Question about Kenwood Kos-a300 Factory Radio Upgrade Solution
Ineed factory wiring colors for 88 monte carlo radio
  • 655 Answers
Does this have 3 plugs or just one in the back of the radio? If it is 3 plugs, here are the color codes:
http://www.tehnomagazin.com/images/GM12-car-radio-wiring-connector-audio.gif
Posted on Nov 25, 2014
Wire diagram to bypass factory amp in 2005 Monte Carlo. Need color coded diagram
http://bbbind.com/free_tsb.html free wiring diagrams . Enter your vehicle info . year , make , model an engine size . Then under system click on interior an driver amenity , then under subsystem click on audio ,then click on search an four links will pop up . Click on them one at a time till you find the one your looking for !
Aug 19, 2016 | 2005 Chevrolet Monte Carlo
2000 monte carlo took radio out with securtiy cut plug off now car wont start what wires to reconnect?
Reconnect all cut wires should be color coated match them back should be fine. Make sure wire color connection match same color.
Sep 28, 2014 | 2000 Chevrolet Monte Carlo
I want to check my radio speaker fuse on my 2003
You have a fuse for the factory amplifier. It will be lo ated in the fuse panel.
A thumbs up would be greatly appreciated want-check-radio-speaker-fuse-2003-jjq1gbgvbnuqnoqvaolrtxpp-1-0.jpg
Sep 19, 2014 | 2003 Chevrolet Monte Carlo
Radio on but no volume 2000 monte carlo ss
I JUST HAD MY FACTORY RADIO SOUND FIXED IT WAS THE WIRES FROM THE FACTORY AMP IN THE TRUNK TO THE STEREO. WIRES RAN ALONG THE PASSENGER SIDE FLOOR BOARD. WIRES CORRODED BECAUSE OF A MOON ROOF WATER LEAK THAT CAUSED WATER TO SETTLE ON THE PASSENGER FRONT FLOOR. REPLACED WIRES I PAID 100.00 TO HAVE STEREO PUT BACK IN AND WIRE CHANGED, ON STAR EVEN WORKS AGAIN I HOPE THAT HELPED. NOW FOR MY LEAK ERRR
Mar 15, 2013 | 2000 Chevrolet Monte Carlo
Install pyle radio in 1996 monte carlo
Get the proper dash kit end wireing harness adapter kit, That plugs into the factory radio wireing harness, That is the easist way to do it,
Dec 04, 2012 | Pyle Plr34m In Dash Usb Sd Aux Am Fm Car...
Radio codes for chevrolet monte carlo
you may have a card in owners manual that has radio code, otherwise you need the serial number off the back of the radio to give to dealer
Sep 15, 2012 | 2005 Chevrolet Monte Carlo
In need of a stereo wiring diagram for a 1996 monte carlo any help will be deeply appreciated
The easiest and cheapest way to get this is to go to Walmart, Auto Zone or Advance auto and purchase the $7 universal adapter for your vehicle. This is an adapter that has clearly marked wires and instructions for connecting it to any brand radio and will allow you to plug into the vehicle factory wiring harness plug that was originally used.
Feb 16, 2011 | 1996 Chevrolet Monte Carlo
How to unlock a radio on a 2000 monte carlo
Punch code into preset station buttons, you can get your code from a factory repair invoice from the dealer or take your car with your proof of ownership tot he dealer and they will give you the code... assuming you are asking about a factory installed radio...
Sep 15, 2009 | 2000 Chevrolet Monte Carlo
Tripping fuses
find what fuse is, You have to follow the wires with patience, from the fuse box to the item, you have a short circuit look if the horn + wire is not touching metal outside or inside the steering column, have You replaced the steering wheel? if the same fuse covers the dome light, take it a part and see if the + wire is touching the inside of the roof, plastic melted, or look at the on and off Dome switches at both doors, look for the positive wire on radio, antenna and main light switch, yo can disconnect every item and check any time hot wiring that fuse with copper wire every time, to You are sure
Jan 21, 2009 | 1987 Chevrolet Monte Carlo
Kenwood Kos-a300 Factory Radio Upgrade Solution Logo
83 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
