 3003.9
TO REPLACE LIGHT BULBS
1. Open the steel curtains (remove glass doors if applicable).
2. Remove the log grate retaining screws and remove the log grate.
3. Pull the rear edge of the log set forward by grasping the ember bed by the sides
(handle the log set only by the ember bed and not the logs) and pulling firmly
until the rear tab pops out from under the back ledge, then lift out.
4. Examine to determine which bulbs require replacement.
5. Unscrew bulb counter clockwise.
6. Insert new bulb screwing clockwise.
7. Replace the log set by inserting the front edge, pushing the back down until the
rear tab snaps under the back ledge and the logs are resting against the mirror.
Quantity 4 clear chandelier or candelabra bulbs with an E-12 (small) socket
base, 60 watt rating. Example GE 60BC or Philips 60CTC
CAUTION DO NOT EXCEED 60 WATTS PER BULB
Feb 23, 2011 | Heating & Cooling
I need replacement logs for a Desa Model CGFB32CA. No one lists the log numbers, including the manual. Where can I get the item number?
As you probably already know, DESA International is no longer in business. However, depending on the age of your unit, some parts are still available, as is the Owners Manual. The parts for Comfort Glow gas logs (which is what you have. And probably purchased them from Lowe's some years ago) are interchangeable with DESA's Vanguard line.
You can find what you're looking for at www.desatech.com. However, don't be shocked by the price of the replacement logs.
Feb 05, 2011 | Desa International Wall/Window Air...
Facebook won't log out of LG Xenon
that problem sounds like your phone. But you can call customer care for att and they will tell you weather you need to replace your phone.
Sep 05, 2009 | Samsung Instinct Cell Phone
Log & reciprocal functions
There is no log (base 10) button on a TI-89. It's buried in the CATALOG as log(. As a shortcut, you can do ln(#)/ln(base), where # and base are replaced with what you want. For the inverse of a log, do the base raised to the part on the other side of the equals sign. So, log(x) = 2 would become 10^2 = x.
Jul 16, 2008 | Texas Instruments TI-89 Calculator
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
