Question about AMD Computers & Internet
<!-- from fixya rte -->How to set turbo clock speed amd a8 6410 - AMD Computers & Internet
  • 195 Answers
You cannot set the turbo clock speed. You have to have the black edition chip and turn off turbo boost then overclock as you would any chip.
Posted on Dec 24, 2014
I'm going to buy a new motherboard...... i found two interesting motherboards Msi x79 Bigbang xpower2 and msi z97x gaming 5 wich one is better and wich cpu should i take i7 4930k or i7 4790k !!!
I'm a MSI guy myself. I would go with the Z97. As for the processors, I would save the extra $150 to $200 and get the 4790k. Plenty of power, and you save some money on it. Use the left overs to purchase a good set of ram. Intel Core i7 4930K vs 4790K
Has a built-in GPU Yes vs No Somewhat common; A separate graphics adapter is not required Higher clock speed 4 GHz vs 3.4 GHz Around 20% higher clock speed Higher turbo clock speed 4.4 GHz vs 3.9 GHz Around 15% higher turbo clock speed Lower typical power consumption 71.5W vs 105.63W More than 30% lower typical power consumption Better PassMark (Single core) score 2,535 vs 1,995 More than 25% better PassMark (Single core) score Better cinebench r10 32Bit 1-core score 8,785 vs 6,903 More than 25% better cinebench r10 32Bit 1-core score Higher Maximum Operating Temperature 74.04 °C vs 66.8 °C More than 10% higher Maximum Operating Temperature Better performance per dollar 4.97 pt/$ vs 3.93 pt/$ More than 25% better performance per dollar Newer Apr, 2014 vs Jul, 2013 Release date 9 months later Lower annual commercial energy cost 77.09 $/year vs 113.88 $/year More than 30% lower annual commercial energy cost Lower annual home energy cost 21.2 $/year vs 31.32 $/year More than 30% lower annual home energy cost
Jan 13, 2015 | MSI Computers & Internet
Motherboard ID 07/28/2004-KM266-8237-6A6LYM4BC-00 **Above mentioned is the motherboard id of my motherboard. can u please tell me how much of the DDR can i use on my board? m using now one 512mb and...
Maximum of 1 GB per slot.
Yes, you can buy DDR400, it will be underclocked by the motherboard to DDR266. If you want some extra performance you can go in the BIOS and lower the timings one unit.
Yes, they will work, but not very fast. They should be used only as a last option.
Aug 03, 2010 | MSI Computers & Internet
My scooby 2l turbo only has 110 mph on clock,is it
remove the governor inside the transmission to get to the highest desired speed if you wish. That is done on all police cars
May 09, 2010 | 1999 Subaru Impreza
Hello , my server mainboards fsb is stuck at 100mhz , the board can support to 133mhz , but i cant set that speed in the bios , the settings are greyed out. my cpu supports a max speed to 1500mhz but now...
It sounds like the system is set to "auto" at the moment, OR the memory speed will not support the 133mhz fsb speed, check the RAM and see what the speed rating is. Leave the CPU multiplier alone, that may well damage the cpu.
Mar 30, 2010 | Matsonic MS8137C Motherboard
How to get AMD athlon 3700 socket 754 engineering sample cpu run at proper speed
Here's a little history
http://compreviews.about.com/cs/pchardwarebasics/a/aaBIOS.htm
More advanced stuff
http://compreviews.about.com/gi/dynamic/offsite.htm?zi=1/XJ&sdn=compreviews&cdn=compute&tm=128&gps=215_11_1267_540&f=00&su=p284.9.336.ip_p504.1.336.ip_&tt=2&bt=0&bts=0&zu=http%3A//www.adriansrojakpot.com/Speed_Demonz/BIOS_Guide/BIOS_Guide_Index.htm
Some systems have "bottlenecks," where small overclocking of a component can help realize the full potential of another component to a greater percentage than the limiting hardware is overclocked. For instance, many motherboards with AMD Athlon 64 processors limit the speed of four units of RAM to 333 MHz. However, the memory speed is computed by dividing the processor speed (which is a base number times a CPU multiplier, for instance 1.8 GHz is most likely 9x200 MHz) by a fixed integer such that, at stock speeds, the RAM would run at a clock rate near 333 MHz. Manipulating elements of how the processor speed is set (usually lowering the multiplier), one can often overclock the processor a small amount, around 100-200 MHz (less than 10%), and gain a RAM clock rate of 400 MHz (20% increase), releasing the full potential of the RAM.
AMD also produced x86 designs which competed with Intel on performance rather than price. In January 2002 the Pentium 4 gained a lead in sales and AMD marketing responded by giving their processors numeric suffixes approximating the clock rate that an AMD Thunderbird (and by inference a Pentium processor) would need to give matching performance, openly undermining the "megahertz myth".
May 15, 2009 | Computers & Internet
AMD k6-2
the problem is xp which makes with an older K6-2 the clock speed lower. It takes a lot for a machine to run XP.
The best way is either go back to 98 or the only way could be ME.
not much what you can do about it otherwise
Apr 30, 2008 | AMD K6-2 , 450 Mhz
Fastest socket A processor?
i think you will find that you are in fact using the fastest speed processor for the socket 'A' type of motherboard as AMD has changed to socket 754 or 939 for dual core processors. You can clock the speed a little in the bios, if you go to the peocessor section in the bios and look at the clock speed probably set at 133MHZ you can move it up 1 increment at a time, eg 134MHZ and keep trying until the pc wont boot up, at which point you will have to reset the cmos settings JBAT1 terminal and then set it again to the fastest you got it to before it wouldnt boot.
Aug 31, 2007 | Syntax SV266A SKA KT266A Motherboard
Computers & Internet Logo
106 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
