My pendrive has been locked by bitlocker which i can not remember the password
    Top Expert:
  • Computers & ... Master
  • 22,703 Answers
You were prompted to save the password in a file on your hdd when you installed Bitlocker. See if you can find it.
Posted on Nov 07, 2014
How to get to locked files on a Toshiba Laptop a305 - s6837 ?????
If you have used BitLocker, when you go to BitLocker you will need the password laid down by the administrator or owner of the laptop before you can de crypt the files.
Nov 26, 2016 | Toshiba Computers & Internet
Tip
How to Recover Data From a Disk Encrypted by Bitlocker. Data Recovery.
Today we will describe the procedure of data recovery from a damaged disk encrypted by Bitlocker. Such problem may emerge as a result of damage to the file system of an encrypted disk (for example, damage to the area of the hard disk, where BitLocker stores important data, that happens due to unexpected system shutdown), inability to load OS or BitLocker recovery console, and other similar errors that prevent normal opening of the encrypted disk. The described problems may affect both system disk,portable external drive or USB drive.
In order to recover data we will use the utility Repair-bde (BitLocker Repair Tool), a command prompt utility which appeared back in Windows 7 / 2008 R2. This utility is used for access and recovery of encrypted data in a damaged disk encrypted by BitLocker.
Warning. This procedure should be applied after all the others have failed, and it was impossible to unlock the encrypted disk in a standard way by using a Bitlocker password or recovery key.
Requirements for data recovery from a BitLocker volume
To recover data from a disk encrypted by BitLocker you need to have at least one of the following Bitlocker defense elements:
  • BitLocker recovery password;
  • Recovery key;
  • System startup key (Startup key - .bek).
Data will be recovered to a separate disk the size of which should be no less than the size of the damaged disk. In the course of recovery, all contents of this disk will be deleted and replaced by decrypted data from the Bitlocker volume.
In our example, disk E: (size 2 Gb) is a USB drive the contents of which are encrypted by BitLocker, and which cannot be opened for some reason. To recover data, we have installed an additional external disk F: (size 16 Gb).
http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-9.png
Method 1. Data recovery with the use of a BitLocker password
In the first place, try recovering data with this method (it will work with Windows 8 / 2012 and newer versions):
  • Launch command prompt as administrator.
  • Execute the command:
    repair-bde E: F: -pw -Force
    where E: - disk with Bitlocker data, F: - disk where decrypted data should be extracted.
  • In the course of executing the command you will have to specify BitLocker password (the same which a user is to enter into UI when trying to access an encrypted volume).
  • http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-2.png
Method 2. Decryption of a Bitlocker volume with a recovery key
For decryption of data located in a damaged volume which is encrypted with Bitlocker we will need a recovery key or a system startup key (if the system partition is encrypted).
Advice. BitLockerRecoveryKey is a unique sequence of 48 symbols. The recovery key is generated when a Bitlocker volume is created; it can be printed, saved as a text file to a local (this choice is not recommended) or external disk, or in a user account at Microsoft website.
http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-0.png
Now let us launch data recovery with the help of this key:
repair-bde E: F: -rp 011407-712393-682121-100210-377003-405174-520014-328130 -Force
If Bitlocker is used for encryption of the system partition containing Windows, and for loading the system a special startup key on a USB drive is used, the encrypted volume can be decrypted as follows:
repair-bde E: F: -rk I:\3F558473-943D-4330-8449-62C36BA53345.BEK -Force
where file 3F558473-943D-4330-8449-62C36BA53345.BEK is a key to launch BitLocker disk encryption on a USB drive G: (by default, this file is hidden).
After the procedure of data recovery and decryption, before opening the disk where the contents of the Bitlocker volume were extracted, it is necessary to run its check. In order to do it, execute the following command and wait until it is complete:
Chkdsk F: /f
Important note. If you failed to recover data from an encrypted disk with the described methods, it is worth trying to create a sector-by-sector copy of the damaged disk with the help of a Linux utility DDRescue (or any other similar utility). After that, try recovering data from the received copy by the following scenario.
Data Recovery Software
We also should notice that exist more common and simpler way to recover files from Bitlocker encrypted storage. These are data recovery software. Of course, not all programs ?an cope in such situation but some of them have required function.
The only thing is that you must have a password to unlock the device which was specified when encrypt.
Then it's simple. Connecting device with the information that you want to recover to your computer and getting message.
