Question about Tablets & eReaders
Need to reset password - Tablets & eReaders
Forgot password. How can I reset my Apple account?
From Apple:
If you forgot your Apple ID password If you're having issues signing in with your Apple ID password, use these steps to reset it and regain access to your account.
Your Apple ID is the account you use for everything you do with Apple, like shopping the iTunes Store, signing in to iCloud, buying an app, and more. To reset your password, you'll need to know the email address for your Apple ID. If you're not sure which email address it is, there are a few ways you can find your Apple ID.
Reset your password
After you reset your password
Get more help Reset your password You can reset your password when you go to your Apple ID account page and click Forgot Apple ID or password. Enter your Apple ID, then click Next.
After you enter your Apple ID, there are a few ways you can change your password:
Answer your security questions
If you know the answers to your security questions, select "Answer security questions" and follow the steps to reset your password.
Use email authentication
If you select "Get an email," we'll send an email to your primary or rescue email address that you can use to reset your password. Didn't get the email?
If you use two-step verification
If you set up two-step verification, you can use it to change your password. You just need a recovery key and a trusted device. Follow these steps:
  1. Enter your Recovery Key.
  1. Choose a trusted device. We'll send your device a verification code.
  2. Enter the verification code.
  3. Set a new password and select Reset Password.
If you permanently lost your recovery key or access to your trusted device, you can't change your password.
If you use two-factor authentication
If you have two-factor authentication, you can reset or change your password from your trusted iPhone, iPad, or iPod touch when you follow these steps:
  1. Go to Settings > iCloud.
  2. Tap your name.
  3. Tap Password & Security.
  4. Tap Change Password.
  5. Enter a new password.
These steps will work only from a trusted device with a device passcode enabled. If you don't have access to a trusted device, you can reset your password when you follow these steps:
  1. Go to iforgot.apple.com and enter your Apple ID.
  2. Enter your trusted phone number and click Continue.
  3. Enter the verification code that we send to your trusted phone number.
  4. Provide any additional account information requested.
  5. Choose your new password.
If you can't sign in, reset your password, or receive verification codes, you can request account recovery to regain access to your account. Account recovery will take a few days, depending on what account information you can give. After you reset your password After you reset your password, you'll be prompted to sign in again with your new password. You also might need to update your password in Apple services and on your devices. Get more help If you're still having issues signing in with your Apple ID and password, make sure that you're entering the correct Apple ID. In most cases, your Apple ID is also the primary email address of your Apple ID account. If these steps didn't help you change your password, contact Apple Support.Last Modified: Feb 19, 2016
Feb 15, 2016 | Apple iPad 32 GB WiFi Tablet PC
I am trying to register my kindle but my password is not being accepted
If it is the Amazon.com account password then go online and change your password. If the device password then try the following:
Forgot my password
Did you forget the password used to unlock your Kindle? If so, you'll need to reset the device to gain access. By resetting, your Kindle will be restored to factory defaults, which means your registration information and content will be removed, and all settings will return to the defaults.
To reset a Kindle Fire 1st Generation:
1. From the lock screen, slide the Unlock Bar from right to left
2. Use the keypad to enter characters into the password/PIN field four times
3. You'll be prompted to reset your Kindle Fire. Tap "Ok reset"
To reset all other Kindle Fire models:
2. Use the keypad to enter characters into the password/PIN field five times.
3. When prompted to reset your Kindle Fire, tap "Reset"
To reset a Kindle 2nd Generation, Kindle Keyboard, or Kindle DX:
1. Slide and release the power switch to turn on the device or exit sleep mode
2. Enter "resetmykindle" in the password field and press the enter key on the key pad
3. Wait several minutes while your Kindle restarts
To reset a Kindle (5-way controller):
1. Press and release the power button to turn on the device or exit sleep mode
2. Select the keyboard key once on the password screen and enter "resetmykindle" in the password field, then select "Enter"
To reset a Kindle Touch or Kindle Paperwhite:
2. Tap the password field to bring up the onscreen keyboard
3. Enter "111222777" and select "OK"
If you don't remember your Parental Controls password, you can deregister your device instead of resetting, as long as you're connected to a wireless network. You'll need to redownload your content, but items that were transferred via USB will be kept. Here's what to do:
1. Visit the Manage Your Content and Devices (www.amazon.com/manageyourkindle) page on your computer
2. Select the "Manage Your Devices" link
3. Select "Deregister" to deregister your device from your account
Sync your Kindle, then register again.
If you need help with your Wi-Fi password, please contact your Internet Service Provider or router manufacturer.
Feb 27, 2015 | Amazon Kindle Paperwhite
Forgot Password for my tablet and need to reset it. How do I do this?
If you have forgotten your password you will need to do a hard reset.
There is a complete tutorial on how to reset a proscan tablet here
https://www.youtube.com/watch?v=npnIdZgXJcA
Dec 03, 2014 | Proscan 7-Inch Android Internet Tablet,...
Reset apple id account
Unfortunately, you will need to get to a laptop or tower PC or Mac, in order to reset your password, migrate to apple.com try to login, there should be a forgot password link just below the login entry points. The Mobile version of Apples website malfunctions when attempting to reset a password, this is why you need to go through a laptop or tower to have a successful password reset.
Aug 16, 2014 | Apple iPad 32 GB WiFi Tablet PC
Lost password on asus transformer tf300t
Here is a post about how to reset forgotten ASUS password with Windows Password Recovery Tool 3.0, you need it. Don't waste time at unnecessary help.
http://www.windowspasswordsrecovery.com/hack-computer-login-password.htm
Jul 30, 2012 | ASUS Transformer Tf300t Tablet
How to unlock the administrator password
Use windows password reset tool is the best way to recover admin password
Here are three tools for you.
Windows Password Reset( http://www.windowspasswordreset.net )
Windows Password Recovery Tool ( http://www.windowspasswordsrecovery.com )
Windows Password Crack( http://www.windowspasswordcracker.com )
Jul 19, 2012 | eMachines eM250-1162 Atom N270 1.6GHz 1GB...
I have a craig touch screen tablet and i forgot my dot password how do i reset it?
Unlock windows password,the easiest way I ever use is to adopt Windows Password Reset ,just a few steps:
Step 1: Download and install Windows Password Reset
Step 2: Burn Windows Password Reset Std ISO file to CD/DVD
Step 3: Put in your newly created CD and remove your Windows Password.
For more details,go to: http://www.windowspasswordreset.net
May 27, 2012 | Tablets & eReaders
Forgot my password and i need my school report off of it can someone please help me unlock my acer icona a500
That's nothing.
Nowadays,lots of methos help us to reset windows password,such as use safe mode, windows password software as Windows Password Reset,and password reset disk ect.
The details in http://www.windowspasswordreset.net/article/article.html
May 15, 2012 | Acer Tablets & eReaders
Tablets & eReaders Logo
27 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
