Question about Insignia Televison & Video
Coming on and shutting off on its own wont channel surf
WONT DO AUTO CHANNEL SCAN, WONT DO ANYTHING. IT WILL NAVIGATE THE MENU BUT WONT SCAN CHANNELS LIKE IT LOCKED UP
Main system control memory IC fault. Check and replace it. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Mar 07, 2016 | Televison & Video
Hisense 55h6sg comes on to logo screen but wont bring up cable channel
Corrupted software. A firmware update is necessary. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 17, 2015 | Hisense Televison & Video
I bought a sony bravia from amazon in 2009 in the last few weeks when i go on channel selection it sometimes cuts out if i try and scroll through channels it wont scoll or takes ages and then cuts out
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Sep 30, 2014 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Bek
Main system control memory IC fault. Contact any service technician to replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 05, 2014 | Televison & Video
What makes my Sanyo DP32746 shut off when I press channel up button?
Main system control memory IC fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 01, 2014 | Televison & Video
Olevia tv
This is not the fault with its remote control. Check and replace its tuner. Contact any service technician. Try these codes. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 07, 2014 | Televison & Video
My tv channels surfs on its own wont stop. have to unplug to stop
What you got here is common. The issue is the controller under the volume and channel and power butoons, This is defective!! your going to need to have the tv serviced. this part cost $75-90 bucks the labor may vary in your area. Please do be considerate as you recieved this info FREE when leaving feedback and ratings today.
Apr 28, 2010 | Vizio VW37L 37 in. LCD HDTV
Tv wont turn on
try to plug in again...if there's no reaction at all, then the power suply section may checked...(I.C. regulator str.... followed the horizontal output transistor or some of the zener diodes regulator or broken PCB line
Jul 30, 2009 | Sony KV-27S42 27" TV
Continues to channel surf wont stop on ant station
When i had the same issue, i used VCR or VCR Combo to set the channels,
May 14, 2009 | RCA R52WM24 52" HDTV Projection Television
Tv shuts off
you a probablyt enter in service mode for that tv set ,contact a service man
Dec 30, 2007 | Sharp 27C-240 27" TV
Televison & Video Logo
29 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
