Question about Dryers
Trying to fit a dryer belt on a trinity bendix tm220w but it has plenty of slack - Double checked it the correct belt for this model
The previous one had snapped
  • 2,411 Answers
Is there a belt tightener you missed when you installed the new belt.
Check and see if there is one that fell down out of sight . Should have a spring on it if there is one.
Posted on Nov 08, 2014
  • 417 Answers
SOURCE: Zanussi Tumble dryer belt replacement
Yes, that sounds about right.
Posted on Oct 11, 2008
jsrock516
  • 5911 Answers
SOURCE: Need routing diagram of dryer belt on maytag dryer D7600
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, locate the "Dryer Belt Diagrams" link under the "Special Features" section. Scroll down to Maytag. The dryer belt diagram for Maytag should be listed as diagram E. I hope this helps you.
Posted on Jan 28, 2009
  • 2468 Answers
SOURCE: New Maytag dryer belt too loose
is the idler pulley have enough tension on it,the tensioner on these can get bad and not put enough tension on the belt,push on it,it should take some force to move it,if you can get your fingers under the belt around the drum without much effort then replace the idler pulley and tensioner
Posted on Feb 01, 2010
SOURCE: Replace a belt on a Tricity Bendix TM 320 W Tumble Dryer
1. remove top plastic panel (retaining screws are at back)
2. locate metal brace (12 incles long and 1/2 inch wide) on top of the cabinet (in mine it is on right edge)
3. unscrew retaining small bolts (there is one a few inches below on the inside of the cabinet too).
4. Repeat for left side.
5. push the back and front halves of the cabinet away from each other
6. slide the new belt around the front of the drum
7. reassemble
8. if you need to tension the belt wrap 10-20 turns of insulation tape around the idler pulley
Posted on Feb 09, 2010
  • 2509 Answers
SOURCE: Fit belt on Tricity Bendix TM 220 W Tumble
Check the belt routing over the idlers near the motor, there is a spring tensioner, also make sure idlers are smoothly rotating and not seized.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Posted on Feb 24, 2011
How to fit belt on a tricity bendix tm310w tumble dryer
round the pulley then around the tensioner then around the drum.
Jun 08, 2014 | Tricity Bendix TM310W Electric Dryer
Trying to replace the drive belt on my 1994 f150. I bought the right size belt but it will not quite fit. I have been pulling the tensioner counter clockwise to create as much slack as possible and the...
double check that you are going around the correct side of each pully,
rule of thumb the belt has a front "grooved" side and a back "flat" side the pullys will be set up the same, (flat with flat, groved with grooved)
Jan 17, 2014 | 1994 Ford F150 Styleside Supercab
My drum on my dryer is not yurning but all else seems to be working fine i have given the drum a push it then turns but when it stipos it will not move again
the belt could be bad or the moter if its the moter u will probably hear humming but the only way to really find out is to take the dryer apart to get to the moter and look at the belt
Jan 24, 2012 | Tricity Bendix TM220W Electric Dryer
How do I replace belt
the best thing to do is look it up on the manual, or searching it on youtube.
Aug 05, 2011 | Tricity Bendix TM220W Electric Dryer
My dryer s motor runs and heats up but does not turn, I have looked for a belt but cannot see one
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 18, 2011 | Tricity Bendix TM220W Electric Dryer
Manual for bendix consorte DN550
Belt & Pulley drawing for Tricity Bendix TM220W Dryer
May 03, 2010 | Tricity Bendix Dryers
Dryer not heating up enough
it is probably one of 2 things.Either the heating element is going out or the high temp sensor is bad. You can have these checked or if your a do it yourself type- all you need is an olm meter to check them out.
Nov 22, 2009 | Tricity Bendix TM220W Electric Dryer
Broken obsolete spring
Check at a old fashioned hardware store (not big box) or aimilar auto parts and supply place. ACE near you?
Sep 29, 2009 | Tricity Bendix TM220W Electric Dryer
Dryers Logo
53 people viewed this question
Top Dryers Experts
