Question about Fujitsu 12RLS Wall Ductless Air Conditioner Heat Pump 25 SEER 12,000
Ticking Noise in my Fujitsu Mini Split Indoor Unit
The inside unit makes a rapid ticking noise probably coming from the fan blades nicking the housing inside the unit. Banging on the outside temporarily stops the noise. I tried to get the cover off to see if I can tell where the noise is coming from but after removing all the screws, I can't get the cover off. Any suggestions other than calling a contractor? Thanks
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
Does the ac continue to make the noise even in fan only mode or is only in cooling mode. If only in cooling then it could be a gas related problem or blocked coil.
Posted on Nov 08, 2014
Testimonial: "It makes the same noise even when in fan only mode. I'm thinking it is the fan fins slightly touching the fan housing as it rotates. Problem is I can't get the cover off to see if I can get into that area to check out the cause."
SOURCE: NEED SERVICE MANUAL FOR FUJITSU SPLIT SYSTEM
try, http://www.uelements.com/downloads/Fj-aby14rga-sm.pdf
Posted on Jan 07, 2009
  • 81 Answers
SOURCE: How to remove cover on fujitsu split system head
The front cover can be dismantled (taken off as one Piece) by unscrewing the screws at the bottom of the air outlet (they are covered by screw cvers which will need to be taken off. Then just pull off the cover. PLEASE NOTE that the front panel (liftable to take out filters) will need to be removed lift up until 90 degrees and then pull off gentley and also take out filters before removing front cover
I take the time to answer you questions so please rate me
Thankyou
Mat
Posted on Aug 29, 2009
  • 3 Answers
SOURCE: fujitsu heat pump noise
i would check the blades on the condenser fan motor and make sure they are not hitting anything if they are not, spin the fan see if the fan spin freely, it should, if it doesn't it could be the bearing in the motor are dry and going bad
Posted on Jan 24, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
Posted on Jun 01, 2009
  • 10 Answers
SOURCE: How do I remove front cover of Fujitsu indoor unit
THE INTAKE GRILLE REMOVAL
(1) Open the intake grille.
(2) Pull down the knob.
(3) Lift the intake grille upward, until the axle at the top of the intake
grille is removed.
THE FRONT PANEL REMOVAL
(1) Remove intake grille (Reference the intake grille removal.)
(2) Remove four screws.
(3) The thumb is hung on the lower part as shown in the figure,
and it pulls to the front, pushing [-] mark , and bottom hooks
(two position) is removed from wall hook bracket.
(4) The front panel bottom is pulled to the front, and bottom hooks
is removed indoor unit.
(5) The front panel is pulled to the front, raising the upper surface,
and a front panel is removed.
Posted on Jul 15, 2010
In winter the outside unit sounds like a rubbing/ticking noise
Sounds like ice coming of the coil. That would explain the ticking. The rubbing could be ice buildup before the defrost cycle or it's building on the blades of the fan throwing it of balance a bit.
Feb 13, 2015 | Fujitsu Halcyon ASU12RMLQ Mini Split Wall...
Mr slim ticking noise
Open it and take a look, it could be debris or a loose wire.
Dec 06, 2013 | Mitsubishi Heating & Cooling
Fujitsu fi-6140 scanner making ticking noises during scanning
The tick tick noise is produced when the gears in the ADF upper unit is worn off. You are recommended to contact a Fujitsu expert for replacement of the faulty gears.
Thanks,
ScanCare
Jan 25, 2012 | Fujitsu FI-6140 Flatbed Scanner
Fan noise indoor unit (asu12rlq) fujitsu
A high pitched noise from the fan unit, means a bearing issue from the motor. You must replace the fan motor to get rid of the noise.
Dec 17, 2011 | Fujitsu 24R1 Air Conditioner
There is no picture and there is a tick tick ticking noise coming from inside the TV
The ticdk tick sound is probably the switched mode power supply making noise due to the fact that there is a shorted component inside(may be the horiz. output transistor). You may need to have service personell look at unit and get an estimate...this is older set n may not be worth repair
Jan 14, 2011 | Panasonic PT-51HX40 51" Rear Projection...
Ticking noise
HI, This is the result of a damaged Power control board. This board is not regulating the incoming current correctly. This board should be replaced, immediately. This will cause the in-house circuit breaker to blow. The board is located behind a access panel, on the rear of the unit. Have it replaced, soon.
It may be mounted on the compressor platform, as well.
Dec 22, 2009 | GE GDS20KBS Bottom Freezer Refrigerator
Fujitsu Air Conditioning split unit Model
Your compressor is seized up. shut down unit and let compressor cool down, it may start again but probably needs to be replaced.... sorry for the bad news,
Nov 10, 2009 | Fujitsu 24C1 Air Conditioner
Fujitsu heat pump noise
Jan 22, 2009 | Fujitsu 24C1 Air Conditioner
Aou18c1 not shutting off
Fujitsu, Mitsubishi, Sanyo mini-split indoor fan motors operate continuoulsy. The room-temperature sensor is inside the unit, so the fan motor needs to circulate air continuouly to sense room-air temperature. This is normal operation.
Sep 12, 2008 | Fujitsu 18C1 Air Conditioner
Fujitsu 12RLS Wall Ductless Air Conditioner Heat Pump 25 SEER 12,000 Logo
964 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
