SOURCE: turn off beeping alarm when the coffee maker is done brewing
you can't ,its up in the top behind the controls.
you have to take the pot totally apart.
only a trained tech should attempt this.
SOURCE: GE 169164 coffee maker problem
*** HOW TO RESET THE GE 169164 COFFEE MAKER ***
After endless online searches yielding the same results (nothing useful), I figured out how to reset this coffee maker.
While coffee maker is plugged in and the evil little blue light is mocking you relentlessly, press and hold the 1-4 button and the TSB button simultaneously for 3 seconds or so. This will cause the device to exit it's error status and allow normal use of it.
SOURCE: how do i use cleaning cycle on ge self cleaning coffee pot
You can find the instructions in this pdf file the link is http://www.gehousewares.com/products/200836153329360.pdf
SOURCE: self clean light keeps blinking
Hello guindonlm,
I recently had this similar problem. Try the following.
Your described problem may be one of two problems. Let's start with
the easier solution first. In the DCC 1200 there is a filter "stick or
column" in the left rear. Pull it out and remove the clogged carbon
filter(s) that are in there. Shine a light into the receptacle and
remove the debris in the bottom. It is likely that this is causing the
problem with you machine needing to be started on multiple times. See
if this solution works. If it does, you might run 8 cups of water and
4 cups of vinegar through to help decalcify the units plumbing. Do this
once or twice and then rinse with at least one pot run-through of
clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following:
unplug the unit and lay it on its back. You will need a #10 torx
driver (hardware store if you don't have one) to remove the bottom
cover plate. There are 4 torx screws holding it on. When removed, you
will find 2 orange hoses. Carefully attempt to remove the left hose
without splitting. I used a eyeglas screwdriver to loosen it up. If
it splits, just cut off the split and stretch it to reconnect when time
comes. As you look into the hose you will find a little black valve
inside as well a some gunk. Clean it all out with a fine wire as best
you can. Rinse well. Attempt to reconnect the hose back onto the
pipe. Slip the pipe clamp back into place. Replace the cover and
screws and you should be good to go again. This is not as daunting as
it may seem. You can do it. :o) Good luck! If this answer helps,
please leave positive feedback for me. Much appreciated. Regards,
NormanZ
