Question about Craftsman YT 4000 42" Briggs Stratton 24 hp Gas Powered Riding Lawn Tract
The lawn tractor hit a post and now the left front wheel is out of alignment. How can I make it aligned?
I have already replaced the LH spindle, LH draglink, & LH link cross. Everything else looks good, but the left wheel still is not aligned. There is no alignment adjustment, so I am looking for other things to look for. The front axle looks OK, the steering shaft looks straight, and the gear sector plate looks OK.
  • snowmanii Nov 11, 2014
    Can you provide the model number? it should be on a label under the seat.
    Sergeant:
  • Craftsman Expert
  • 369 Answers
The steering tie bar (goes from left to right steering brackets and makes the wheels steer together) should be straight. if it's bent, that is your problem.
Posted on Nov 07, 2014
Testimonial: "This model has no steering tie bar."
  • David Stanley
    David Stanley Nov 13, 2014
    This Craftsman model #917.288561.
4 Suggested Answers
SOURCE: 20 Year Old Craftsman Lawn Tractor Steering Gear Slips
check top of sector gear mounting plate for waer this is the gear that hooks to you steering gear . the plate that it mounts to will ware down causing it to be loos and slip . the only way i know to fix it is to pull the cross member out and take it to a welding shop and have it built back up.if the bolt is as tight as itcan go .
Posted on May 06, 2009
  • 760 Answers
SOURCE: I need to replace the
You can find your manual at:
http://www.managemylife.com/mmh/owner_manuals/16827/CRAFTSMAN-Lawn-Tractor-L0030155?brand_name_search=917270760+CRAFTSMAN
Parts are available at www.searspartsdirect.com
You won't find detailed instructions there, but there are parts diagrams that will help you determine what to remove first. I can't imagine why you'd need to replace this whole assembly, but the diagrams should be helpful.
Posted on Sep 24, 2010
  • 6468 Answers
SOURCE: pinion gear jumps the sector gear when trying to turn left. Right side fine.
no model number but some have a plastic fitting that hold the shaft down into the main gear it has a bolt that goes threw it into the bottom of the steering shaft about a $15 part but again no model number to see the set up
Posted on Jun 12, 2012
GOING BACKWORDS THE WHEELS TOE IN, GOING FRONTWORDS ONE WHEEL TURNS 90 DEGREES THE OTHER STAYS STRAIGHT AHEAD
You most likely have a broken tie-rod. (A part of your suspension. ) Don't try to drive it...it will not steer. It will have to be repaired.
May 01, 2016 | Mtd Garden
HOW DO I ALIGN THE FRONT WEELS ON A D130
loosen up tie rod unhook tie rod from spindele turn tie rod in hook tie up to spindle see if straight if not repeat till straight make sure tie rod end is not bad replace if is make sure spindle not bent replace if it is
Sep 04, 2014 | John Deere D130 22HP V-Twin Foot Pedal...
Aligning the front tires
most tractors no longer have a adjustment after time the wholes the rods go into wear out and the play in the holes throws the wheel off as well as hitting something and banding a part for worn holes i get door hinge repair bushings and refit the hole for the bushing to fit
Aug 13, 2012 | Husqvarna YTH21K46 (46") 21HP Lawn Tractor...
Front wheel alignment
Wheels are to straigten. Best to replace.
Jun 11, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do I adjust front wheels one wheel goes way off center
before you change anything, lift the whole front end off the ground and check the wheel bearings and the suspension bushings for slop. you cannot align it if there is slop in the system and those cheap
plastic wheel bearings are usually the culprit. if the bearings are bad, replace both sides and you can buy new front wheels at small engine repair shops, lowes, menards, DIY. if the knuckle bearings are bad, then a sears parts location or a small engine repair shop is the place to be. and from time to time an entire knuckle is bent from where a woman hit something with it.
if there is no slop, then acquire an owners manual from sears, google it, and there will be instructions on how to align. very simple lock nut on a threaded rod type of task. not rocket science.
Jul 27, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman DLT 3000 Lawn Tractor, Model 917.273821. Two problems for which I'd appreciate any help: Problem 1. The front wheels are not aligned. The left front wheel cants out to the left so much so...
Problem 2 is probably a belt slipping or a pulley loose somewhere.Problem 1 .........is the tie rod adjustable?If the tie rods are adjustable, put steering wheel where it's supposed to be when straight, then adjust tie rods so that each wheel is pointed straight ahead. There should be a lock nut that needs to be loosened, then turn the tie rod end in or out and tighten lock nut. Back to problem 2....if it isn't the belt or pulley, it may not be an easy fix.Sometimes over time, belts stretch and get loose, or a set screw in a pulley can work loose, and cause the pulley to slip on the shaft. If it is hydraulic, it might be low on fluid.. I don't know for sure as I am not a big fan of Craftsman lawn tractors. Good luck
Apr 16, 2011 | Garden
How do you fix the front wheel alignment on a 48 inch lawn tractor by Craftman. The wheels are turned to the outside. Theres no bent rods or anything. Whenthe wheels go one way in the frony. you mow the...
make sure tie rod between wheels is straight. if bent will cause wheels to turn outward. take tie rod loose at each wheel, straighten rod reinstall wheels should be straight.
Aug 21, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My front wheels are suddenly out of alignment. I
There are plastic bushings on the front wheels that get worn over time. Pull the front wheels off and inspect them to see if they are still intact.
May 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Steering
Look under the front between the wheels at the tie rod that connects the two wheels. It is probably bent up and should be straight. If it's bent, remove it a straighten it.
Jun 19, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Front wheels on craftsman lawn tractor are in two different directions after hitting fence. The one that hit the fence is in a 45 degree angle and the other is straight, how can I realign these.
It depends on if you just bent the tie rod (the rod that goes between the wheels) or if you bent the spindle on the wheel that hit. Look under the front and see if the tie rod is straight. If not, take it off and straightened it. If it is straight, you probably bent the wheel spindle. But also check the axle on the end that hit to see if it is twisted.
Jun 07, 2009 | Craftsman Garden
Craftsman YT 4000 42" Briggs Stratton 24 hp Gas Powered Riding Lawn Tract Logo
771 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
