Turned toshiba C55t-A off last nite turned it on this morning, it says configuring windows updates, i waited several hours, now says update failed reverting changes. But wont stop doing only that. Took off battery, tried F8 ay turn on but it done nothing. Help
    New Friend:
    Problem Solver:
  • 7 Answers
In most cases if you are running Windows 8 you have to reinstall the system again. Try to learn to select updates manually cause not all Automatic Updates are needed for personal computer use.
Posted on Nov 08, 2014
CosmaP
  • 409 Answers
SOURCE: HP Pavilion dv7-1240us does not restart
Press and hold the power key. It should shut down (or just pull the power).
Restart the PC and do not press the escape key
Posted on Jul 24, 2009
leecom72
  • 4806 Answers
SOURCE: cannot start up the laptop
Hi there.
That really quick flash of a blue screen is the blue screen of death and there is a possibility that the error could be memory related.
What you have to do is remove and clean the system memory and the slots the memory goes into.
Take out the battery and the AC power (if attached)
The memory will be located behind a panel underneath the laptop, unscrew the panel unclip the memory, clean the brass contacts and the slots with a clean, dry, soft paintbrush, then reseat the memory making sure it clips into place, replace the memory cover and reboot the laptop, see if it lets you into windows.
Please post back with the results and more help if needed, good luck and thanks for using FixYa!!
Posted on May 20, 2009
gsage
  • 180 Answers
SOURCE: hp laptop 9720us screen wont brighten or dim. last
You got the wrong inverter fitted - i'm sure your unit requires a sinle lamp inverter and they have cheated - putting in a generic lamp inverter and branching togeather the wires to accomodate the single plug thus reducing the available volatage for the lamps - this is why it's dim - correct part is 431391-001 Display panel power inverter - For use with single lamp display panel
Posted on Aug 08, 2009
  • 154 Answers
SOURCE: screen dim HP pavilion dv1000
The lid actuator switch may not be working correctly. It's a small switch above the keyboard and led's on either the right or left side. Try pressing it 2 or 3 times to see if the display starts working correctly again. If so, it will need to be replaced.
If that doesn't work, you can also turn it on with the ac adapter plugged in. After it boots, press the power button and hold it in until it shuts off and then turn it on again and see if the display has returned to normal.
If neither of these options work, your laptop may need to have the backlight replaced.
Posted on Aug 13, 2009
  • 33 Answers
SOURCE: Updates not configured correctly Reverting
uninstall the updates : if you are using vista then go to contolpanel, click on programs, and then programs and features, and on the right hand side panel you would find view installed updates, select all of them or those which you know are causing the problem , and uninstall them , and also go to windows update in the control panel and then click on change settings and then click on check for updates but let me choose whether to download and install them..
Posted on Dec 19, 2009
Asus x553 has been showing configuring windows features 100% complete don't turn off your computer message for 24 hours
Hi
This sometimes happens when updates are not successfully downloaded or installed. I know it says don't turn it off, but this is the only way you'll get it back. Hold the power button down for at least 5 seconds until the power goes off. Wait a minute or two and start the machine up. Upon boot you will probably get a screen asking if you want to start the machine normally, in safe mode and several other options. Try start Windows normally first, and if this doesn't work, Last Known Good Configuration. If this fails as well then you will probably need to go into safe mode and uninstall some of the latest updates.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Jan 01, 2015 | Computers & Internet
Got toshiba sat C55t-A, yesterday. Turned it off last nite, turned on this morning it says configuring windows update. After long while it says ipdatte failed. Now wont shut down or respond to even F8 on...
follow the steps supplied below from your manual.
To recover the original factory image using the utilities on your computer's internal storage drive:
1Make sure the computer is turned off.
2Press and hold the 0 (zero) key on your keyboard while powering on the computer.
3If your system offers a choice of Windows® 7 32-bit or 64-bit
operating system, select one at this time. If not, skip to step 4.
4A warning screen appears, stating that when the recovery is
executed all data will be deleted and rewritten. Click
Yes to continue.
