Question about Dishwashers
Fisher Paykel D603 f1 code top drawer only, bottom one has no power and locked
Diagnostic code F1 on top drawer (no power on bottom which is locked). Tried the start/lock on top drawer but machine quickly reverts to F1 code. I read that this may mean that the Heater Plate may need to be replaced. How do I unlock the bottom drawer to check for water behind) and verify proper function of Heater plate. Any suggestion or drawing on unlocking bottom drawer and locating heater plate. Thanks in advance.
    Habit-Forming:
  • 77 Answers
Check out www.ApplianceRepairLesson.com. I hope this is what you needed, and it works for you. Good luck!
Posted on Nov 08, 2014
Testimonial: "Thank you. I did get a hold of the folks at Fisher Paykel and conrirmed it's the heater plate. I gently forced the bottom drawer open and hope that it'll slide back in when power is restored and lid slides open. Will check the website you mentioned for some How To take the heater plate off and replace. Thanks again."
reg501
  • 413 Answers
SOURCE: fisher paykel dish drawer
The motor impeller is located inside the tub.
To remove/inspect:
1. Remove dishrack and filter
2. Twist the strainer lock ring counterclockwise to disengage.
3. Lift and remove strainer and lock ring assembly
4. Remove impeller, inspect for damage and/or debris in sump.
Hope this helps....
The F1 code is retained in memory as the most recent fault (may have happened awhile ago) and may not be related to the current issue.
However FYI
F1 code can be caused by several things:
1. Defective lid motor(s)...Each drawer has two lid motors that pull the lid tight to the drawer when the cycle is started. (this was very common on early models)
2. Something too tall was placed in the drawer preventing the lid from closing completely.
OR
3. (only seen this once) the drain hose developed a crack causing water to leak only when draining.
Posted on Jun 17, 2008
vitg55
  • 78 Answers
SOURCE: Fisher Paykel F1 error / double dishwasher drawer
F1-water on bottom of dishwasher. Uselly it cost by broken drain hose. Need expert tech to fix the problem.
Posted on Dec 01, 2008
SOURCE: Fisher & Paykel single drawer dishwasher F1 flashing.
F1 indicates a problem with the Flood sensor. I cleaned all the filters etc. removed the drawer viewed under the drawer, it was dry. There is nothing further I can do, so called the Appliances repair person and booked an appointment for him to determine if an outlet hose is blocked or has a hole in it or whatever. Thanks for all the suggestions Blokes. I'm technically challenged. Happy New Year
Posted on Dec 29, 2008
SOURCE: Fisher & Paykel dishwasher:
Turn off dishwasher's circt braker at distribution panel (usaly located in garage or in basement)
1. Open lower drawer
2. Push in two plastic buttons at front lower corners.
3. Remove drawer from railing
4. Remove water from bottom of dishwasher
5. Use hair drier to dry off bottom copartment, specialy in left corner at floding switch location.
6. Install drawer on the rail in position when plastic buttons pup up
Posted on Apr 21, 2009
  • 3247 Answers
SOURCE: My Fisher Paykel dishwasher is
F1 error means the flood switch in the drawer is activated. If there is water inside when you open the drawer then you will have to manually empty it with a small container.
Most likely the solenoid that controls inlet water is faulty or the water level sensor is faulty.
Try turning the mains power and water off and on again and run dishwasher. If fault persists then you may have replace the parts.
Posted on Nov 12, 2009
F1 error on Fisher and Paykel Dish Drawer
Sorry did not see your problem report earlier. If you have checked the sensor under the bottom drawer and it is dry, then F1 is caused by top drawer power filter fault. This means the bottom drawer controller is giving the F1 error but the top drawer controller has no power. Can you confirm this.
Apr 08, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 flood switch is on
The F1 code in both drawers could mean flood at base of dishwasher (under bottom drawer) . If it is occuring only in bottom drawer then it is likely the power circuit for top drawer is blown.
Need to know which of the above to give advise on how to fix.
Feb 02, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel dishdraw model DD603
P2 is for drain. Make sure there is a bit of water in the base of drawer before you start P2 otherwise the rotor may rub and burn. You can run the diagnostic with drawer open. Be careful not to start P1 as the wash water will splash and flood the dishwashwer.
Jan 28, 2013 | Fisher and Paykel Dishwashers
F1 code
F1 is a flood sensor fault code. The problem sometimes comes from loading the machine above the top of the drawer. When the inside lid comes down before the dishwasher starts, it cannot seal completely and water can spray into the outer cavity. The water accumulates in the inner bottom where there is a sensor. The sensor protects the electronic components from getting wet by warning you of the water which you cannot see. The solution is to remove the bottom drawer and wipe out, then dry the compartment with a fan or a small space heater. Once dry, the machine will function as usual.
Jan 24, 2013 | Fisher DD603FCSS Dishwasher
Fisher & paykel fault "F1" is displayed on the top
hello
F1 means the flood sensor senses water at base of machine at PC board.
