Question about Dishwashers
AEG Favorit 44080i Dishwasher will not fill with water
Basically, the dishwasher was working fine up until a couple of weeks ago when it just will not fill with water; it drains fine having filled it with water manually and switched on, all the water gets drained away. I've replaced the aqua stop tube as I thought this was the problem as I could see the voltage being sent to the tube to open the valve (used multi-meter) but it did not let any water in. Same problem after buying & fitting a new aqua stop tube. I've now opened up the sides as well as the back and I cannot see any obvious reasons for the problem. The lights flash in so-called sequence 1 which is the water inlet fault.... Water is definitely coming out of the pipes to the aqua stop tube as I switched the tap on and happily got lots of water pouring out before I reconnected the tube and continued on.....
  • 26 Answers
Well, this was very long-winded. If it works when filled manually, then check the stopcock for the water flow and open it more if not all the way. If this does not work, try the water pump in the back/bottom of the disher
Posted on Nov 07, 2014
AEG Favorit 44090i Dishwasher will not fill with water
There may be a filter after the aquastop pipe which is blocked. This is usually at the back of the inlet valve. Also, the inlet valve may no longer work.
Nov 07, 2014 | Dishwashers
HI, First I hope you checked that someone has not turned the water off. next, you will find that the inlet of the water is operated by a solenoid valve. This has I would expect, stopped working. You will need to remove the power, then remove the top of the dishwasher. the inlet valve is where the cold water enters the dishwasher. You will need the make and model of the dishwasher, buy the new valve and replace the dead one. it will take longer for the new one to arrive than it will to change them over. Good luck
Aeg oko favorit 40300 service manual
AEG OKO FAVORIT 40300 When switching dishwasher on no water is flowing into the the dishwasher
Please help
Jan 11, 2012 | AEG Dishwashers
AEG Favorit Integrated Dishwasher failing to heat the water. has the element gone? and how do you get at it?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Mar 23, 2011 | AEG 23 in. Favorit 50750Vi Built-in...
The dishwasher will not heat up what could be the problem
heatman101
Nov 23, 2010 | AEG 24 in. Favorit 40850 Free-standing...
AEG Favorit 665i. Lower arm does not turn
im not sure about this if the upper arm is working ok,because the lower arm gets the pressure first then sends it to the upper arm,if the water pressure to the machine is ok then the lower arm is at fault take another look at the lower arm something is not right with the lower arm.adrian;;
Jan 22, 2010 | Dishwashers
Ikea Whirlpool integrated dishwasher door front
how do i take door off to fix handle back on dishwasher
Jan 03, 2010 | AEG 23 in. Favorit 50750Vi Built-in...
AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Dec 20, 2009 | AEG 24 in. Favorit 60830 Free-standing...
Aeg favorit 86070 vi fully integrated dishwasher started bleeping with 3 short bleeps 2 months ago. I followed instructions internet and shook dishwasher to one side and it worked for about 8 weeks. Now...
This is typical of the anti-flood circuit that opperates once it detects water on the base of the machiene and is a polystireen float that activates a micro switch. This puts the machiene in pump out mode only. You need to determine if the water at the base of machiene is caused by a small leak or is it a customer spillage. Clearing the water (tip to side) or dry with paper towel and inspect for leaks. Rectify the leak and this should solve the problem.
Sep 09, 2009 | AEG 23 in. Favorit 86070Vi Built-In...
Dishwashers Logo
112 people viewed this question
Top Dishwashers Experts
Owen Barnes
