Lights come on
When i plug it in it does not come on or run.
    Problem Solver:
  • 12 Answers
Can you give me a model of this shredder?
Posted on Nov 23, 2014
Testimonial: "model no. SPL826X"
Interior wall panel battery lights does not lightup when 120 power is not pluged
The lights run off of 12V DC and use your RV's batteries to run when not plugged in. When plugged in it uses the AC and converts it to DC and runs the lights.
Please check your battery disconnect switch. It's most likely off. In my Winne there is a battery disconnect switch which disconnects the two batteries near the door. Lights wont work when unplugged and the switch is off. Lights works when plugged in or unplugged and switched on.
May 05, 2015 | Winnebago 2015 Ultralite 27RBDS
There are only 5 wires from truck. Red, black,
aaaa more info your new plug should be marked as to what to connect to , DONT drive your self insane do one wire at a time and with a test light im guessing this is a rv flat spaded plug as i said start with one thing at a time turn on just running lights not headlights running lights that will put power in on wire only and that you want to connect to your plug running lites next shut off lights ,turn on a signal light signals will be a blinking light only on one wire.
Oct 08, 2014 | Cars & Trucks
Wiring 4 way flat trailer plug. brown wire running
you got brown for running parking light
green for right turn/stop
yellow for left turn/stop
white for ground
reverse lights are only wired on a 6 or 7 plug connector
make sure you on the dark green for right turn stop not the light green
the light green is for reverse
Jun 24, 2010 | 1999 Chevrolet Tahoe
Trailer wiring problem. Tow vehicle is a 2008 Grand Caravan with 4 wire plug. Double checked, plug function works fine. When trailer is plugged to tow vehicle with tow vehicle lights OFF the trailer...
Most likely the brown wire from the trailer connector is connected to a constant battery voltage source, and it should be connected to the vehicle running light circuit, however someone might have wired the trailer connector up that way on purpose so that the trailer does not draw power from the vehicle running lights and possibly damage the vehicle running light circuit. (Dodge/Chrysler vehicles do have delicate lighting systems) Here are some images to help assist you, and the 4 way connector is the same as the 5 way connector just without the blue wire for the trailer brakes.
Jul 06, 2010 | 2008 Dodge Grand Caravan
Running trailer lights not working, but brake
Did you check the fuse for the trailer tow adapter paring lamps ? This is a separate fuse powered by a relay, it is not the same circuit as the truck's parking lamps.
This is fuse # F10 & The half size ISO relay, R201 in the fuse panel in the passenger side kick panel.
This is based upon being a new body style 2004, not the 2004 Heritage or Lightning models, those are different fuse & relay locations.
Jun 05, 2010 | 2004 Ford F150
No check engine light on runs rough while in gear
Plug Mis-firing (firing-but not adequately) no light and no fire.
Causes: Spark plug bad, spark plug wire leaking.
If you can pull the spark plugs - and you find that one of them is wet or very dirty - compared to the others....the you have the wire/plug source identified.
Oct 14, 2009 | 2002 Ford Taurus
Trailer running lamps will not work
Your running lights/marker lights and tail lights are on the same circuit. I all thetruck lights work, the problem is in the plug or plug harness.
Jul 01, 2009 | 2007 Chevrolet Silverado 2500HD
2005 F250 Trailer lights
Not sure if you know that much about electrical wiring so I will go through it like you don't.
Take the trailer plug out of the female socket at the rear of the car, turn your running lights on, go to the female plug and using a test light check to see which one lights up the test light, that wire will be the running lights wire.
turn the running lights off and turn either your left or right indicator on and check at the plug to see which wire lights the tester, do this for the opposite indicator as well.
Turn the indicator off and get someone to hold their foot on the brake while you test the plug for power.
check the male plug at the rear wire terminals by putting it in the female plug and perform the same test as the female plug, if you have power to all the wires at the rear of the male plug go to the lights at the rear of the trailer and perform the same tests as before.
to get the both rear brake lights to come on you have to run a red wire from the brake light on the live wire side to the light on the opposite side to give it power when you apply the brakes for it to light up.
Turn the ignition on and turn your left or right indicator on again and check the wire for that side, if that is ok do the same for the other side then the running lights, you will have to run another wire off the running light wire to the opposite side of the trailer to give that side power to the lights
ther should be an earth wire from the plug that has to earth the trailer, all the lights also have to be earthed as they will not work if they aren't.
Try that and see how you go, if you do it right they should work for you
May 14, 2009 | 2002 Ford F250 Super Duty SuperCab
No running lights on camper trailer
Hey Paul, it's most likely a wiring problem. There is one wire designated for just the running lights. What type of plug does the truck have? Probably 6 or 7 way (6 or 7 wire). You can check the plug-in at the truck with a multi-meter to see if there's power at that point. If there is, then the problem is somewhere from the trailer plug to the lights on the trailer. If you have a 7 way plug, the center plug is for aux. power (back up lights on what you pull, if equipped). One wire is power to the camper battery for a breakaway switch, one for left turn and stop, one for right turn and stop, a ground wire, one for running lights, and one for trailer brakes. To determine what wire does what, 1st with meter check volts of all wires w/ truck and trailer hooked up, truck running, power wire to battery for breakaway should show voltage if equipped w/ a trickle charge, brake wire will show low voltage, approx. 2 volts, apply brakes and should go up to approx. 12 volts, put on L turn signal, meter should go up and down, as power to blinker pulses on and off, do the same to determine which is the R turn signal (put foot on truck brakes will show voltage to brake lights AND brakes, continue w/ process of elimination to determine which is running lights, and exactly where power is not going.
Apr 19, 2009 | 2002 Toyota Tundra
50 people viewed this question
jasbo
jasbo
