Question about DigiWeigh Digital 50 pound USB Endicia Compatible Postal Scale
The second number from the right breaks up--like a fluorescent light that doesn't work in some areas. For example: the zero/0 looks like a capital L. Any ideas?
    Top Expert:
  • DigiWeigh Master
  • 37,915 Answers
The display could be defective.
Posted on Nov 07, 2014
Testimonial: "Any way to fix it?"
The model number is: Lithonia Lighting Model # OALS10 65F 120 P LP 3.0476 already installed and doesn (105) Wall-Mount Outdoor Metallic Fluorescent Area Light
You might have to adjust the light sensitivity of the unit... also check for power to unit if it has one with a voltage meter.
Oct 18, 2016 | Hardware & Accessories
HYPERTECH MAX ENERGY CODE 6F
VIN numbers are often difficult to read and numbers get transposed. A capital "o" looks like a zero, etc. And transposition has happened at the DMV when title changes etc. My best advice is to look at the VIN as posted on the door frame sticker. If it's not there, you vehicle may be less than not-stolen. In that case look to dash, drivers side, base of windshield for riveted plate. CAREFULLY copy the VIN as stamped. Pay particular attention to O vs zero. Zero will usually look like a capital O with slash through it. Another misread is between numbers 3 and 8. When front half of 8 gets worn it looks like a three.
Mar 21, 2014 | Vehicle Parts & Accessories
How to closed zero dial in this phone set
phone circuits included electromechanical relays which imposed limitation on the speed of dialing a digit, and therefore dialing a complete 10-digit telephone number could take up to ten seconds, during which hardware resources had to be dedicated to a circuit. The Bell System organized the numbering plan to minimize the cost of providing automatic dialing to large population centers. The second digit of all area codes was 0 or 1, while the second digit of the exchange triplet was never 0 or 1, thus facilitating the recognition of whether a user was dialing a full 10-digit number or merely dialing within the local area code. In this coding scheme it was not yet necessary to dial a leading 1 for access to long distance circuits to other area codes. In some regions, local numbers were 7 digits, or occasionally less, but a toll call within the area code required a preceding 1. Area code 617 in eastern Massachusetts used this system in the early 1970s, while the Chicago area (312) did not. In the Chicago area, one could call the Boston area by dialing only 10 digits, while in Boston, to call Chicago, one would be required to use 11 digits, including the prefix 1.
Dec 19, 2013 | NEC Lands Phones
I am having trouble figuring out how to enter problems to find logarithmic functions
Let me give you a general recipe to familiarize yourself with any calculator, if you are averse to reading the manuals.
Most function will work in one of two ways.
1st way
Enter the number, then press the key,; the result is displayed.immediately.
Second way
Press the function key ( a left parenthesis may be displayed) enter the number (close the right parenthesis if there was a left one) press the = or EXE or ENTER keys.
Try the two ways described above to calculate the following values. The answers are given. Here log is he decimal logarithm and ln is the natural logarithm.
log(1)=0
ln(1)=0
ln(2)=0.693147181
log(2)=0.301029996
ln(100)=4.605170186
log(10)=1 (= number of zeros after the 1)
log(100)=2. (= number of zeros after the 1)
log(1000)=3 (number of zeros after the 1)
log(10000)=4 (number of zeros after the 1)
Aug 17, 2011 | Texas Instruments TI-30 XIIS Calculator
How do I put a limit in my TI-89 with it saying 'to few arguments'?
Make sure you give it the appropriate number of arguments. The limit() function takes three or four arguments.
  1. The expression. For example, sin(x)/x
  2. The variable. For example, x
  3. The point at which the limit is to be taken. For example, 0
  4. (optional) The direction from which the limit is to be approached, negative for from the left, positive for from the right, 0 for both. Defaults to zero if not given.
Sep 08, 2010 | Texas Instruments TI-89 Calculator
I CANT OPEN MY SENTRY FIRE-SAFE MODEL:DS3431 SAFE. I KEEP TRYING TO DO WHAT THEY SAY DO TURN DIAL TO ZERO, TURN KEY ETC; NUTHING IS WORKING. CAN U HELP?
Make sure that the key barrel is all the way out. Then replace this example code with your factory code and try it
Example combination: 70-55-05
  1. Do two rotations to the left stopping at 0.
  1. Do two rotations to the left (Anti-clockwise) on the third time past 0 go to your first number.
So – 0 to 0, 0 to 0, 0 to 70
  1. Do one rotation to the right (clockwise) on the second time round stop at your second number.
So – 70 to 70, 70 to 55
  1. Turn directly from your second number to your third number heading to the left.
So – 55 to 05
  1. Push down the handle.
Dec 13, 2009 | Sentry Fireproof Safe
Sometimes when I use a formula in Excel 2003 it will not calculate - it is as if the formula does not exist. an additional problem is that when the formula works it will not calculate several columns if...
Make sure, when you entr a formula that you hit the ENTER key instead of just moving to tyour next cell. To have all numbers added or moved, use the"Special" application, or change the value. Such as -if you are working in text mode and you enter numbers, they are only numbers in text mode. They don't have a value. Correct the cells to reflect numbers. Right click, format cell - select what you want.
Nov 05, 2009 | Microsoft Office Excel 2003 for PC
Take input from user and tell either the letter is capital or small a...z A...Z should be solved with if else statement
Use asci code:
char input[]; or string
if(intput[0] <=90 && input[0] >=65) write capital
if(intput[0] <=122 && input[0] >=97) write small
or easy:
if(intput[0] <='Z' && input[0] >='A') write capital
if(intput[0] <='z' && input[0] >='a') write small
input[0] it's the first letter.
If you wanna use the asci press and hold alt then input the number in the Num Lock from the right (only!!) then relyse the alt the it's will write the char from the asci you write.
Rate me please, thanks.
Jul 12, 2009 | Computers & Internet
Key in invalid
Ensure that any zeros are typed in as a numerical 0 and not the letter O (Oh)that is what springs to mind first. Double check that all letters and numbers are entered correctly into the boxes in the correct order it is so easy to make mistakes. I manually use shift key for capitals and never caps lock if the key needs entering in capitals.
Jun 16, 2009 | Microsoft Windows Vista Home Premium with...
How do you make you r letters capitol on sign in page for email
You can make the letters capital just by pressing "0" key
"0" key here works as a SHIFT key of computer
You will notice that when you press this key, there is a
change in upper right corner, for example look like this:
"abc" All small letter
"Abc" First capital and others small
"ABC" All small letter
Jan 14, 2008 | Cell Phones
DigiWeigh Digital 50 pound USB Endicia Compatible Postal Scale Logo
60 people viewed this question
Top DigiWeigh Office Equipment & Supplies Experts
jasbo
jasbo
Are you a DigiWeigh Office Equipment and Supply Expert? Answer questions, earn points and help others
