Question about Garden
How to replace gas vent on huaqvarna 51 chainsaw
How to replace gas vent on husqvarna 51
  • Ken Hollyhurst
    Ken Hollyhurst Dec 19, 2016
    There seems to be confusion on some sites between the fuel feed tube and the fuel tank vent, they are different. The fuel tube feeds fuel to the carburettor from the tank, it has a filter on the end inside the tank. to renew the tube;
    Empty the tank! Disconnect the tube from the carburettor, super glue a new tube onto this end of the old one ( use a bit a plastic rod, or the like to just fit inside both ends), a spot of oil on tube, then it pulls through into the tank as you pull the old one out. Cut off the join then refit the filter, best to use a new filter. Cut tube to length and refit on Carb stub.
    The fuel vent line is a plastic pipe, visible from the inside at the top(handle end) of the tank. It is a push fit on my 51. There is a little, two screw, plate on the outside at other side of the saw remove it and to the side of it, down the deep hole is the vent. A Husqvarna kit is a plastic pipe and a little white porous vent plug( BEWARE VERY SMALL ) THIS CAN EVEN FALL OUT IN GENERAL USE LEADING TO FUEL SPILLAGE WHEN FILLING! Carefully press home the new one, with its white plug fitted.
  • 1,169 Answers
Disassembly
The fuel tank vent is located on the right side of the fuel
tank next to the right rear rubber element. With the fuel
tank empty and the fuel hose disconnected at the
carburetor, remove the two rear rubber elements. Separate the rear of the crankcase and the fuel tank enough to expose the fuel tank vent. Working through the fuel filler opening, grasp the fuel tank vent tube with a pair of needle nose pliers. Push the vent out the other side.
For access to the right side rubber elements, first remove the chain brake cover, bar, chain, chain catcher and cover plate.
For access to the left side rubber elements, remove the starter housing.
Assembly
Install the fuel tank vent using a drift the same diameter
as the vent tube. The remainder of assembly is the
reverse of disassembly.
Posted on Nov 09, 2014
steve_lima
  • 181 Answers
SOURCE: How to replace the Husqvarna chainsaw fuel line.
let me knoe the model number and i'll see what i have....
Posted on Feb 11, 2009
  • 120 Answers
SOURCE: I need to know oil/gas mixture for husqvarna chainsaw
40 to 1 is the ratio.
Posted on May 05, 2009
  • 86 Answers
SOURCE: husqvarna chainsaw leaks gas when filling
HI. IT SOUNDS LIKE YOU MAY HAVE A PROBLEM WITH THE FUEL LINE, WHEN YOU TURN IT ON ITS SIDE THE FUEL MAY BE LEAKING AROUND THE SEAL ON THE FUEL LINE OR EVEN POPED OUT. ITS HAPPENED TO ME BEFORE. JIMBO
Posted on Sep 14, 2009
dontbother10
  • 2220 Answers
SOURCE: is there a hose that attaches to gas tank vent on
You can find an answer to your question here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Uncheck "Manuals" check "Illustrated parts lists"
I think your answer is on detail "J"
pns 503 60 04-01 and 501 62 98-01.
All fuel system components can be found on these illustrations. I wish Husqvarna included nomenclatures but they don't. Your local Husky may be able to verify by telephone these are indeed your fuel vent.
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
It might be a good idea to save a copy of both your Manual and the IPL to your computer. HTH
Lou
Posted on Nov 08, 2009
  • 2239 Answers
SOURCE: need to know the ratio
Use a ratio of 50-1 with Husqvarna two stroke oil, with other two stroke oils they recommend a 25-1 mix as they do not know the quaility of other manufactureres two stroke oil, always try to use Husqvarna oil.
Posted on Sep 25, 2011
REPLACE CHAIN BAR STUDS 55 RANCHER
Tom, Check the attached links,instruction and guides on Husqvarna chainsaw, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Husqvarna rancher 55 chain bolt replacement
http://www.husqvarna.com/ddoc/HUSO/HUSO2002_USen/HUSO2002_USen__1140106-95.pdf
How to Change Chain on Husqvarna Chainsaw Model 445
How to Adjust the Oiler on Husqvarna 55 Rancher
Apr 02, 2016 | Husqvarna 36 41 50 51 55 136 141 154 254...
Where to find vent line on 359 husqvarna
Husqvarna chainsaw fuel line check and replace - YouTube
? 3:44
https://www.youtube.com/watch?v=8FyU_fG9qwc
Feb 6, 2012 - Uploaded by mweba1
359. ... Husqvarna chainsaw fuel line check and replace. mweba1. SubscribeSubscribed .... You will want to inspect the tank vent and fuel line.
Husqvarna common air leak - YouTube
? 1:51
https://www.youtube.com/watch?v=Z7f9zNQTJBQ
Apr 11, 2012 - Uploaded by mweba1
Husqvarna common air leak ... Husqvarna 136 ChainsawCarburetor Rebuild & Fuel Line Repair - Duration: 22:39. by donyboy73 59,377 views.
Husqvarna 359 Professional Chain Saw Review
Dec 14, 2015 | Husqvarna Garden
Husqvarna 65 cutsout cuts two blocks
check tank vent and the coil,to see if vent is plugged,and the coil gets hot
Mar 12, 2015 | Husqvarna Fuel Gas Line Hose 501462501 65...
What is the gas/2 cycle oil mixtuure for a husqvarna 55 chainsaw
These saws were normally ran on a slightly richer mix. The reason was becuase of the mix oil available. I would recommend running a 40:1 or 50:1 mix. Make sure you use an "FD" rated mix oil and Premium ethanol free fuel.
The premixed fuels / oils are even better. They contain the FD rated oil 95 octane fuel and no ethanol.
Jul 20, 2014 | Husqvarna Chain Saw Models 51, 55
Fuel tank air vent leaking
http://www.mediafire.com/download/j8bz118bhm1n6jm
Replace vent, it should allow air in but fuel shouldn't leak out.
Apr 05, 2014 | Husqvarna Garden
Huaqvarna chainsaw 240 runs then quits
when ??? dies at wide open throttle ??? dies at idle ??? dies it restart right away or take an hour or more ??? did you put the right 2 cycle mix in the gas tank ???
Nov 27, 2013 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 51 will not start
Two things to check, ren=move the flywheel and check the key has not sheared, remove the muffler and check the condition of the piton through the open exhaust port, any signs of scuffing or damage and the saw will have to come apart for further investigation.
Oct 19, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 141 clogged fuel vent
The breather is made of a sintered brass plug and beneath this ia what i call a duck bill valve ( because it looks like a ducks bill ) this is a one way valve green in colour which allows air one way into the tank, to test correctly you should do a vacume test via the fuel hose, to remove the valve will normally destroy.
Jun 23, 2012 | Husqvarna 36 41 50 51 55 136 141 154 254...
Garden Logo
869 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
