Computers & Internet Logo
Eugenia Norrell Posted on Nov 07, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Got toshiba sat C55t-A, yesterday. Turned it off last nite, turned on this morning it says configuring windows update. After long while it says ipdatte failed. Now wont shut down or respond to even F8 on startup. Help
dhupp01
Level 2:
New Friend:
  • Expert 69 Answers
  • Posted on Nov 07, 2014
dhupp01
Expert
Level 2:
New Friend:
Answers
69
Questions
Helped
11343
Points
194
Follow the steps supplied below from your manual.
To recover the original factory image using the utilities on your computer's internal storage drive:
1Make sure the computer is turned off.
2Press and hold the 0 (zero) key on your keyboard while powering on the computer.
3If your system offers a choice of Windows® 7 32-bit or 64-bit
operating system, select one at this time. If not, skip to step 4.
4A warning screen appears, stating that when the recovery is
executed all data will be deleted and rewritten. Click
Yes to continue.
5When the Toshiba Recovery Wizard opens and the Selecting a
process screen displays, select
Recovery of Factory Default Software and then click Next.
6The Recovery of Factory Default Software screen appears.
Select
Recover to out-of-box state.
7 Click Next.
A confirmation message displays reminding you that all data
will be lost during the recovery process.
8Click Next to begin the recovery.
When the process is complete, a message displays indicating
that the internal storage drive has been recovered.
9Press any key on the keyboard to restart the computer.
I have a Toshiba c555t,on Windows 10. After updating, it shut down & wont restart and load. It has a message across the bottom.. "Prepairing Automatic Repair". What can I do to get it back to normal?
according to the maker there is no C555t
a c55t-1234 (note the vast submodels not stated by you....1233 is m fact sub number what is yours?
but is kinda off topic but gee, wrong model stated out of the gate.
Ok what update is running, we cant see your screen
1: tell all words on screen and logo's
2: post photo of failing screen
sorry we can not guess WHAT is updating
good luck. for sure.
Turned toshiba C55t-A off last nite turned it on this morning, it says configuring windows updates, i waited several hours, now says update failed reverting changes. But wont stop doing only that. Took...
In most cases if you are running Windows 8 you have to reinstall the system again. Try to learn to select updates manually cause not all Automatic Updates are needed for personal computer use.
Windows update
contact Microsoft support. A support technician will work through the problem with you.
Toshiba c55t replace keyboard
https://www.youtube.com/watch?v=F62RbnA06Fo
Toshiba c55t-a5222 bios update, after reboot no screen
Did it at anytime lose power during updating? If so, motherboard was damaged and needs replaced. Otherwise, try to boot into'Safe Mode with Networking' and if it turns on, immediately re-install your graphics (video) driver. See this link for instructions on booting in to safe mode on a Toshiba: http://forums.toshiba.com/t5/Windows-7-Knowledge-Base/How-To-Start-your-Windows-7-computer-in-Safe-Mode/ta-p/272525
When I turned my ps2 on this morning my memory
the system might have fell get something to holld the card up
Screen turn to white & cant recovery the system
I would reinstall windows sounds like the update corrupted it.
2helpful
Thankyou for your help ive took the back right off and theres 3 lamps red green and white, i bought this samsung 42in rear projection 2nd hand it worked absolutely fine the first nite i got it then...
Cheryl at a guess i would say that was why it was sold. It has an intermittant control board fault.
Now these often extend beyond just the one board ( there are 3) Opening the TV up is a risk to you as not only does it have scatter radiation type X but it is the HIGH TENSION area where severe burns and electrocution is the risk. Call a professional to fix it. We have people on here all the time trying to do this on the cheap, not many suceed as often they think that just swapping the boards out will fix it. Rare! Most times it ends up costing 3 times as much because they dont have the knowledge, essential tools or the skill to tune it properley and they end up fritzing the board again or blowing the expensive lamp.
Thanks for using FIXYA Please rate oure help to keep the FREE service online++++
Will not power on
First try disconnecting ALL power to the laptop - not just at switching off at the wall but pull the plug and remove the battery as well. leave it for 30 seconds or so and put it all back and try again.
If no luck then press F8 on boot until the boot options screen appears and select 'Last Known Configuration'
If no luck then is this XP or Vista?
Sony ericsson w910i
remove Battery and then try again
Oct 05, 2008 • Cell Phones
Grand Canyon Tech
Grand Canyon Tech
