Question about Garden
I am looking for a wiring diagram for PF-20-2N22X pump
Looking for diagram of wiring harness for 1977 Pontiac firebird 8 track tape player
https://www.google.com/search?q=77+pontiac+tape+player+diagram&tbm=isch&imgil=d25ZlCY70CHZ4M%253A%253BsMEc2k8B6ScLPM%253Bhttp%25253A%25252F%25252Ftransamcountry.com%25252Fcommunity%25252Findex.php%25253Ftopic%2525253D48721.0&source=iu&pf=m&fir=d25ZlCY70CHZ4M%253A%252CsMEc2k8B6ScLPM%252C_&usg=__zl9WeLTR83ZUviDP1bFZ3fh4BUc%3D&biw=1280&bih=890&ved=0ahUKEwiFjaLjkZjQAhXnqlQKHTQnCm0QyjcINg&ei=6TshWMX0AefV0gK0zqjoBg#imgrc=d25ZlCY70CHZ4M%3A
Nov 08, 2016 | Pontiac Cars & Trucks
CAN I WIRE THIS PUMP TO RUN OFF 110 OR DOES IT ONLY USE 220
There should be a wiring diagram on the side of the motor. It will show wiring for 220V,or 110V, or both.
Jun 22, 2015 | Pool & Spa
What dose PF mean
I would check the power to make sure of the polarity, two hots and a ground. Once that checks out ok and still has a problem, check the power cord connections in the dryer, that green wire goes to chasis ground or terminal N, G, and the solid color wires to the line 1 and line 2. If it still trips on PF, then a wiring diagram and tracing the power failure is needed, perhaps a control transformer but its too early to say now. Diagnose.
Feb 04, 2015 | Dryers
Need a wiring diagram for a 1997 Nissan quest xe fuel pump assembly it has 4 wires and my not so smart brother in law tried to change fuel pump abd instead of disconnecting the plug he cut the wires so I...
Usually, replacement pump will come with wiring instructions. If dumbo lost them, might go to friendly parts store and ask to look at chart in another one, or simply look at wiring diagram in your shop manual.
Dec 15, 2014 | Cars & Trucks
My dishwasher has pf code every use and doesn't finish. It seems to happen when pump kicks in and doesn't sound good. Could bad pump cause pf code
PF stand for power failure...and only occurs when voltage is lost to the main control... First thing I would do is shut the power off to the dishwasher and check the main power connection going to the dishwasher, I have seen those wire nuts come loose and melt.
Far as the pump causing it, I wouldn't think so.. its more likely its just tanking some time for the wire's to heat up before the connect is lost (about the time the drain cycle starts)
If not I would recommend a pro come out and look at it.
Mar 08, 2014 | GE Dishwashers
Soap pump won't work...fill it, pump a thousand times, no soap
Common problem with PF faucets. Have read elsewhere that soaking the pump mechanism in water or other solution may fix. PF offers new pump mechanism for less than $8 but shipping is equal to that. That is a non-starter for me.
Stopped by Lowes this afternoon and when I told them the part I was looking for, they handed me the 931-0020 pump replacement saying that PF rep had dropped off a ton of them because they were having problems with the dispensers across thier line. And, get this, they gave it to me gratis!
I'll see how easy it is to pop out and replace tonight (instructions elsewhere on this site)
Jan 15, 2011 | Price Pfister Marielle Kitchen Faucet with...
Garden Logo
88 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
