Question about Lexmark X543dn All-In-One Laser Printer
There is a yellow edge on downside of paper when sent printing on the Lexmark x543. I have already tried changing the yellow ink cartridge. I have also printed the settings and the fuser, imaging ki
There is a yellow edge on downside of paper when sent printing on the Lexmark x543. I have already tried changing the yellow ink cartridge. I have also printed the settings and the fuser, imaging kit, ITU, and waste toner box all say ok. Can you tell me how to eliminate the yellow edge please?
  • Lexmark Master
  • 1,915 Answers
If it is pure yellow I would look at the yellow imaging unit (drum) to make sure that it is ok. That is likely the culprit if changing the toner did not resolve the problem.
Posted on Nov 09, 2014
5 Suggested Answers
  • 25 Answers
SOURCE: Lexmark E320
I am afraid to say that the fuser lamp has burned out this is replaceable part if you go to the link provided and go to parts you can get diagrams and the part # and ordering info from Lexmark
http://www.lexmark.com/lexmark/site/home/0,6932,204816596_0_0_en,00.html
best luck
Posted on Aug 28, 2008
  • 990 Answers
SOURCE: c782: vertical lines showing up on printed media.
Hello sir; I believed the vertical lines coming out from your drum cartridge, replace it !
Posted on Feb 02, 2010
Printtech
  • 1087 Answers
SOURCE: TONER LIGHT STAYS ON WITH NEW TONER CARTRIDGE
If the main problem is just the toner light on then what you could do after installing the new toner is resetting the printer. You could do that by powering the printer off, open the front cover (as if you were to replace the toner) with the front cover open and the printer off push and hold the two buttons on the printer and turn the printer on while holding down the buttons then once the bottom light stays on solid, release the two buttons and that should reset the printer.
Now if the toner light is blinking that means that you have reached the 30,000 page mark and the Photoconductor needs to be replaced. If that is not the case you can follow this link to a procedure where it will explain how to reset the Photoconductor. http://bit.ly/91SWS3
Posted on Mar 19, 2010
Ricky8
  • 337 Answers
SOURCE: I have a Lexmark x543 printer and when I print a
try to print a test page .. if u get the lining there then its a problem with the printer drum .. u might need to get it replaced .. if not then its an issue with the settings .. you can also try to reinstall the drivers in that case.,
Posted on Oct 21, 2010
Black ink on edge of paper
You may try to clean the rollers using a slightly damped paper towel.
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 5100 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Jan 23, 2012 | Lexmark X5150 All-In-One InkJet Printer
How do you change the ink cartridge on a lexmark x543 printer
See the manufacturer's web-site:
http://support.lexmark.com/index?segment=SUPPORT&userlocale=EN_CA&locale=en&productCode=LEXMARK_X5435&page=product&frompage=null#1
for the 'X5435' (not the 'X543') printer, and select to download the "manual", which tells you how to maintain your printer.
May 12, 2011 | Lexmark X543dn Laser Color All-In-One...
How do I change the ink cartridge in a Lexmark x2330
  • Turn the Lexmark printer on by pressing the power button. Usually, the power button is located on top of the Lexmark printer. If the Lexmark printer does not power on immediately, then hold the button down for a few seconds before releasing it. Once the Lexmark printer has powered on, the installed cartridges will begin to move back and forth for a few minutes.
  • 2
    Raise the Lexmark printer cover up towards you. Doing this will give you instant access to the inside components of the Lexmark printer. Lift the cartridge release lever and remove any installed ink cartridges. Be careful when doing this because the ink may leak out. It's best to have a disposable bag or paper towel near you when performing these steps.
  • 3
    Remove the plastic from the brand new cartridges by carefully cutting them open with scissors or tearing along the perforated edges. Once you have removed the plastic, there's a yellow tag located near the bottom of the ink cartridge. Take this tag off only when you're ready to insert the ink cartridges into the slots.
  • 4
    Tear the yellow tag from the ink cartridges and place them into their corresponding slots. Each one will be easily identified by its color. The cartridge release lever will have the same color as the ink cartridge. If you mistakenly place the cartridges in the wrong slot, then you'll risk having your Lexmark printer stop working properly.
  • 5
    Press the ink cartridges into the slots and listen for a clicking noise after the insertion. Although you will need to firmly place the ink cartridges into the available slots, it still needs to be done gently. Close the Lexmark printer cover when you've completed the previous steps. Wait a few minutes for the Lexmark printer to recognize that you have inserted brand new ink cartridges. After a few seconds, it will go through some diagnostic steps to make sure the ink cartridges were correctly inserted.
  • 6
    Print a test page on your Lexmark printer. This will help you to determine if the ink cartridges are properly working. You can view the newly printed images and text after the Lexmark printer has finished printing. Get rid of your used ink cartridges by throwing them away or sending them to an online store that accepts empty ink cartridges.
