Question about Sport & Outdoor - Others
How to change the water pump - Sport & Outdoor - Others
    Problem Solver:
  • 13 Answers
Go on u tube they will show u how just put in make model and year
Posted on Nov 07, 2014
Where is water pump fuse located
If your water pump has failed you will simply just have to change it.It does not have a fuse and a rule of thumb is change the water pump when you change the timing belt at 60000 which is the correct interval to change the timing belt and you already have easy access to change the water pump also.
Oct 20, 2013 | Honda CR-V Cars & Trucks
I would like instructions on changing a water pump in 2005 Chevy uplander V6 3900
This is probably the easiest water pump of all vehicles to change.
Water Pump Replacement
Removal Procedure
  1. Drain the cooling system.
  2. Loosen the water pump pulley bolts.
  3. Remove the drive belt.
  4. Remove the water pump pulley bolts and pulley.
  1. Remove the water pump bolts, pump, and gasket.
  2. Clean the water pump mating surfaces.
Installation Procedure
  1. Install the water pump gasket and pump (1).
Notice: Refer to Fastener Notice in Service Precautions.
  1. Install the water pump bolts.
    • Tighten the bolts to 10 Nm (89 inch lbs.) .
  1. Install the water pump pulley and bolt until snug.
  2. Install the drive belt
  3. Install the water pump pulley bolts.
    • Tighten the bolts to 25 Nm (18 ft. lbs.) .
  1. Fill the cooling system
  2. Inspect for leaks.
Aug 18, 2013 | Cars & Trucks
Can't get 1976 evinrude 6hp to pump water I changed water pump
have you changed the impeller inside the lower unit.
There is copper pipe to redirect water up into the engine.
When you replaced the impeller make the copper pipe is insert onto the engine.
Jul 31, 2012 | Light Outboard Motor Boat Bass Fishing...
2000 FORD EXPEDITION OVERHEATING....changed thermostat,radiator cap, confirmed fan clutch is working, no radiator leak noted, changing coolant temperature sensor as a type...water pump not leaking or...
yes. the impellor on these engines have a tendency to come off the water pump.First you can see if the pump is working by removing a heater hose then have someone to start the engine. if the water sprays a good, solid stream out then the water pump is good. if the water just barely comes out or not at all then the pump is weak or "bad".
Aug 13, 2011 | Ford Expedition Cars & Trucks
I have a 2003 pontiac grandam with a intake gasket leak. I am planning to have it fixed but i have advised to change the water pump also. I am having no water pump problems is that advisable to do.
CHANGE WATER PUMP WILL SAVE YOU SOME MONEY, TO CHANGE INTAKE GASKET HAVE TO DISAMBLE PART OF YOUR ENGINE , AND IF YOU NEVER HAVE CHANGED YOUR WATER PUMP IT WIL PREBENT FUTURE PROBLEMS. BUT DOESN'T MEANS THAT YOU NEED TO CHANGE WATER PUMP.
Feb 17, 2011 | 2003 Pontiac Grand Am
Do you have to change the water pump when changing the timing belt/timing?
You don't have too, but not bad idea, the timing belt drives the water pump, if you just replace timing belt, and not water pump, water pump could go out and mess up the timing belt, now it has to be done all over again, timing belt, water pump and labor.
Sep 16, 2010 | 1996 Subaru Legacy
2003 kia rio- water pumps
I would follow the mechanics recommedations. I think he's taliking about the cam and crankshaft seals. Yes the water pump should be replaced as well. The pump that sprays windshield washer fluid onto the windshield is called the windshield washer pump. The water pump is on the engine and pumps water (coolant/antifreeze) through the engine to the radiator and heater core.
Oct 29, 2009 | 2003 Kia Rio
Do I change water pump when having timing belt changed
I would go to auto zone and get a diagram and the timing belt and do it yourself and the water pump (no it does not have to be changed everytime the timing belt is changed but if the car has over 60,000miles then it is best to change them both) it is not that hard especially if the car is not out of time just make sure you disconnect the negative side of the battery
Jan 21, 2009 | 2001 Hyundai Elantra
How to change a water pump on a 1999 Buick Century 3100?
the water pump on the 3.1 isnt to hard to change ...
  1. Disconnect the negative battery cable.
  2. Partially drain the cooling system into a suitable container.
  3. Remove the drive belt guard.
  4. Loosen the water pump pulley bolts before removing the drive belt. This should help keep the pulley from turning as the bolts are loosened.
  5. Remove the drive belt. Remove the water pump pulley bolts and remove the pulley.
  6. Remove the water pump bolts and separate the pump from the engine front cover.
Dec 09, 2008 | 1998 Buick Century
Leaking water pump
leaking water pump was standard for that year.
Changing it without changing of taking of the cam belt shouldnt be a problem. but wen u get the new water pump make sure it the same cause in changes from serise 1 to serise 2
Oct 17, 2008 | 1994 Mazda 626
Sport & Outdoor - Others Logo
29 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
