Question about Northern Industrial Tools Air Tools & Compressors
Looking for Northern Industrial 18v battery model NTECBA18
Doesn't matter whether it works or not. will take the charge too if available
  • 4 Answers
SOURCE: makita cordless driver drill model-6347d.
You say will not stay charged? Over what time period? Are you aware Nicad and NiMh rechargeables discharge naturally at 1% per day so where does that leave your power tool after 3 months? Furthermore they only have around 1000 charges in their useful life so you can immediately see how these tools are not for intermittent(ie handyman) use.
Posted on Jul 03, 2009
  • 9 Answers
SOURCE: Makita 18v Lithium-Ion BL1830 Battery Won't Charge
If you have been a bad boy and managed to short the battery by using it for non-proscribed purposes, the fusible link will blow (kind of like a fuse) To fix it, open up the battery (use a Torx 10 security bit, or a small flathead in a pinch) On the battery connection nearest the spring-loaded white catch there is a small bridge of metal with a hole in the center. If this is melted you can solder it back together by sanding the two pieces and putting a glob of solder on them. This will void your warranty (duh!) and remove the battery's fuse protection, but it WILL work again. If the link is intact and nothing else is obviously wrong, you almost certainly have a bad cell. I recommend pulling out the bad cell ( it will be the one that does not read between 2.5 - 4 vdc) and replacing it with one from another dud battery- this requires some fudging and re-soldering. Or do what I did, pull the cell, toss the electronics and the short pink wire, add a cigarette lighter socket and voila! you have a portable power supply giving around 14 volts. Charge it up by wiring two cigarette lighter male ends together (check polarity , + to + and - to -) and plug it into your car, but only while it is running or you will be charging your car battery with it! Hope that helps.
Matt Binns GiantGlobes.com
Posted on Aug 18, 2009
  • 9 Answers
SOURCE: I need charging instructions for my 18v lithium batteries.
the lithium batteries are not like nicad you can cahrge them whenever you want and will not get a memory. Just put them on the charger and when the ready light is on they are done.
Posted on Oct 05, 2009
lcdpayless
  • 25 Answers
SOURCE: One of my Ryobi 18v battery packs (1400672) won't charge.
Use
AC / DC Power Adapter Replaces Ryobi One+ Batteryhttp://lcdpayless.com/ryobi_one_power_adapter.php
Posted on Jan 29, 2010
  • 246 Answers
SOURCE: Need owner's manaual for Northern Tool 123005 elec
Try online at www.needanownermanual.com.
Good Luck
Posted on Feb 21, 2010
Can I buy a battery charger for a ozito drill
yes
Search Results
Ozito Power X Change 18V Eco Battery Charger Tool ' Bunnings ...
https://www.bunnings.com.au > ... > Cordless Accessories > Batteries & Chargers The Ozito PXCG-120 18V Eco Charger can be used to charge any of the Power X Change battery packs and includes a charge indication. The Power X Change Eco Charger is a compact and portable design. Charge Time: 1.5Ah Battery - 2.0hours 2.0Ah Battery - 2.5hours 3.0Ah Battery - 4.0hours 4.0Ah Battery - 5.0hours
Batteries & Chargers available from Bunnings Warehouse
https://www.bunnings.com.au/our-range/tools/power-tools/.../batteries-chargers Compare. Ryobi One+ 14.4 - 18V Dual Chemistry Car Battery Charger. Ryobi One+ 14.4 - 18V Dual Chemistry Car Battery Charger. 79. Compare. Ryobi One+ 18V 1.5Ah Lithium+ Battery. Ryobi One+ 18V 1.5Ah Lithium+ Battery. 69. Compare. Bosch Blue 18V 3.0Ah Li-Ion Battery. Bosch Blue 18V 3.0Ah Li-Ion Battery. 119.‎Ozito Power X Change 18V ... · ‎Ozito Power X Change 18V Li ...
Dec 02, 2017 | Drills
WHERE CAN I BUY A battery nteCBA18 for a jig saw model ntecjs8c from northern industrial?
try at http://www.ag-central.com/ag-store/Power-Tool-Accessories-148.html or contact Norther Industrial tools at http://www.northerntool.com/shop/tools/category_power-tools+jig-saws
Feb 05, 2017 | Saws
D.A. Sander part
what is the make and model number?
Jun 11, 2013 | Northern Industrial Tools Air Tools &...
Need battery charger for robust 18v drill/driver. charger model 9706
need battery charger for robust 18v drill/driver. charger model 9706
I have exactly the same charger with the battery .
my drill is fallen , and it is broken .
Jul 13, 2010 | Drills
Replacement Battery
I found a 18V Powerglide battery at AceHardware.com and they say that it will fit ANY 18V Powerglide tool. Their part number is 2103992 and list price is 23.99. However I would strongly recommend that you look at the battery online to make sure it will match up. This is allthe information I can find. Good Luck
Dec 31, 2008 | Ace Hardware PowerGlide 18V Trigger...
General Knowledge
Yes!  It is not very powerful, but the blower serves to move heat away from the heat coils and toward the work.
Dec 16, 2008 | Northern Industrial Tools Northern...
Air Tools & Compressors Logo
119 people viewed this question
Top Northern Industrial Tools Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Northern Industrial Tools Air Tool and Compressor Expert? Answer questions, earn points and help others
