SkyScan 86742 Digital Atomic Wall Clock Logo
G
GARY STEINERT Posted on Nov 07, 2014
<!-- from fixya rte -->SET THE TIME ON MY MODEL #867742 - SkyScan 86742 Digital Atomic Wall Clock
2answers
I hava a Nakamichi iPa53DK model iPad docking system. How to set the clock please?
Hello, to set the clock on your nakamichi iPa53DK model click settings the go to general there it will display the date and time. There you can set your time zone, date and time. Then enable the option for set automatically.
1helpful
How to set the time on a Dakota one button watch
To set the time on a Dakota one button watch, you will need to follow the instructions in the user manual that came with the watch. If you do not have the user manual, you can try the following steps:
  1. Press and hold the button on the top right side of the watch: Press and hold the button until the time display appears.
  2. Set the time: Use the button to set the time. The specific sequence for setting the time will depend on the make and model of your watch.
  3. Exit the time setting mode: Once the time is set, you will need to exit the time setting mode. The specific steps for exiting the time setting mode will depend on the make and model of your watch.
It is important to note that the steps for setting the time on a Dakota one button watch may vary depending on the specific make and model of the watch. If you are unable to set the time using the steps above, it is recommended to refer to the user manual or contact Dakota customer support for assistance.
If you have a "his and hers" set of Dakota watches, the steps for setting the time on both watches should be the same. You can use the steps above to set the time on both watches.
1helpful
How do I change the time zone for model 31981B?
How To Set Your Time Zone
Time Zones around the world are identified by how many hours they are off-set from Greenwich Mean Time. US time zones are 5 to 9 hours behind Greenwich Mean Time and are identified as:
Eastern -5 Central -6 Mountain -7 Pacific -8 Alaska -9
Your SkyScan model 31981 is pre-set to Pacific Time. To set your clock to your time press and hold the mode button for 2 seconds. The off-set hours will appear and blink in the clock window. Press the up or down button to designate your time zone. Press the alarm button to exit time zone setting mode.
http://skyscanatomicclocks.com/manuals/31981.pdf
1helpful
How to set timezone
Hi Mary
To set the timezone:
  • In the Normal Time Display, press the [MODE] button to enter the Alarm Time Mode.
  • Press the [SET] button to set the desired time zone. Refer to the Time Zone map on the display, P=Pacific, M=Mountain, C=Central and E=Eastern.
  • Press the [MODE] to return to the time mode position.
Full instructions for all of the clock features can be found at the following link:
Instructions Warranty for Atomic Clock Model SPC364
Trust this helps
Regards
Alan
Sep 27, 2014 • Home
2answers
How do I set the date and time on yardworks model #59-3531-0 watering timer?
how do i set the date and time for yardworks model # 59-3531-0
Jun 01, 2011 • Garden
5helpful
2answers
I don't know how to set the clock for a MA4203 model
I couldn't find the information for your particular model, but I did figure out the general procedure for Memorex alarm clocks currently in production:
  1. Make sure power is turned off (no radio or whatever playing). Press the Time Set button (on some models, this is the Skip Search Back button for an iPod docked in the unit).
  2. When the display blinks (on one model, the volume control knob lights up), press the Hour button (Vol. -) to set the hour, then press the Minutes button (Vol. +) to set the minutes. On the model with the light-up volume control, rotate the volume control knob to set the time.
  3. When you have the time set, either wait 15 seconds or press the Time Set button again to start the clock.
Setting the alarm works the same way on single alarm models, but the Alarm Set button may be the Skip Search Forward button. Dual alarm models have separate Alarm A and Alarm B buttons.
2answers
How do you set time zone model 3229-1
Press the Mode button to display the alarm time then press the Adjust button till you get tot the corret time zone, press Mode again once have found the coreect timezone.
9helpful
2answers
How to set time in fast track watch with model number 4056pp03
HOW CAN I SET CORRECT TIME ,DATE AND DAY FASTRACK WATCH MODEL NO 4056PP03
Sep 21, 2008 • Watches
Model#fa972 southwestrn bell freedom phone answering machine
Press the >>/Time Set button for about 2 seconds. The system will announce "Monday" press the >>/Time Set again to choose the correct day. Press <</Time Check to change to hours. Select the correct hours by pressing the >>/Time Set, then press the <</Time check to change to minutes. I can't get the mail box 2 to operate either.
Top SkyScan Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a SkyScan Home Expert? Answer questions, earn points and help others
