Question about Dryers
Beco cond dryer DRSC 68 W When drying cycle ls on l hear an electric trip sound followed by a wire burning smell
  • 26 Answers
If you EVER smell that again, unplug, unload(dry or not, lives may be at risk), preform a thorough check and identify the smell. Then buy a replacement part and check ALL the wiring. Really I cannot stress just how dangerous this is. In my opinion a new dryer would be fine.
Posted on Nov 07, 2014
Beko drcs 68 w cond dryer 3 yrs old an electrical trip sound followed by a burning wire smell
It could very possibly be that some of the lint has migrated thru the cracks of the lint "tunnels" and settled down around the heating element. Danger Will Robinson! Learn how to remove the front cover/door or back side and inspect for loose lint. It is normally lots more accumulated than you could imagine.
Nov 07, 2014 | Dryers
Maytag Neptune Dryer with strong "burned electrical wiring" smell
Sounds like the motor went out. Before trying to start it it needs to be inspected. If you are not comfortable opening up the cabinet then I would would recommend calling a service tech. If you need further assistance please let me know.
Ken
Mar 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore 80 series electric dryer. metalic sound/burning smell
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
Kenmore dryer. Heats up intensely
Hi, It's an over heating motor that's cousing the thermal switch to trip, on the motor.
Motor retails for $150.
Labor for putting it in is $90.
It might just be worth replacing it.
Sorry for the bad news :(
Best of luck.
Sep 13, 2009 | Kenmore 64902 Electric Dryer
Dryer doesn't heat up
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 09, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
Wont dry
CHECK THE FOLLOWING---
2. Heating element
3. Thermal fuse
May 03, 2009 | Maytag Neptune MDE4000 Electric Dryer
GE Dryer smells like its burning
the burning smell may be caused by a belt some have a look at the belt
Mar 07, 2009 | GE Dryers
Gas dryer drum will not spin
the flint element might need to be replace...(pilot light) I had the same problem the dry had a burned smell...which meant that the element wasn't working properly and finally the drying wound't heat anymore
Jan 01, 2009 | Kenmore 98702 Stacked Washer/Dryer
No heat
If there is no heat during drying cycle, it is usually either the heating element, or a thermal fuse.
See the following suggestions from repairclinic:
If your dryer doesn't heat, check these:
Heating element
Thermal fuse
Wiring
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Oct 19, 2008 | Splendide 2000S Vented Washer/Dryer
Electric dryer internal short
Make sure that the dryer is disconnected from the wall outlet before doing any repairs on it. Electric dryer work on 240 volts AC and this could hurt or even kill you. loose connection on the terminal block will cause the wires to get hot. and melt the terminal block and wires and the pig tail wires. you will have to replace the terminal block and pig tail wires and make sure you use the correct bolts and make sure you tighen them. let me know if this helps.krazytech
Sep 09, 2007 | Magic Chef CYE4000AWW Electric Dryer
Dryers Logo
47 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
