Question about Motorola Moto X XT1052 4G LTE 16GB Unlocked Phone SIM Free
My moto x keeps roaming where it shouldn't what can I do to fix it
How to turn off roaming?
If you need to stop Roaming phone signal while visiting abroad,You should keep in mind the following instructions
1.Turn your voicemail off
2.Just switch Data Roaming off with a help of your service provider.
3.Try to access network through Wi-Fi while visiting abroad.
4.You can also avoid roaming by use the local carrier sim card,which is available in that country.Before put local carrier,Make sure your phone is unlocked or not.If it's restricted by some network,try to unlock your phone using
SuperUnlockCodes.com
Jul 08, 2014 | Motorola Cell Phones
Samsung europe
Yes,It will work.But Roaming charges will be applicable.
Unlocking4U.com
May 22, 2014 | Samsung SGH Cell Phones
Why does my phone have no network connection?
Joseph
Sounds like you need to call boost to enable roaming.
Mark
Motorola Support
Apr 13, 2014 | Motorola Mobility GOOGLE 8GB MOTO G XT1032...
Turn off roaming
Unlocking4U.com
Apr 11, 2014 | Cell Phones
Stop roaming
If you need to stop Roaming phone signal,You should keep in mind the following instructions
WickedUnlock.com
Mar 02, 2014 | Nokia 5800 Cell Phones
When i call someone they can barely hear me
If it happens to everyone you call it is a problem with the phone itself. Either the mic is damaged or the transmitter is failing. It needs professonal service. Otherwise, there are inexpensive replacements all over eBay.
If it happens from time-to-time with different people it is a connection problem. The only thing you can do is update roaming or restart your phone. If you use Verizon dial *228 and select option 2 to update roaming. Verizon says to do this once per month or after traveling 20+ miles. In the case of non-Verizon phones take out the battery and then put it back in and turn on the phone.
If it only happens with one person, their phone has a problem, not yours.
If this helps please vote for my solution.
Feb 25, 2011 | Motorola Mobility Moto Q
Moto q
I believe the Moto Q can support this so the basic flash you received only hacks the SPC, changes it to null value and writes the PRL (preferred roaming list) for Cricket and it's partner carrier's towers. Then, assuming it has not been reported lost or stolen, they will add your ESN (electronic serial number) or IMEI (international mobile equipment ID) so you can make and recieve calls. This does not enable picture messaging or internet. This is a separate procedure using computer software and there are several things which need to be changed in the firmware like your MID (mobile identification number) web addresses, protocols, and passwords for Cricket mobile service. You will need to take it to the person who flashed your Verizon and ask for the full flash so you can get the internet. I hope this helps. If you already paid for the full flash ask them to redo it and test it before you leave the store.
Jul 13, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Moto q problem
I had the same problem and called my phone carrier. They sent me to motorola. As long as you bought your phone less than a year ago, they will fix it for free.
-Ken in Kentucky
Jun 03, 2008 | Motorola Mobility Moto Q
My razor cell keeps roming
Try dialing *228 to update your roaming preferences. It should connect to verizon's automated roaming update service.
Unfortunately, it won't normally update if you are not already on a Verizon tower. If *228 will not connect, also try *22804, which attempts to push it through to the nearest Verizon tower, or *22890.
If you do get through, it will give you a welcome message, and ask you to select option 1 to reprogram, or option 2 to update roaming preferences. You will need to select option 2.
If you do not get through, unfortunately you will have to stop by a Verizon Wireless Corporate owned store and speak with their tech department. They will be able to tell you if you have the latest PRL (preferred roaming list) and also check to see if you have the latest firmware (which could be part of the issue). They will have the tools to manually reprogram the roaming listing in the phone.
Jan 21, 2008 | Motorola Mobility RAZR V3
Motorola Moto X XT1052 4G LTE 16GB Unlocked Phone SIM Free Logo
102 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
