Question about Kenwood DDX7019 6.95 in. Car Monitor
Working a DDX-7019, had to clean laser eye. After unit reassembly, and during functional check, during the load (or eject) process the front panel rotates down out of the way -but the gearing never st
I am an Electronics Tech with over 15 years experience.
4 Suggested Answers
otacon
  • 1944 Answers
SOURCE: kenwood ddx 7019 password reset
It looks like the unit has a code programmed into it in the past. If this unit is second hand try contacting the previous owner for the code. If it's new from the shop, then contact the shop. The last option is to contact Kenwood and they can reset the code for you. Unfortunately there is no other way...
Posted on Dec 23, 2007
  • 111 Answers
SOURCE: Password Reset Help
During code request:
Point the remote control to the screen and input these numers (fast as you can).
55222277
ps.
You will not see any change on the display untill you enter tha last digit.
LET ME KNOW IF IT WORK thank you
Posted on Dec 24, 2007
Daniel S
  • 4323 Answers
SOURCE: please help we bought a
Hi
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display. Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key "5" ( 2 times ) and press the Track UP/Next Track key * Press numeric key "2" ( 3 times ) and press the Track UP/Next Track key * Press numeric key "2" ( 1 time ) and press the Track UP/Next Track key * Press numeric key "7" ( 2 times ) and press the Track UP/Next Track key
The security is canceled. Hope this helps... Please post back if you need more information.
Daniel
Posted on Mar 21, 2011
Ferguson TV DVD fault - won't play discs
Check its loading mechanism for proper disc loading. Replace the loading belt first and check. If it does not help you, insert a cleaning disc into it. If the fault is with accumulated dust or dirt on the laser pick up lens, it will be cleared out. If not, replace the laser pickup unit.
Nov 27, 2012 | Televison & Video
Kenwood ddx 7019 password reset
Dec 23, 2007 | Kenwood KVT-617DVD Car DVD Player
Will not play
Hello Brandon
The fault is with its Laser Picku Unit itself. The sled motor, the motor that spins the disc inside the DVD player, should wok like this as you details here. Just see, when we put in a disc inside any disc player, it will sart spins, after it has been loaded properly into the mechanism. The the laser pickup unit will start scan the recording on the disc, reads it; recogonize its contents, then starts to play from the first track. This is an automatic process ot all disc players, and suring this reading process, the spin speed of the disc will vary, may stop, or rewind to a little and then spins again. This is a common process to all the playeres.
Here, with your DVD player, the laser pickup unit tries to read the tracks, but fails, the again it starts to readit, fails and finally show a 'No Disc' display, as it hasn't got any details about the recoding at the inserted disc.
There are three main causes for this fault. The first one is with a faulty strip wire. This wire is one, that connects the laser pickup unit with main board. You can see a flat ribbon type cable that connectes to laser pickup unit at the mechanism, to the main circuit board of the player. Replace this cable fist. This cable can be purchased from most of the electronic spare part shops at your town, and won't cost more.
The second chance is with dirty or dusty laser pickup unit lens. To cclean this lens, the easisest way is to put in a lens cleaning disc into the unit, play it for at least three times, by ejecting it out and get it into. This process will clean up any dirt or dust accululated on the lens, and will help you. The cleaning disc also can be bought from most of the electronic spare part selling shops at your town.
The third chance is with a faulty Laser Pickup Unit istsef. If so, there is no repair to this unit other than replacing it with same type and number. It is a skilled work, and you have to disassemeble and reassemble the deck mechanism. If you have experience to dothis, you can do it by yourself at home Ok
Please do rate this solution, if it found helpfull to you.
Dec 29, 2011 | Durabrand PDV-709
SAVV LOH-5120 The disc drive does not accept discs, ejecting them after failing to recognise them. I have tried cleaning the lense but to no avail. Is there anything I can do or do I need to get a...
Seems that the head is not working, there is no laser scanning and the possibility that the laser head can be defective.
Now certain cleaner disks will not be tracked to run for cleaning as it is not read. Hence it will reject. So it is ideal to clean manually the laser head eye using a cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Mar 28, 2011 | Televison & Video
Audiovox D2016 returning to the beginning during playback
the player is not able to read your disk ...if the disk is clean and it does the same thing for other disks as well then you probably have dust or debree on the laser ... on some players you can see the laser .. it looks like a little lens thats very springy ...you can clean it with a soft tissue wetted with eye glass cleaning fluid .. dont spray directly on the laser ...gently clean the laser lens .... if you cant see the laser with the lid open then you can purchase a DVD/CD cleaning disk ... that looks like a regular DVD but has little brushes mounted on it to clean the laser when you play it ....cleaning the laser usually works but if it doesnt then you could have a damaged or worn out laser .....just a single hair or particle is enough to keep the laser from working...
Apr 12, 2010 | Audiovox D2016 Portable DVD Player
Frigidair front load washer won't drain during spin cycle
The main reason these units wont drain is because the drain pump is plugged. Remove the front access panel at the bottom the pump is located on the right hand side at the front. Get rid of water in unit with a shop vac, disconnect wires from pump remove hoses clean out pump and rubber hose to the tub reassemble and try. good luck
Dec 19, 2008 | Frigidaire Washing Machines
CDJ 800 Bad Laser
Yes, sounds like you have a bad traverse assembly (laser). You can replace it yourself, however, I wouldn't suggest it, as you need to calibrate the assembly after the installation, and remove a solder bridge (which keeps the unit safe during transport). It is a little complicated, if you don't have experiencing doing this type of work. Taking it to a service center would be your best option.
You can purchase the part HERE
- Davis
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
www.1200s.com
Jul 17, 2008 | Pioneer CDJ-800 Turntable
Washer won't spin properly
It may not be draining properly, open the bottom front access panel ,3 screws on bottom front , remove the large filter access and watch for water spill.
clean of any debris. while down there check pump impellers for freedom of movement.
reassemble , then check under the rubber skirt and be certain no objects got under the tub.
Feb 27, 2008 | Danby DWM5500W Front Load Washer
Password Reset Help
55222277
ps.
Dec 23, 2007 | Kenwood DDX-6019 Car DVD Player
New DDX-6019
haha ok shipping screw in a double din unit i have never seen before but in dual which is a big pos. but there should and will not ever be a screw that holds the laser in on a double din unit because the laserated in the very middle of the player on these models. sounds like you have a defective driver so i would try and get it exchanged or call kenwood
Feb 05, 2007 | Kenwood DDX-6019 Car DVD Player
Kenwood DDX7019 6.95 in. Car Monitor Logo
60 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
