Question about Video Game Consoles & Games
Darksiders 2 Xbox 360.. my abilities (LB) stopped working. Not the bumper its self. But in the game. It doesn't register any more. Shut the game off and restarted the game and nothing. Tried starting a new game, it worked just fine. I really don't want to start all over.
PAeasop
  • 17 Answers
SOURCE: xbox 360 controller stopped working
I have the issue mostly when the batteries are about to die, Try changing the batteries, or if you are using a play and charge kit (sold seprately) connect it to your xbox 360 and one of the front usb ports. Or replace the rechargeable battery.
Posted on Apr 22, 2008
SOURCE: xbox 360 plays dvd but not games
you probably didn't flash the drive correctly. you can find guids how to online. its a pretty in depth process though.
Posted on May 24, 2008
sharkymo
  • 95 Answers
SOURCE: Xbox 360 won't read a certain game
If you have the original X box CD's it will work fine expect when you have issues with region code.PAL NTSC are the two format a game can work with.so if you have NTSC formated game TRY a PAL version.it may work.
else clean your lens and try inserting a new CD of that GAME.
Posted on Jun 12, 2009
  • 90 Answers
SOURCE: HOW TO TEST ETHERNET PORT ON XBOX 360
Try using a different hard drive
Posted on Aug 03, 2009
  • 441 Answers
SOURCE: xbox 360 not reading discs
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1. Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser. The laser is the part that actually reads the disc. The reality is... with all the hours and hours of gameplay, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3. Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything, including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock. The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
Posted on Nov 17, 2009
Darksiders cheat codes
I'm sorry to tell you but there are no cheat codes for Darksiders on the Xbox 360. However, you can look up online on how to mod your game saves to see if modding is something you'd be interested in so that you could cheat and give yourself as many Souls as you want. I recommend the program, "Modio," it's a nice save game modding platform that is easy to use and effective. I hope this helped! Like I said, do some research of your own to see if modding saves is something you'd like to do. Best of luck to you! :)
Aug 14, 2014 | Microsoft Xbox 360 Console
How do you reset all family settings on xbox 360
There are different codes for different 360 consoles and different dash versions:
1. On the 360 dashboard, scroll over to the "System" tab.
2. On the System tab, click "Console Settings".
3. Scroll down in console settings and click "System Info".
4. When the system info box comes up SCROLL TOP THE BOTTOM and type in this sequence:
LT RT X Y LB RB Y "Left Stick in" (press it in and hold it in) Y Y
A box should come up and say, "Would you like to reset the console to the factory defaults?"
Click Reset and you're done!
!!!HERE ARE MORE CODES THAT HAVE BEEN TESTED AND WORK!!!
LEFT TRIGGER, RIGHT TRIGGER, X, Y, LEFT BUMPER, RIGHT BUMPER (Do this twice)
LEFT TRIGGER, RIGHT TRIGGER, X, Y, LEFT BUMPER, RIGHT BUMPER, X, X, UP, DOWN, DOWN. Then down, down again.
Left Trigger, Right trigger, X, Y, Left Bumper, Right Bumper, DOWN (dpad), Y, Left, Left
Jun 22, 2014 | Microsoft Xbox 360 Console
How do you reset the family settings for xbox 360 dashboard 2.0.16747.0?
Reset Family Settings (Factory Reset) for Dashboard 2.0.16747.0
System -> Console Settings -> System Info (Press "A")
LEFT TRIGGER (LT), RIGHT TRIGGER (RT), X, Y, LEFT BUMPER (LB), RIGHT BUMPER (RB), Down, Down, Up, X,
Apr 23, 2014 | Video Game Consoles & Games
Xbox wont read brand new games
Check with xbox to see if there is a firmware upgrade for the player to cope with the later disks coming out.
Sep 07, 2017 | Microsoft Xbox 360 Console
I got a wireless controller for an x-box360. Made by Logitech. Can you verify that it for a 360, and not the original x-box? Seems to be missing some buttons.
If it has and LB and RB (left and right bumper) it is an xbox 360 conntroller. It could also be an xbox 360 for windows controller where it only works for a computer too. Hope this helps.
Jun 09, 2011 | Video Game Consoles & Games
My xbox 360 controller was working find when i started to play today, i was playing then all of a sudden when i went to press Left Bumper LB it wouldnt function, its not stuck and it still clicks.. i...
1-try rettting the game's control layout back to default...you might have changed the layout 2-is this problem happening in other games as well? if it does, then we can consider taking the controller for repair 3-there is always ebay and amazon to get you a new controller 4-do you have a wireless or usb adapter to connect the xbox controller to the pc? in windows 7 you can use the gamepad as a gamepad and in "callibration settings" you can test the buttons
go get those killstreaks!
Feb 18, 2011 | Microsoft Xbox 360 Controller
I'm playing Darksiders PC with wired XBOX 360 controller. I'm having problem where the screen kept zooming in and out automatically while playing. If I hold LT, this will stop. But once released, it...
If you are on windows 7 go to control panel and search for "game" one of the top results should be "Set up USB game controllers". Go there, select the 360 controller from the list, and hit properties. In the settings tab there should be the option to calibrate it, do so. That should stop the controller acting like you are pressing things when you aren't.
Oct 04, 2010 | Microsoft Xbox 360 Controller
Fallout 3 disc reading/load issues
Try going to your memory on your xbox highlight the hard drive and Press Y on the hard drive symbol and then press the following: X,X,Left Bumper, Right Bumper, X,X. then select yes this will clear any game updates they will have to be re-updated
Jan 27, 2010 | Bethesda Softworks Fallout 3 for Xbox 360
Xbox360
just went through this u need a new disc drive
Oct 23, 2008 | Microsoft Xbox 360 Console
Update Problem
restart your console and try again if that doesnt work your hard drive may have a crrupted file on it and in that case you need to call xbox customer support at 1-800-4myxbox
May 02, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
