Question about Allis Chalmers AC130 46" 23HP All Wheel Steer Lawn Tractor
I have a 130 Allis-Chalmers all-wheel-steer want to know how to change the motion drive belt
  • Marylou Dagenais
    Marylou Dagenais Nov 10, 2014
    its the belt that connects to the engine pulley then goes to the transmision for the forward and reverse
My belt is sqceeling on my d17 when i try to turn it right but if i turn i left it does it it does not scqeel
'squeal'
'squealing'
Check the steering pump fluid level and the drive belt tension. Spray all your belts with belt conditioner spray.
For anyone else reading this and wondering what the vehicle is, we are taking about an Allis Chalmers D17 Tractor.
http://www.chatstractors.com/2009%20tractors/1477-Allis-chalmers-D17-left-side.jpg
https://www.google.ca/search?q=d17&sourceid=ie7&rls=com.microsoft:en-CA:IE-ContextMenu&ie=&oe=&gfe_rd=cr&ei=yV9QWKPOAu7L8Ae-rbX4CA#q=d17+tractor+steering
Dec 13, 2016 | Garden
410 allis chalmers
Specs Link:
Allis Chalmers 410
Parts Link:
Simplicity Allis Chalmers Mower Parts
Had a friend who took off his Yamaha branding on a Motorcycle and replace with AC brands - AC rocks.
Mar 03, 2015 | Garden
The power steering quit on my d17. It seemed like one side quit before the other. I already replaced the rack gear. Any suggestions?
D17 POWER STEERING has had spots when moving the wheel. It's not smooth steering at all and with a load you have to front be moving with the wheel turning real slow.I've drained the reservoir and replaced the suction hose.
Jul 18, 2010 | Dmm Allis Chalmers Tractor D17 Series 4...
When setting points on a CA Allis Chalmers Tractor. What should the gap be and do you do it on the lobe or flat service
Set the gap on the high spot on the lob,it should be set at around 50000 or twice the plug gap,this is just a rule of thumb,but changing the timing by turning the distributer will get the engine to max performance after this has been done.
Apr 07, 2010 | B&C Allis Chalmers Tractor B,c,ca Starter...
Spindle on 6060 keeps breaking are the front ends
Yes unfortunately they are.
I have personally taken them apart and welded and then welded in reinforcement pieces to beef them up.
Feb 03, 2010 | RTO Allis Chalmers W,wc,wd,wf,wd45 Tractor...
Allis chalmers AC 5040 is leaking water/fluid
looking for in the oil cooler inside the radiator maybe is broken.
Jul 11, 2009 | B&C Allis Chalmers Tractor B,c,ca Flywheel...
Allis chalmers 912 hydro belt diagram
I also have the same tractor but i have what your looking for so my email address is rickralston73@yahoo.com
Jun 27, 2009 | RTO Allis Chalmers Tractor 8010, 8030,...
Allis Chalmers AC130 46" 23HP All Wheel Steer Lawn Tractor Logo
59 people viewed this question
Top Allis Chalmers Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Allis Chalmers Garden Expert? Answer questions, earn points and help others