  • Jan 17, 2011 | Lexmark X2330 Printer
    MY LEXMARK 4505 LEAVES 3-4 BLACK BLOTCHES ON THE EDGE OF EACH PAPER IT PRINTS, TRIED CLEANING THE ROLLERS TO NO AVAIL, ANY SUGESTIONS
    ADJUST THE COLOR AND PRINT SPEED You may need to adjust the color and print speed. CHECK THE LEVEL OF INK IN THE PRINT CARTRIDGES 1 From the Finder desktop, double-click the Lexmark X5400 Series folder. 2 Double-click the Lexmark X5400 Series Utility icon. 3 From the Maintenance tab, check the ink levels of the cartridges. If an exclamation point (!) appears on a cartridge, the ink level is low. Install a new cartridge. Improving print quality These are possible solutions. Try one or more of the following: CHECK PAPER • Use the appropriate paper for the document. If you are printing photos or other high-quality images, for best results use Lexmark Photo Paper or Lexmark PerfectFinish Photo Paper. Do not use Lexmark Premium Photo Paper. Your print cartridges are not compatible with this type of paper. • Use a paper that is a heavier weight or bright white. CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" on and "Installing print cartridges" . If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts". If print quality is still not satisfactory, replace the print cartridges. For more information, see "Ordering print cartridges". CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page 124. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" and "Installing print cartridges" If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts"
    Nov 10, 2010 | Lexmark X5495 All-in-One &USB...
    The colour is not printing anywhere near the same as the image, its very yellow I have done the cleaning and the test print shows the blue to be very pale and I have tried 3 new ink cartridges, I did print...
    Great job on cleaning the cartridges and even trying 3 new ink cartridges. Pretty much you did the basic troubleshooting already. This looks like a hardware problem but I strongly suggest you contact Lexmark technical support to further investigate the problem. Thanks.
    Aug 12, 2010 | Lexmark X1270 All-In-One InkJet Printer
    A Lexmark E250dn in my school does not print. There is a new ink cartridge in it and it "talks" to the computer but does not show what was sent to print. The motors runs paper through it, but the paper...
    This likely to be a faulty cartridge.
    There are a number of things that can result in blank pages, but if the cartridge has just been changed (and the old one was fine apart from being 'empty'), you should be talking to your supplier.
    Apr 23, 2010 | Lexmark E250dn Laser Printer
    Need to change the ink cartridge on lexmark model #x2350
    1- Turn the printer on by pressing the power button. Usually, the power button is located on top of the Lexmark printer. If the Lexmark printer does not power on immediately, then hold the button down for a few seconds before releasing it. Once the Lexmark printer has powered on, the installed cartridges will begin to move back and forth for a few minutes.
    2- Raise the Lexmark printer cover up towards you. Doing this will give you instant access to the inside components of the Lexmark printer. Lift the cartridge release lever and remove any installed ink cartridges. Be careful when doing this because the ink may leak out. It's best to have a disposable bag or paper towel near you when performing these steps 3- Remove the plastic from the brand new cartridges by carefully cutting them open with scissors or tearing along the perforated edges. Once you have removed the plastic, there's a yellow tag located near the bottom of the ink cartridge. Take this tag off only when you're ready to insert the ink cartridges into the slots.
    4- Tear the yellow tag from the ink cartridges and place them into their corresponding slots. Each one will be easily identified by its color. The cartridge release lever will have the same color as the ink cartridge. If you mistakenly place the cartridges in the wrong slot, then you'll risk having your Lexmark printer stop working properly.
    5- Press the ink cartridges into the slots and listen for a clicking noise after the insertion. Although you will need to firmly place the ink cartridges into the available slots, it still needs to be done gently. Close the Lexmark printer cover when you’ve completed the previous steps. Wait a few minutes for the Lexmark printer to recognize that you have inserted brand new ink cartridges. After a few seconds, it will go through some diagnostic steps to make sure the ink cartridges were correctly inserted.
    6- Print a test page on your Lexmark printer. This will help you to determine if the ink cartridges are properly working. You can view the newly printed images and text after the Lexmark printer has finished printing. Get rid of your used ink cartridges by throwing them away or sending them to an online store that accepts empty ink cartridges.
    Nov 27, 2008 | Lexmark Office Equipment & Supplies
    Pictures coming out yellow
    The "Print Head" needs cleaning or replacement. It's the part that delivers the ink from the cartridge tank to the paper itself.Mostly caused by air entering the lines and making any residual ink cure.
    Most newer printers only ever use 95% of the available ink before reporting tank is empty,and will not allow any printing to resume, preventing air being introduced to empty lines in the head.
    Without Removing Anything
    There's commercial products available, I guess a bit like using a head cleaning cassette in your VCR - I Have not tried any of these yet.
    Use an empty ink cartridge Refilled with hot water and run the print head cleaning function.
    ( Dont worry , The paper will absorb the minute amount of water being dispersed.)
    If that fails you should remove the print head cartridge most are pretty easy ,
    LexMark X1150 X1185 and other similar models with the sensor strip running through the cartridge instructions are located at the following FixYA topic
    http://www.fixya.com/support/t181337-piece_fallen_out_printer
    Immerse it in warm-to hot water for a while or try using rubbing alcohol or similar Non-solvent based liquid.
    Inspect the small rectangle shaped metal print head & surrounding copper track for dried ink , remove any with very gentle wiping taking care not to damage anything.
    If it's beyond cleaning it will have to be replaced .Try ebay or the local print shop.
    May 12, 2008 | Lexmark X1150 All-In-One InkJet Printer
    Lexmark X543dn All-In-One Laser Printer Logo
    239 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Roopesh S
    Roopesh S
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