You need to take out bottom drawer and check for water puddle under where the drawer was.If there is water you can get the machine going again by comletely drying it out(F1WILL CLEAR),but it still means you have a leak.With bottom drawer out you can really see whats going on.Once F1 is clear you can actually run upper drawer and see if it leaks.Most likely culprit are the lid actuators.Replace all 4 . It'll run like new.Don't overload drawer .That can cause lid leak too.Also the PC board may be damaged and may start to go crazy giving fake F1 codes.$80 easy fix.
good luck
Jul 27, 2011 | Fisher and Paykel 23 in. DD603H SS...
Dishwasher beeping and displaying F1 on screen. HELP!!
F1 error means that the flood switch has been activated. To reset the flood switch you need to remove the bottom dish drawer to be able to access the reset buttons. To remove the drawer you press in the rectangle buttons and slide them back under the drawer, they are located right behind the front panel at the bottom of the drawer. It may help to have someone help hold the drawer for you. Once they are slid back all the way place the bottom drawer on the floor to the left side of the washer as you look at it. This will give you the access you need. Lie down on the floor so you can see in the bottom. There you will see a white coloured plastic box on each side, one is for the top drawer the other is for the bottom drawer. Make sure the power is off to the dishwasher. Place your finger underneath the box and you will feel a small pin/lever. This is attached to the magnetic flood switch and resets it when you click it one way and then the other. Once you have done this turn the machine back on before you put in the bottom drawer as if it does not work then you will need to activate it maybe a couple of times. Once the F1 alarm disappears you are good to go. Place the drawer back in the opposite way to removal. Slide one rack forward and rest the drawer on it. Then slide the other side out and it will snap lock into position.
Mar 17, 2011 | Fisher and Paykel 23 in. DS603H W Built-in...
F1 code appeared during wash cycle..
The Ever- So- Helpful Diagnostics Mode -----
Getting into the Diagnostics Mode:
Press the LOCK and START / PAUSE buttons simultaneously and hold for 5 seconds.
The unit will beep once
Press the POWER button once, and you are now in diagnostics mode.
Pressing the START / PAUSE button sequentially advances the machine through the various functions you will want to test.
Start and stop each function by pressing the LOCK button.
A strong word or caution: DO NOT ENERGISE THE HEATER PLATE function (ER) without water in the tub or the heater will burn out.
The tech sheet containing all fault codes, test values, and a schematic is located behind the lower drawer at the back wall.
Exit diagnostics by pressing power off.
Q: F1 ERROR. The unit is beeping, both drawers are flashing F1 and won't stop running.
A: Your appliance has experienced the ubiquitous F1 flood error. The only way to stop the beeping is to remove power. Your course of action depends on the next step. You need to look BEHIND the lower unit drawer. Remove power, then open the lower drawer all the way, and press those plastic tabs (down at the sides, along the bottom and just below the round buttons)- inwards. Now slide the drawer out a couple inches more. You can now see behind the drawer.
Is there water in the catch pan? If no, the Mains Filter Board beneath that plastic cover in the back is bad. It thinks it's flooded while in fact it is not. Replace it. (PN 525959P) It is also remotely possible that one of the wiring harness is faulty.
If there IS water back there, you need to find where it's coming from. Usually, the fill (PN 526836) and drain hoses (PN 527137) are NOT at fault. Go into Diagnostics Mode, and operate the water fill valve (FV), and look for leaks at the valve and along the fill hose as the tub fills.
(You'll want to remove that large plastic cover in the back to see the valves and hoses coming from them. Lift the drawer off its rails and set it off to the left if there's space for it. Upper drawer, set it on top of the bottom drawer).
Operate the drain pump (P2) and look for leaks in the drain line. If no water is seen leaking from those sources, go on to the Lid Motors and the Link Supports.
First inspect the link support (that white plastic rod that spans the tub service lines). They typically snap in two at the mid span point. If it's snapped, there's your problem. Replace it with the updated link support. (PN 528437) Also run the Lid Motors (LD). As they transition up and down, do they respond strongly, or do they sound weak and labored? If the motors are in a white plastic case, you have the old motors and they will need replacing soon anyway. When they grow weak their ability to pull the seal down strongly is diminished (PN's 528112 Top, and 528113 Bottom)
Should you get an F1 error code on the TOP UNIT ONLY, it means that the LOWER UNIT has experienced some failure in the Water Heating Circuit. You will need to test those components to detect what has failed. Get out the trusty schematic and your multimeter!
Feb 26, 2011 | Fisher and Paykel Dishwashers
We have a 23" Fisher&Paykel dishwasher and got
The F1 error coming on top drawer when operating bottom drawer is due to the thermal fuse blowing up on the bottom drawer and shutting controller power.
The thermal fuse could have blown either as a normal component failure or heater over heated due to thermostat failure. In any case this can be repaired by replacing the whole heater assembly as all the parts are integrated.
This is at the underside of the drawer and will need a technician to replace unless you are very familiar with repairing electronic dishwashers. The part look like this.
The way you have described the onset of the F1 error is not due to flood switch. You can confirm that the lights on the bottom drawer are out even though the top drawer is showing F1 and beeping.
If problem was flood switch then both drawers would show F1.
Nov 25, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
F1 error
The heater unit in the bottom drawer is blown. This causes power to shut off to the controller. The effect of this is the F1 error on the top drawer.
If you get the heater on bottom drawer fixed, that should take care of the F1 error in the top drawer.
Jul 11, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
98 people viewed this question
Top Dishwashers Experts
