Question about Ryobi Garden
How do you replace a fuel bulb on a 30cc 5hcps-0304ab engine (Ryobi)
  • Eugene Rounds Nov 10, 2014
    Hi Dennis Wilson, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    That number is only the family of the engine. we need the actual model number to be of help.
#1 Taper
  • 1041 Answers
SOURCE: replacing fuel lines on ryobi 767r trimmer
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
  • 512 Answers
SOURCE: Ryobi 775r gas trimmer stalling when tilted
You have a air leak between to tank and motor. Could be carb gasket. When using in tilted position you dont have gravity feeded carb anymore, causing air to be sucked into carb. Take off carb and spray with crb cleaner, then blow out with air gun. Replace gasket, make sure all new lines and bulb connections are connected securely.
Posted on Jul 17, 2009
moretons
  • 155 Answers
SOURCE: I believe the electronic start on the igniton of
these parts are replacement only and cannot be repaired
Posted on Jul 25, 2009
  • 183 Answers
SOURCE: Ryobi 30cc trimmer won't run. Difficult to start, hard to keep ru
chnge the plug for the best you can get then depending on the mix petrol oil mix u could cahnge that ie if its 50:1 go down to 40:1 or visa versa if that doesnt work bin it and get a sthil or an ehco
Posted on Jul 27, 2010
rycgl
  • 1545 Answers
SOURCE: I have a Ryobi 30cc
A good starting point for the Hi and Low speed jets is about 1 and one/half turns OUT from a lightly seated (all the way turned in) position, Never overtighten these as the tips can be damaged. This setting should enable it to start and if one jet had a spring on it, the other one should have one also. Maybe state carburetor/model #'s in another post?
Posted on Aug 08, 2010
I have a Ryobi RPT3000 trimmer. Firstly how do I top up engine oil? And then how do I restring it?
The engine on that trimmer will be a 2 stroke 30cc engine not a 4 stroke.
"Two Stroke Oil" is added to the fuel for a 2 stroke fuel mix in accordance with the proportions specified by Ryobi for that engine. The required petrol/oil mix may be printed on the top of the fuel cap. No other oil is used in a 2 stroke engine.
There are a number of videos on Youtube people have uploaded which will show you how to replace the pull cord on a trimmer.
Dec 28, 2015 | Ryobi Garden
My Ryobi 4 cyl 30cc leaf blower just quit starting. Has always started perfectly, but now it just wont start.
replace spark plug.if spark plug okay problem could be carburetor or air leak at fuel lines or check primer bulb for crack which cause air leak.any breaks in fuel line or primer bulb cause air leaks fuel system cause carb not get fuel run engine.
Sep 20, 2013 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do I replace the fuel bulb?
Homelite and Ryobi appear to be made by the same manufacturer. Home Depot now carries a "Fuel System Tune-Up Kit, AC04122," that includes 2 replacement fuel lines and a replacement Primer Bulb for 25cc, 30cc, and 26cc 2-cycle engines. Cost is $7 +.
Aug 27, 2012 | Homelite Mighty Lite Blowervac
Won't start , can not get primer to work even after replacing primer bulb.
If your fuel filter is clean, and none of the fuel lines are pinched, then you probably need to replace the diaphragms, gaskets, and screen in the carb. Some carbs with the primer bulbs mounted on the carb have a check valve in the primer system. This is the least likely problem, but it is possible that the check valve is defective.
May 07, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
I have a Ryobi 30cc string line trimmer model # 0304AB 2005 model. After cleaning the carborator and replacing the fuel line, I found two needle values that need to be readjusted . Which of the two...
Aug 07, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My TP30 Ryobi weed eater turns and stays on while
You have a hairline leak in one of your hoses or a small gasket under primer bulb.
Jul 05, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
RYOBI RBL-30MVA 30cc when pressing the primer bulb to allow petrol thro, nothing happens? and as its not letting the petrol thro, the leaf blower will not start....any suggestions? thanks ben.
The diaphragm in the carb may need to be replaced. Make sure all your fuel lines are fine. On these inexpensive blowers the fuel lines tend to get brittle and crack and fall apart.
Oct 08, 2009 | Ryobi Garden
Garden Logo
122 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