Further, enter password in a special window after double-clicking on the device you need to recover in "This PC".
After that, the storage becomes fully accessible for data recovery for any of the Hetman Software programs.
on Jun 06, 2016 | Hetman Partition Recovery - Recover...
How do recovery bitlocker password
Open the saved encrypted file password that was created when you installed bitlocker or buy a new device.
Feb 28, 2015 | Dell Computers & Internet
How to remove bitlocket from my laptop...it appears on one of my apps and also the avast shortcut...I tried to remove the app and installed it again but its still there
Go to Start > Control Panel
Right click on Bit Locker
To turn off or temporarily disable BitLocker
If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Click Turn Off BitLocker. This opens the BitLocker Drive Encryption dialog box.
To decrypt the drive, click Decrypt the volume. To temporarily disable BitLocker, click Disable BitLocker Drive Encryption.
Feb 04, 2015 | Cell Phones
How to unlock bitlocker encryption on a external hard drive
You might not ever get it back as the whole point of encryption is security. Having said that, try to remember , was anyone present when you made the password? Do they remember anything, Could you have made it with cap lock on my mistake? You wrote it down somewhere else? Can you remember? You changed it and told a friend on the phone? Did you use a different computer to set this up?
I tell all my clients Go to the dollar store buy an address book with the split pages abc ,def, etc mark it my computer passwords and use it just for that. Best $1.00-$3.00 you'll ever spend. Good luck Bob
Jul 12, 2014 | Microsoft Windows Vista Ultimate Edition
How do I boot to windows or disable bitlocker?
Anonymous,
Steps to Turn On/Off BitLocker:
Click the Start button to view the Start Menu and then choose the Control Panel option.
The Control Panel window opens up.
Now click the System and Security link from this window.
The System and Security section of Control Panel opens up and you can see the direct link for the BitLocker Drive Encryption.
Click on the BitLocker Drive Encryption and a new window opens up.
By default the BitLocker Drive Encryption is Off for the Hard Disk Drive. Click Turn On BitLocker. If a compatible Trusted Platform Module.
Note: To use BitLocker Drive Encryption, your computer has to meet certain hardware requirements.
Otherwise, this opens the BitLocker setup wizard. Follow the instructions in the wizard. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Click Turn Off BitLocker. This opens the BitLocker Drive Encryption dialog box. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 07, 2014 | Dell XPS M1530 Notebook
How can I. Bypass an HDD password on a dell studio xps 1645
Are you asking about bitlocker or a bios password? You can clear the bios password by either taking out the battery or removing a jumper and then booting the machine and then turning the machine off and replacing the battery or jumper. If it is bitlockered there is no way around it unless you have the bitlocker code.
Feb 26, 2012 | Dell Computers & Internet
I have locked the second partetion of my laptop HD but after i couldn't unlocked it even i have a passwerd ( locked with bitlocker) when i put the pass.W it start but at 14% it stopped and sayed suspended...
BitLocker is an excellent encryption utility but unless you use the correct password or the file that the programme saved for you when you locked the secondary hard disc, you are, as we say, stuffed.
If you can find the bitlocker file, usually named "Bitlocker * " it is about 30 digits in length and on your drive somewhere. Type bitlocker into the search box.
Good luck, there is no other way in!
Mar 25, 2011 | Samsung Computers & Internet
WHEN I TURN COMPUTER ON AND IT START BOOTING UP. IT SAYS "HARD DISK LOCKED, ENTER USER PASSWORD"
Sounds like your disk has had bitlocker activated (vista or windows7)
if you did not create a recovery file at the time of creating your password and now cannot remember your password then there is not much you can do about the data already on the drive, you would need to remove the partition and reinstall your OS from scratch.
thats the purpose of data encryption, to ensure that no one can ever get your data.
Mar 20, 2011 | Computers & Internet
I'm at my nephews, and he has been on my x61, haven't got a clue what he has done, but now locked out and reading 'windows bitlocker drive encryption pin entry' I haven't got any codes or passwords with...
Sounds as if he may have activated 'bitlocker' on your drive. Ask him for the pin code he used and if you get in disable 'bitlocker'. Highlight the drive in My Computer>right click and select turn off bitlocker.
I hope he remembers the pin code he used!
Jan 31, 2010 | Lenovo ThinkPad X61s Notebook
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
