Question about Sunbeam 2346 Heritage MixMaster Series Stand Mixer
I need the gears for a 2346 sunbeam stand mixer
I have it all apart and all that's bad are the plastic gears where can I buy them
SOURCE: Sunbeam hand mixer. One beater not working
That spring does not turn the beaters. It is part of the beater release assembly. Probably one of the gears is worn.
Posted on Jun 05, 2008
SOURCE: Model #2366 mixer blade release problem
I found a site that says it has replacement stands for 19.95 plus shipping. You can check it out at http://www.bettervac.com/proddetail.asp?prod=SUN%2D84128&cat=293.
Good Luck
Dan
Posted on Nov 04, 2008
  • 4 Answers
SOURCE: Regarding the Sunbeam Mixmaster (model
Pry the beater release button out with a screwdriver. There are two screws underneath it and one under the motor housing between the the beater holes. This will allow you to remove the chrome front cover, but not the motor and drive assembly. Getting to the part that contains the gears requires complete disassembly of the mixer. It is not designed for service, and requires patience and a variety of tools to disassemble.
It has a metal worm gear and plastic drive gears. If the beaters are out of alignment, then one or both of the plastic gears are stripped and the mixer is junk. Repair plus shipping costs equals the price of a new mixer. This is the weak point of these mixers and a fundamental flaw in an otherwise robust and sturdy design. It is definitly not the same mixer *********** bought 30 years ago.
Posted on Dec 16, 2008
  • 2976 Answers
SOURCE: have a sunbeam heritage stand mixer model 2346-000.
Make sure the bowl is off to the side. I wouldn't get rid of a mixer just because the bowl doest't, if it's a good powerful mixer. There aren't many replacement parts available except directly from sunbeam. You need to get a replacement motor for the bowl turntable.
Posted on Jan 08, 2009
greenspan
  • 1734 Answers
SOURCE: I need a User Manual
Check here, I guess they can get you virtually every Sunbeam manual
Posted on Jul 28, 2009
Worn out beater gears
Soft plastic gears inside the machine from what I've read around the web, sorry but you'll need a complete new mixer.
I've had one apart to see just how fixable it might be, and it took me about 30 minutes to get the motor and gearbox into a position where they could be looked at. The gearbox had 2 stainless steel clips holding the top cover on and I didn't want to pry at those in case the cover snapped.
Not a lot gained from looking inside it sadly.
Apr 12, 2013 | Sunbeam 2346 Heritage MixMaster Series...
Need manual for Sunbeam model 2346 stand mixer
Sunbeam has the manual for the 2346-33 stand mixer on the product page: http://www.sunbeam.com/ca/productdetail.aspx?section=kitchen&cid=14&pid=5280 . The direct link to the manual is http://www.sunbeam.com/ca/manuals/Sunbeam/002346-033-000_English.pdf . The manual covers several models. Note: you will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Nov 16, 2011 | Food Mixers
Bowl does not rotate anymore
This is typical of Sunbeam mixers. The solution is to throw that piece of junk out and never buy anything from Sunbeam again. They can't stand behind their products because they know they are junk. They would go out of business if they tried to repair/replace all of the useless appliances they sell.
Oct 24, 2011 | Sunbeam 2346 Heritage MixMaster Series...
Bowl wont rotate
I have problem with the gears of the mixer sunbean 2343. Since I can buy all the pieces that compose the system
Please clarify your question. I understand that you are thinking of buying replacement parts for the mixer to correct the gear problem. Is that correct?
Jul 29, 2011 | Sunbeam 2346 Heritage MixMaster Series...
Beaters won't turn bowl still does turn
I just took mine apart for this same issue. What i found was the plastic beater drive gears have been stripped by the motor worm gear. I am currently looking for these parts to replace them.
Dec 28, 2010 | Sunbeam 2346 Heritage MixMaster Series...
The beaters won't go around. The motor is running
I can't solve this problem, but mine just died doing the very same thing. Motor is running, the revolving base is turning, and the beaters are just sitting there. Ruined an entire batch of divinity!
Aug 30, 2009 | Sunbeam Heritage 2346 Stand Mixer
Have a sunbeam heritage stand mixer model 2346-000.
Jan 08, 2009 | Sunbeam Heritage 2346 Stand Mixer
Regarding the Sunbeam Mixmaster (model 2346): How do I remove the front cover of the mixer so that I may reallign or replace the beater gears?
Jul 18, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Stripped beater gear
It is terminal. This is the fatal design flaw of these mixers. The gears are made of soft plastic and strip easily. Even the gear housing is plastic that is either glued or melted together to make it unserviceable. I have never suceeded in finding the part from either Sunbeam or one of the many appliance repair places on the web (who charge the cost of a new mixer for repair). Sunbeam does not repair them; if it is determined to have malfunctioned due to quality or design while under warranty, it is simply replaced with a new one. I had mine replaced under warranty twice, each time they sent me a new one complete with extra bowls and beaters. Now I have three sets of bowls and beaters and no functioning mixer.
May 25, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam 2346 Heritage MixMaster Series Stand Mixer Logo
166 people viewed this question
Top Sunbeam Food Mixers Experts
Oscar Netto
Oscar Netto
Jerry Greenberg
Jerry Greenberg
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
