Question about Yamaha Music
Can you help us get sound from our Yamaha electrone hc2
Hi I have a Yamaha electrone hc2 that we have recently moved from one room to another and since moving it we are not getting any sound. We have checked all the plugs are in the right places and connected properly. We have also followed the startup procedure in the manual and still there is no sound coming out of it. We were wondering if you could give us some more advice on other options that we could try to get the sound to work. Kind regards Tracy and Courtney
    Habit-Forming:
  • 61 Answers
Can you help us get sound from our Yamaha electron - 25273994-iaf424o4icq33yejy52n3jve-2-0.jpg
HAVE YOU TRIED THIS?
Posted on Dec 24, 2014
3 Suggested Answers
  • 1212 Answers
SOURCE: Repairing Yamaha psr-12
If the power adapter is not the original adappter- check to make sure the polarity is correct- it should be marked on the keyboard near the adapter socket, and also on the adapter itself.
The keyboard should have an internal fuse- check that. Then with keyboard open, if the fuse is okay, trace the power flow from the power pack and look for broken wires, bad solder connections, stressed components like bulging capacitors, etc. It may have a burned out zener diode in the power supply regulator portion of the main circuit.
Posted on Mar 30, 2012
SOURCE: yamaha electone organ no sound-
Yamaha electone organ el25 no sound
Posted on Sep 17, 2013
Where can I buy a manual for electone HC2
Retrevo has a link to the manual for the Yamaha Electone HC-2 organ here: http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=42cf1723b6ae869802a215f20e1c7dc1&modelid=961462&q=Yamaha+HC-2 . You will need to enter a code to access the manual. You can check if Yamaha has copies for sale. You can also download the manual from the Yamaha downloads page: http://download.yamaha.com/top/?site=usa.yamaha.com&language=en . Just search for the HC-2.
I hope this helps.
Dec 21, 2015 | Music
Yamaha p85 no power, no on light
Try testing the adapter .If its O.k.then your adapter socket may have lose solder or track broken near the socket.
Jan 20, 2014 | Music
Yamaha EL70 organ - no sound.
This site offers a free onliine manual. http://www.nodevice.com/user_manual/yamaha/electronic_organs/el-70.html
I hope this helps you out!
Apr 18, 2017 | Music
The keys are broken and some at no sound can I order the notes and sound kit. Yamaha PSR-295 . Regards Elias
Hi, i think you can. You can go to any of the Yamaha companies around you area and explain to them the problem of the keyboard. They will give you good and quality replacement part for your Keyboard.
Make sure you go to only Yamaha company to avoid getting a wrong part for your Keyboard.Avoid road siderepairsforissue like this,it's more complicated to handle
I guess that will do.
Thanks for using fixya...
Jan 12, 2011 | Yamaha PSR-295MS Portable 61-Key...
My hihat controller has a problem sounds become
Make sure you aren't mixing up the cord for the hi hat pad and the hi hat controller.
Jan 17, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Yamaha clavinova CLP200 the amp has lost power
I might suspect that the volume control itself may have a break in the resistance element by your description. There can be many causes however including LOOSE CABLES. IF the unit has been moved recently, then a loose cable MIGHT be the cause. In any case, servicing iis required. If you are not familiar with electronic repair you will need to find an experienced repairman.
Nov 08, 2009 | Yamaha Music
Yamaha electone organ no sound-
Check if you may have knocked off the speaker leads OR ones to an expression pedal.
Sep 16, 2009 | Boss Micro BR Digital Recorder
Keys not sounding as loud as others
Hi, BHOWDY.
Probably the best thing to do is call the Yamaha service center nearest you. I live in the Los Angeles area, and the Yamaha service center closest to me is in Buena Park. I called them on the phone and told them what the problem was, and they knew immediately what parts were needed and they shipped them out that same day.
The contacts that seem to wear out the fastest are the ones near the middle of the keyboard. On my CLP-170, it's the keys between middle C and the G above that -- probably no more then 4 or 5 keys. However, I ordered replacement contacts for all 88 keys because once you take the piano apart to replace the contacts, you may as well replace all of them.
Good luck, Howard
Sep 29, 2008 | Yamaha Full-Size Keyboard
DTXpress III Special Yamaha Drum Kit - high hat won't sound closed
solution!! you go to "voice" hit the hihat pedal, then press "page" till you get to hhat ofset and bring the value to negative. approx -25. pressure that you applied to hhat pedal becomes less
Sep 19, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
Music Logo
63 people viewed this question
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
