Please help
HI, First I hope you checked that someone has not turned the water off. next, you will find that the inlet of the water is operated by a solenoid valve. This has I would expect, stopped working. You will need to remove the power, then remove the top of the dishwasher. the inlet valve is where the cold water enters the dishwasher. You will need the make and model of the dishwasher, buy the new valve and replace the dead one. it will take longer for the new one to arrive than it will to change them over. Good luck
SOURCE: water isnt draining
Check your drain line and/or drain pump. The drain line should have a high loop at the point prior to where it connects to your drainage system in order to prevent drain water from the kitchen sink from back flowing into the dishwasher. In addition, most drain pumps have a small check valve that prevents this water from backing up as well. However, if you have something lodged in the drain pump (i.e., a toothpick) it can prevent the check valve from closing properly. This can cause water to back up into the dishwasher. You mentioned that the water will not drain. Is the drain pumping runnings at all? Please post back and let me know.
SOURCE: Dishwasher will not fill up with water
check the following- remove the wires from the fill valve.close the door and start the unit.u should read 120 v as u start the unit.if u read 120v then fill valve is bad.if not then chk and make sure the float is sitting completely down and float sw is closed.the power to fill valve goes throug this sw.if all is ok and still there is no power then u may not be getting power from cntrl board and control board could be bad.but that rarely happens.turbidity sensor does not affect the fill operation.good luck.
SOURCE: Our Asko D3250 dishwasher is brand new, and it
this sounds like a improper install ! ck to see if the drain hose outlet is lower than bottm of tank. it should drain to the disposal . and have a drain loop under sink .. the dw prosser is sensing that the drain is longer in time so it flasher inlet fault . . elevate the drain and try again ..if it drains to a lower use a stand pipe or a siphon brake . in the install .. mm
Testimonial: "The drain is working. It fills but doesn't start the washing, just comes on with the fault light. Could it be a faulty control panel? Or ???. Thanks."
SOURCE: Bosch smu4096ud /14 dishwasher wont fill with water
Find out where the water is being stopped. Firstly at the wall. Then maybe at the solenoid (depending on the model) and then just trace the water line until you find out where it's being stopped.
Also I would recommend you run some nickel safe ice machine cleaner through the system to get rid of the 'white junk'.