5When the Toshiba Recovery Wizard opens and the Selecting a
process screen displays, select
Recovery of Factory Default Software and then click Next.
6The Recovery of Factory Default Software screen appears.
Select
Recover to out-of-box state.
7 Click Next.
A confirmation message displays reminding you that all data
will be lost during the recovery process.
8Click Next to begin the recovery.
When the process is complete, a message displays indicating
that the internal storage drive has been recovered.
9Press any key on the keyboard to restart the computer.
Nov 07, 2014 | Computers & Internet
Windows update
contact Microsoft support. A support technician will work through the problem with you.
Jun 11, 2014 | Microsoft Windows 8.1 64-Bit - System...
Updates fail to download
Nasty! I would try going to Start>Restart> OK Your computer is not actually turned off then. When it starts booting up again, tap the f8 key continually until you get a screen of text. Select start in Safe Mode and see if it boots up in Safe Mode. Then try and go on line and download the updates again.
If all that fails you will have to close down your computer and switch off. Wait 15 secs, cross your fingers and start up again!
Feb 23, 2014 | Computers & Internet
Toshiba c55t-a5222 bios update, after reboot no screen
Did it at anytime lose power during updating? If so, motherboard was damaged and needs replaced. Otherwise, try to boot into'Safe Mode with Networking' and if it turns on, immediately re-install your graphics (video) driver. See this link for instructions on booting in to safe mode on a Toshiba: http://forums.toshiba.com/t5/Windows-7-Knowledge-Base/How-To-Start-your-Windows-7-computer-in-Safe-Mode/ta-p/272525
Feb 01, 2014 | Computers & Internet
Toshiba laptop stuck on Microsoft Corportation screen
not to sure how that can be fix for its very important to have the updates done for it updates the system and it is required to let the process finish. Take your computer to a shop and they will be able to help u but do not ask how much it would cost. :)
Feb 19, 2012 | Toshiba Satellite L305-S5933 Notebook
Toshiba laptop frozen pointer mouse
  • If you're having problems with Windows Update, make sure you're connected to the Internet, and then download and run the Windows Update Troubleshooter for your version of Windows.
  • Download troubleshooter for Windows 10
  • Download troubleshooter for Windows 7 and Windows 8
  • After the troubleshooter finishes, try running Windows Update again and install any available updates.
  • Or,
  • https://support.microsoft.com/en-us/help/947821/fix-windows-update-errors-by-using-the-dism-or-system-update-readiness-tool
  • Mar 15, 2017 | Computers & Internet
    My windows vista won't open
    If it does this after re-booting the computer then something got corrupted when it was updating. You could try pressing F8 when the computer is first booting up(right before window starts). This will bring up a menu. Choose the option to run the last known good configuration and see if that gets windows working again. You might need to choose a restoration point to get windows working. If you get it working and then the windows update tries to install the updates again hopefully they will work this time. If it happens again then make sure to cancel those updates and contact Microsoft with the software issue.
    Nov 18, 2009 | Microsoft Windows Vista Ultimate Edition
    What,s the deal with windows updates in Windows XP,i have a dell laptop with XP home edition.How shoul'd i configure automatic updates,does it need to be turned on automatic download and update 24/7,or...
    What I'd do personally. If you have a broadband connection. Just enable the update program to update during the early hours of the morning. Say somewhere between 1AM and 6AM. This can be set so windows will automatically download, install, and configure the updates for your system. Remember, for it to be able to do this; the computer must be on.
    This way it won't be a hinder to your every day internet usage, and it will do it's business while you're not using the computer. I have mine set up the same way and it's really nice. A simple reboot on some mornings is all I ever have to worry about and my PC is always up to date.
    Sep 11, 2008 | Sharp Computers & Internet
    Firmware update failed RD-XS34Su
    If it was a toshiba supplied disk, then I should follow up with them with the failure, as it was their fix, that caused this problem, they should replace/repair this unit for you
    Oct 15, 2007 | Toshiba RD-XS34 DVD Player/HDD Recorder
    Computers & Internet Logo
    69 people viewed this question
    David Payne
    David Payne
