Question about Tools & Hardware - Others
How can I drain a water softener
Tell me how to drain
Are you talking about the resin bed or the salt reservoir?
Salt Reservoir ~ Remove as much salt as possible then dump the water out.
Resin Bed ~ You do not want to remove the water from this unit. Disconnect it from the water supply and discharge and cap it off.
Posted on Dec 30, 2014
Water Softener full of water, not draining, or using salt
How old is the system ? Where does the system drain to ? If this is the softener you have (seems awful large for a household) it is probably the injector/nozzle assembly. I have attached a manual to help you. A restriction in the drain line could also be the problem. Fleck 2850s
Mar 20, 2014 | Fleck 165,000 Grain Series 2850 Commercial...
Installation
Hi David,
Your water softener doesn't have a pump in it. Your home's water pressure comes either from your municipality or from the pump in your well (or basement) which has the power to move water to the top of your building, so yes, your softener will drain overhead, even a couple of floors. There is internal friction in any drain line, so your softener manual likely advises that if your 1/2" drain line is more than 25 feet long you ought to install a 3/4" drain line to reduce back pressure over that longer run.
Dec 21, 2013 | Kenmore 300 Series Water Softener
My miele g680 dishwasher did have a flashing intake/drain I cleaned it seemed to be working fine, then everytime I try to start it the softener light comes on with no further washing activity.
that is just an indicator that your salt is low. it will stay on until you refill the water softener with softener salt. it will not affect the dishwasher to run it without the salt. the water for your final rinse will not be softened.
Apr 06, 2012 | Miele Dishwashers
My water hose from my culligan n8 came off and water was poring out,..where did that come from and where do i reattach it? thx!
It depends on which hose you are referring to. If you are referring to the DRAIN it may have come off by the softener valve it goes back on the drain connection on the side of the valve (use a hose clamp). If it came off by where the softener drains it goes back into wherever the softener was draining (laundry tub, standpipe trap, floor drain)? If the hose came off by the connection for the salt tank it should be replaced. If you don't know, unplug the softener for now or it may flood again and call your local dealer.
RJ
RJ
Oct 10, 2011 | Culligan Sediment Water Filter
Bosch nexxt washer fabric softener not draining
is there a drain on the bottom left corner if so drain the contents its usually under a small panel
Sep 14, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
My front loading washing machine is flashing a code, F 02, and sometimes it is F 03, I do not know what it is trying to tell me.
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
The problem with the fabric softener not dispensing is not likely related to and F03 error code due to the washer not draining.
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly.
The fabric softener dispenser works on a siphoning principle.
Make sure that the siphon hole in the dispenser is clear and not restricted or plugged.
You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it.
Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer.
You can use the diagnostic test described below to test the fabric softener dispenser.
If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining.
You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer.
You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum.
To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 20, 2009 | Kenmore Washing Machines
After my softener is done with regen water still
The drain float seems to be stuck. Move it up and down , sometimes this helps loosen it to allow it to close.
Jun 30, 2009 | Home
Softener slot won't drain.
take the soap draw out there should b a sign on the draw to press also the top of the sofner compartment comes off u will see a hole where the water goes make sure it is clear put the lid back on hold soap tray under water tap let the water fill the sofner compartment it shoud run out
Aug 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bosch Classixx 1000: Won't drain
The Solution: Top up the softener tray with extra water so that it is up to the 'max level' mark.
The softener tray works by a siphon action. Thus, the reason the tray does not empty is that not enough water is added by the machine during the softening cycle, so that the machine does not completely fill the softening tray; only when the softening tray is filled beyond the 'max' mark does the siphon action works. A partially filled tray will never empty - it's impossible due to the siphon.
The reason that not enough water is added to the tray during the softening action is that the water inlet of the machine is partial blocked (you can try to fix that) but it is simpler to just added more water to the conditioner tray.
Thus, the easiest way to ensure that the softener tray empties every time (after adding the softener to the softener tray of course) is to top up the softener tray with extra water, top it up to the 'max level' line (keep a bottle of water by the machine). That way, even if only a little water is added to the softener tray during the softening cycle by the machine it is enough to trigger the siphon action and the tray will empty!
Works for me every time, and no need to remove any parts - I used to take the tray out, clean it, scrub the outlet holes that fill the tray etc, but they used to gum up again quite quickly!
Hope that helps
May 26, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Water in Fabric Softener Compartment
As for the softener compartment, powder tends to overflow and block the three drain holes. It needs removing and thoroughly cleaning out, i use cotton buds and lots of hot water.
Dec 18, 2006 | Zanussi FS1455W Front Load Washer
Tools & Hardware - Others Logo
44 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
