Question about Stihl Hs 81, 86 R, Rc, T, Tc Trimmer Parts Manual
How do I change the clutch drum on my stihl hs81R hedge cutter?
The engine runs ok but the cutter bar does not move back and forward. I suspect that the drive gear has sheared off the drum.
    New Friend:
  • 21 Answers
Hi all, I see a few people are in need of this question been resolved so heres the answer.
1st, of all you need to take off the gear box plate using a torx 27 tool to remove the 6 torx bolts.
2nd, you will need to remove the internal spur gear and connecting rods possible the full blade.
3rd, remove the external circlip that holds the drive pinion gear in place.
4th, you will need to remove the air filter cover
5th, next is the 3 torx bolts holding the gearbox casing to the engine 1 is at the back wich can be accessed through the ring that covers the rear anti vibration springs. the other 2 are either side of the casing sunk down a little bit. hopefully these can be easily located.
6th, next is the pull start housing/ top casing.
7th, at this point you should be able to carefully lift the engine out of the lower casing and get access to the clutch drum.
8th from the gear box side carefully tap the drive gear out of the bearing.
9th, give the gear box a good clean out to remove any old oil and any metal filings that may be hanging around.
finally re fitting is pretty much the reversal of this step by step although 1 thing to take into consideration is when putting the new clutch drum in be sure to have something softer than the clutch drum to tap it back into place using the centre of the clutch drum to avoid any possible damage on refiiting.
1 final thing, good luck. and don't forget to refill with grease
Posted on Mar 16, 2015
How do I change the clutch drum on a stihlHS81R hedgtrimmer?
I have upload the SM for this unit to my google drive so be able to view and download it from there.
STIHL HS 81 86 RA 442 00 01 01 pdf Google Drive
Nov 08, 2014 | Stihl Garden
Stihl hs86 set blade gap
You shouldn't have to set a gap.. the gap between the blades is 'pre-determined' by a spacer between the blades that each 'blade bolt' passes through. You should be able to tighten up the blade bolts and the blades should still move. If they dont, then the spacers are worn and need to be replaced.
Apr 02, 2014 | Stihl Hedge Trimmer Pruner Cutter Blade...
Stihl HS 81 RC
You may be trying to cut material that is too large
Oct 05, 2013 | Garden
Stihl hs81r
The HS81R Is a hand held hedge cutter, not a chainsaws
Oct 15, 2010 | Garden
Stihl strimmer engine runs but wont cut grass the head wont turn what cuts grass
First take the head off and look for grass, weeds and string wound up in there. A lot of times that's the problem.
Next, with the head off and the switch in the off position, pull it over a few times and see if the shaft spins. If not, could be a broken shaft or a bad clutch.
Apr 04, 2010 | Oregon Scientific Complete Carburetor for...
Need alternative spark plug for stihl hs81r
STIHL recomends a Bosch USR-7AC
Nov 23, 2009 | Garden
Chain stops under load ms 660 stihl
your centrifical clutch need to be replaced there is no adjustment,I hope this helps you?
Oct 01, 2009 | Garden
Thihl HL75 hedge trimmer engine will not run at full speed
Remove the cutting attachment, insert a screwdriver in to the shaft receptor and it should operate smooth with a slight bit of friction. if not then check the blade bolts and make sure the blades move freely. Lubricate the blades and the gearbox regularly. If the attachment end is good then turn the driveshaft by hand (with attachment still off shaft). If this too moves freely then go to the clutch.
Apr 04, 2009 | Oregon Scientific Complete Carburetor for...
Stihl Hs 81, 86 R, Rc, T, Tc Trimmer Parts Manual Logo
763 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
