Question about Honeywell CT87N - Round Heat/Cool Thermostat
Ct87n thermstat is hooked up and the heater is on because i smell the heat but it is not blowing out the vent
    Master:
  • 602 Answers
The blower motor isn't running. At the thermostat, red wire to the R terminal white wire to W terminal.or W2 If the blower still doesn't run It's probably not the thermostat.
Posted on Nov 10, 2014
Car heater blowing cold air and rubber burnning
If your heater is spraying a light mist through your vents it could be your heater coil. Mine did the same thing, smell rubber burning, then started a light mist through the vents. If you don't get that checked out, it could mess up your water pump and possibly your engine
Jun 22, 2014 | 2000 Chevrolet Cavalier
No heat but blows cold air
Not if the engine is getting up to normal temp. Could be low on coolant or a problem with the heater core or a blend door under the dash.
Jan 24, 2014 | 2001 Saturn L-Series
Sweet-Burning Smell when vent is on
I am quite certain you have a leak in the heater core and you are smelling the leaking antifreeze. Check the coolant level for loss and look under the car where the water from the airconditioner normally drips.
Hope this helps you, Robert
Mar 26, 2013 | Worldwide 2002 Ford Focus ZX5 2.0L...
Installing a CT87N wiring matches up fairly well except for 1. white to O terminal green to G terminal red to RC terminal yellow to W terminal but also stripped in the middle and hooked to the A...
sounds like your yellow should go to either white or yellow and a jumper installed between the 2. then test both heating and cooling, may need to make co figuration change on how your reversing valve is energized.
Oct 13, 2017 | Honeywell CT87B ROUND HEATING&COOLING...
The heater core is going bad in my blazer, but it still blows hot air. When I turn the control to switch the heat from vent to defrost or floor, it still blows out of the vent. How do I fix this?
THAT HAS NOTHING TO DO WITH A HEATER CORE IF CORE IS GOING OUT IT WILL LEAK THATSOUNDS LIKE AN ACTUATOR ACTING UP OR VACCUUM LINE LEAK BEHIND DASH
Apr 06, 2011 | Chevrolet Blazer Cars & Trucks
I installed a honeywell CT87N thermostat. The
the burners light? if the burners dont light than it's working right the blower on the furnace comes on with the a\c
Jun 19, 2010 | Honeywell Electronic Programmable...
There was an electrical smell when the heat was on
Could be ,to be certain take it out the wall and check
Mar 07, 2018 | Cadet Manufacturing 67508 Coil / Ribbon...
Heater smell when AC comes on...
The fan that blows the air blows through the heater coils before it blows through the A/C.As long as the heater doesn't come on, there is not much that can be done. ZCooking the attic room will be a problem because it is the heat rises thing, and on top(literally) of it all, the roof is radiating heat.
Sep 21, 2009 | LG Heat cool Window Air Conditioner
NO HEAT FROM HEATER , FAN BLOWING OKAY , BUT NO HEAT , UNTIL YOU GO UP A HILL , THEN IT BLOWS HOT , FOR SHORT TIME THEN GOES COLD AGAIN
This sounds to me like the thermstat is is a low temp one, I would check and see what temp it is and replace it with a 195 degree thermostat. either it is faulty or as I say it is a low temp one. One other thing to check is that the gate valve on the heater vent / hoses is openning properly, and not stuck. Good luck and remember to rate all solutions that you get on FixYa, thanx.
Nov 02, 2008 | 2003 Kia Sedona
Honeywell CT87N - Round Heat/Cool Thermostat Logo
89 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
